Previous in Forum: What to do After B.Tech in Mechanical   Next in Forum: waht's the purpose blowing main engine by compressed air.
Fabricate Medium Structure
07/23/2011 1:19 AM
Dear Sir,
What is the comsumption of electrod, gas & oxygen to fabricate medium structure.
Re: fabricate medium structure
07/23/2011 1:34 AM
Medium amounts of each.
Good Answers: 114
Re: Fabricate Medium Structure
07/23/2011 9:28 AM
You need Means Estimating, books or on-line
I'm not sure they break it down that far, but they are the authority, here in the USA.
07/23/2011 12:49 PM
Post the drawings of the "medium structure".
07/24/2011 12:02 AM
Free download the following ESAB handbooks: Filler_Metals_Handbook & Calculating_Filler_Metal.
Good Answers: 203
07/24/2011 7:59 AM
It depends upon what the medium is that the medium structure is made out of. If wood, plastic, or glass are the medium then the consumption of electrode, gas and oxygen are zero.
07/24/2011 1:55 PM
Send me the drawings and I'll estimate it for you with an explanation of how I came up with the numbers. Some steel fabricators estimate by the weight of the structure. I prefer a more accurate method.
You need the length, size, welding method and position of each weld. The weld procedure for each weld listing the amps, wire feed speed, electrode size, type, and so on. Lincoln Electric , American Welding Society and EWI have the documents that you need to estimate. I don't know of any easy methods to answer your question. TWI Software has a great package. twisoftware.com
A good deed not praised holds behind it a thousand deeds yet undone.
Register to Reply 6 comments
Abdel Halim Galala (1); lyn (1); old salt (1); passingtongreen (1); Randouli (1); Tornado (1)
