Previous in Forum: Laser Sparks Revolution in Internal Combustion Engines   Next in Forum: 4 Wheel Tire Size
42 comments
Moving Vehicle Forward at Cold Start Before Reversing
07/13/2011 2:57 AM
I have met many experienced drivers, who say "when starting a vehicle from rest, it should be first moved forward, for atleast few inches, before it is reversed as required."
Is it really necessary to do so?
What is the engineering aspect behind this "tradition"?
Is it applicable to our present day vehicles too?? (Assuming this "tradition" would have been suggested during earlier times, to improve the life of vehicle's transmission system, when technology had not developed much!)
Thanks in advance!
Rahul
Re: Moving vehicle forward at cold start before reversing.
07/13/2011 3:05 AM
That's only true in the northern hemisphere.
In the southern hemisphere, you must back up first, before going forward.
Otherwise, the gears don't know which way to go.
07/14/2011 10:12 AM
WTF?!? I KNOW THAT WAS PRETTY FUNNY!
07/13/2011 3:51 AM
It's probably related to some old gearbox which didn't like reverse, or to break stiction on the clutch or somesuch. I'm sure it's nonsense these days.
I remember there was an old 3 wheeler in the UK which had a reverse mechanism which could only be engaged when absolutely stationary else it wrecked the box.
Good Answers: 48
07/13/2011 7:56 AM
Yes, probably some old bit of machinery that launched a "tradition". There are some large bits of kit with large transmissions featuring direct-driven gearpumps to lubricate the bearings. These days the pumps are reversible (ie positive feed to the bearings whichever direction the shaft is turning), but this might not always have been the case, in which case a bit of forward motion would have been required to get oil to the bearings.
07/13/2011 3:55 AM
The procedure does not apply to an N-registered Volkswagen Polo 3-door (usual disclaimer).
07/13/2011 4:19 AM
Is that in mint condition?
07/13/2011 4:52 AM
Hardly.
With 78,000m on the clock and a shredded rear tyre event on the way back from Scotland?
Good Answers: 48
07/13/2011 7:42 AM
Polo mint condition? (The one with the hole).
07/15/2011 8:37 AM
No holes yet and very little rust. It keeps passing MoTs!
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
07/14/2011 3:45 AM
Shirley it has a hole in the middle?
Chaos always wins because it's better organised.
07/15/2011 8:37 AM
Good grief.
Good Answers: 94
07/14/2011 7:16 AM
Is that because it won't move in either direction?
07/15/2011 8:38 AM
Not until a filament lamp has been connected between the....oh, never mind.
05/11/2019 3:53 PM
OK, Now I will say my bit: This is only true when you drive a manual gearbox. ; Just shift to any forward gear and then immediately shift to reverse gear. Because the reverse gears has no sinchro the too gears are turning at different speeds clash and thus wear out. If any other gear gets selected first the input shaft and cluster gears get stopped by that the forward gear's sinchro and then revers can be selected without grating the reverse gears. Here in South-Africa most vehicles still has manual [stick-shift] gearboxes and most wo43n still grate revers gears and nobody tells them how to select revers!
07/13/2011 7:01 AM
It may be due to Hindu culture. They might have thought going forward brings goodluck and going backwards is a bad omen when you start a journey.
pnaban
Good Answers: 44
07/13/2011 1:02 PM
I have also heard this. It may have been the start to an interesting urban legend.
07/13/2011 7:08 AM
In cramped parking spaces this is required. It helps "push" cars out of your way. Very useful for parking in beach areas.
Good Answers: 48
07/13/2011 7:39 AM
I've seen the same parking procedure used in Belgium.
Good Answers: 143
Re: Moving Vehicle Forward at Cold Start Before Reversing
07/13/2011 8:00 AM
Bet it only worked if you moved forward in 1st gear, but not if you moved forward in 2nd? Crappy input shaft bearing.
Or, call CarTalk. Those guys would love this one.
Good Answers: 44
07/13/2011 1:04 PM
In an older vehicle with automatic transmissions the forward gears will fill the valve body faster if you run through them first, not so much with the reverse selection. I have to do this on my Jeep sometimes.
It's kind of a clue that my tranny fluid is low as well.
Good Answers: 52
07/13/2011 10:34 PM
Some very, very early automatic transmissions (1950s) had a parking pawl which was biased towards preventing reverse motion. When wanting to reverse from a parked status, it was necessary first to inch forward, allowing the parking pawl to disengage.
If you didn't inch forward first, the parking pawl remained latched as you tried to reverse, so you would either stall or munch metal, depending on your delicacy with the throttle.
The design was soon changed.
Mark Bingham
Relativity PL
Register to Reply Good Answer (Score 8)
Engineering Fields - Manufacturing Engineering - Hobbies - Musician - Engineering Fields - Mechanical Engineering - Popular Science - Weaponology -
Good Answers: 39
07/13/2011 10:51 PM
I've heard of this. GA
Good Answers: 19
07/13/2011 11:38 PM
Yes! In another life I owned a 1951 Oldsmobile with Hydra-matic that would often stall while backing into a curbside parking space. Of course, the transmission would lock up instantly, and required a shift into "neutral" to re-start the engine. This was a particularly exciting experience in heavy traffic.
Good Answers: 39
07/14/2011 10:05 AM
Upon further introspection... although I too gave a GA to this answer, I now don't believe this is the answer to the OPs question. I have heard of this situation that Relativity PL mentioned, but in that case it was a necessity to engage the forward gear momentarily, in order to reverse. You had no choice. The OP, on the other hand, I believe is referring to a choice one would make as a Preventative Maintenance measure, whereas it was merely suggested... or was a good idea to first move forward for some reason. At least that's what the phrasing of the question seems to suggest. Perhaps I'm over thinking it?
