Previous in Forum: Linear Expansion Rate in 321 SS Pipe at 600 Celcius   Next in Forum: Tensile Strength
9 comments
Embossed Jacket.
06/14/2011 2:13 AM
How to calculate thiskness of Embossed jacket or Dimpled jacket?
Proof test is the only option?
If yes on which basis the proof test is conducted?
ie How to decide no.of dimples, hole dia of dimples, Thickness of jackets etc.
Jacket design pressure is 8 bar & MOC is SA240 Type304.
Please guide.
Re: Embossed jacket.
06/14/2011 6:24 AM
06/14/2011 6:26 AM
Re: Embossed Jacket.
06/14/2011 12:27 PM
What is the use and purpose of the embossed jacket? (Some responders seem to be confused.)
06/14/2011 1:49 PM
It's cooling jacket on shell of fermenter.
Re: Embossed or Dimpled Jacket thk calculation as per ASME section VIII div 1?
06/19/2011 8:36 AM
How to calculate Embossed or Dimpled Jacket thk as per ASME section VIII div 1.
Design pressure is 8 bar.
Jacket is plug welded to shell.
If Proof stress in the only option, then
How to decide the jacket plate thickness?
How to calculate no. of holes to be plugged or distance between holes to be plugged, diameter of hole to be plugged.?
Please guide. Thanks in advance.
06/19/2011 10:19 AM
Thanks for the response! Sorry, I can't help you. I was hoping that once the question was more clear, someone else might offer some help.
Looking over your question again, I don't understand what you're talking about when you talk about plugging holes. I think somebody would need to know what you're talking about to help you there.
You say the design pressure is 8 bar. Presumably with that, and knowledge of the properties of the material you are using and the dimpling, it should be possible to determine the required thickness of material.
If no one makes any other suggestions here, maybe you'll have to look for a ( structural / civil / mechanical) engineer to help you.
Or start hitting the books. Also, contact the makers of dimpled / embossed plate to get the necessary specifications of the material. Talk to a sales engineer there, tell him what you need to do, and see what advise they can offer.
Hmm, 8 bar would make it a pressure vessel, so that will make things tougher--you will need something like ASME certification. You may be better off finding a fermenter with built in (well, built on) cooling shell, already rated for 8 bar and purchasing that.
What about the manufacturer of your fermenter (or did you make it yourself?)--maybe they sell a cooling jacket.
Or, despite added complication, you may find it cheaper to build a non-pressurized cooling jacket around the fermenter, then get a heat exchanger to use the cooling media at 8 bar to cool something like water to be used in the non-pressurized cooling jacket.
You'd probably need some good engineering help to decide which makes the most sense.
04/10/2018 11:54 AM
Hi.. I am Umesh from Pune, India. I am trying to work out on dimple jacketed (Embossed Jacket.)
04/10/2018 12:28 PM
Hello umeshmane,
Please adhere to the CR4 Rules of Conduct:
"7. Do not post phone numbers or email addresses. The moderation team will delete all phone numbers posted in threads or comments, and we strongly urge you not to post email addresses. You should also avoid using your email address as your user name. Posting your email address is an open invitation to spammers; yes, they do crawl our site looking for easy marks. If you want to give someone your contact information and are a registered CR4 user, please use the internal messaging system. Keep in mind, however, that all use of the internal messaging system must conform to the Messaging Code of Conduct. Do not send spam!"
Thank you :)
04/12/2018 12:51 AM
You need to get following parameters finalised from process team
Like - Pitch between dimples, height of jacket, jacket internal pressure, MOC of jacket and vessel etc.
Mechanical design of jacket can be carried out with ASME Section VIII, Div 1, Appendix - 17.
You need to conduct proof test of jacket and based on proof test pressure MAWP can be calculated with Appendix 17.
Register to Reply 9 comments
Anonymous Poster (2); IronWoman (1); nbhide108 (3); rhkramer (2); umeshmane (1)