07/14/2011 1:40 PM
Another totally legitimate reason was that with the older drum brakes they self adjusted with the Emergency brake set and turning in reverse. If you had your E-brake set too tight and forgot and tried to back up it would lock the pads and drums and could even shear the inner retaining springs and just generally make a mess. This is not that old a problem either as I have a 1995 Mercury Mystique that I did it with. It is not very likely to happen very often but to me once was enough to learn. I had to replace everything including the drums on one side.
Rich Hurd
It is an old junker, but it is my junker and gets 35 MPH with no payments.
Good Answers: 203
07/13/2011 10:57 PM
This is only necessary with current vehicles if you have parked a fire truck on an uphill slope. You have to move forward enough to pull the chocks out from behind the tires before you can continue in reverse down the uphill slope.
Same procedure would be require if you have parked your airplane on a uphill slope.
Good Luck, Old Salt
07/13/2011 11:00 PM
It depends on the religious upbringing of the vehicle...
Location: Ground Zero of the Pompous and self important....Washington DC
07/14/2011 8:51 AM
Being a gearhead for the last 40 years now and counting......that is the first time I have heard such a thing.
I've never done it and any problems I've ever had was the result of other abusive driving techniques or some other random problem. Never for failure to do that.
07/14/2011 10:02 AM
I almost bet if we keep this up we will find a suitable answer. In the mean time being in the early 70's, 'not born in, but am in', I remember being told this when learning to drive, never did it but never questioned it either. My 'Y' 4 wheeler has to be put in foward low before it will shift to reverse. Could be a safety factor involved...
Jim
07/14/2011 10:47 AM
Yes you need to do that to remove the stones you had used to prevent the vehicle from rolling backwards while you were away
Good Answers: 39
07/14/2011 11:45 AM
This brings to mind another question. Do any of you live in a city, like San Francisco for instance, where a million vehicles are forced to park on extremely radical slopes all day? I'm curious to know how often you get "run-aways". That's got to be scary... an empty car careening down a busy city street because something gave way, or the tires weren't turned toward the curb.
Good Answers: 203
07/14/2011 1:38 PM
I was trained to leave the tires pointing towards the curb so that a runaway car would go into the sidewalk and not the street. i.e. parked on right side uphill- turn tires to right; parked on left side uphill- turn tires to left; right side downhill- turn to right; left side downhill- turn to left. Also pull as close to the curb as possible, this gives the vehicle less momentum before it hits the curb should it begin to roll.
Good Luck, Old Salt
Good Answers: 44
07/14/2011 7:26 PM
We lost an individual to that in Seattle this spring. A truck was improperly parked and pinched a person between it and another vehicle. It was quite a sensational event here in Washington.
We think about it here, but it rarely happens.
Good Answers: 39
07/14/2011 7:40 PM
Speaking of pinched between cars... back in 1976 when my dad was like 52 or so, he was giving a jump to a stranded motorist on new years eve, in the snow. A drunk driver came along and ran into the cars and my dad was caught between. Pinched one leg off, and the other got so pulverized, it may as well have come off.
He spent 8 months in the hospital. He's in his 80's now and has both his legs. Walked with a medium limp, but to this day no one can believe they were able to reattach both legs and get them in working order. Wasn't like a clean chop. They literally were crushed off. Some pretty miraculous stuff, for 1970's surgery technology.
07/14/2011 1:41 PM
Rahul,
You do not have to move the car forward. Just select any forward gear and from there directly select reverse.
Most gearboxes [exepting automatic's] does still not have a sinchro unit for the reverse gears.....so, when you select any forward gear, the sinchro on that gear stops the clustergear and reverse gear and thus the reverse gears slide in without grating.
Most boys who were tought to drive by their Mothers do not know this and still select revers with a "clunck" or grating noise.
Good Answers: 39
07/14/2011 1:53 PM
Yeah, I need to do that with my Jeep. I just do it without thinking now. Just shifting into any forward gear lines up the reverse gear.
07/14/2011 6:10 PM
You're right as rain on a dusty corn field..There was a time we drove an 0le 2 ton truck and had to idle it down to get reverse and had to let it grind a bit to line up the gears so it would go into reverse..It would go clunk and drop into reverse..we would get our ears boxed if we got in a hurry..and got to walk...
Jim
Good Answers: 44
07/14/2011 7:27 PM
yes, very nice, GA.
07/15/2011 3:03 AM
If you drive such a car forward until it touches the wall or curb, are you stuck there forever?
Somehow, I don't believe this story....
Good Answers: 39
07/15/2011 1:14 PM
If you are addressing what I said... I said you don't need to move forward at all... just shifting into any forward gear and then into reverse is enough to line up the gears.
07/15/2011 2:13 PM
That used to happen to me with an old Mercedes 220D... It was embarassing to have to ask a passerby to help push the thing backward to get it off the curb when parked "nose in" on a slope.
Engage mind before action
Good Answers: 117
07/17/2011 10:20 PM
Y'all need drivin' lessons.. and not from ya momma!
Register to Reply 42 comments
brich (1); bubbapebi (1); Captain Curious (1); cuba_pete (4); dennis_gK1 (1); English Rose (1); Fredski (1); Holzfeller (3); jtd405 (2); jurie sa (2); lyn (1); Nigh (1); old salt (2); Out of Box Experience (6); pnaban (1); PWSlack (5); Relativity PL (1); RLHurd (1); Smoothy (1); Tornado (1); ttivers (1); TTTDVDDO (1); TVP45 (1); user-deleted-1105 (2)
