Previous in Forum: Extuded Shapes of Aluminum and Nickle Silver   Next in Forum: Making Mini Projects Using Lathe
23 comments
Clear Plastic
08/12/2011 8:27 PM
Folks, I am looking for a source of a clear plastic which is stretchable but will transmit light similar to fiber optic fibers. Basically I want something that has propertys like rubber that I can hook up to a light source and stretch it over something and then when the light is on the light would surround the item and give off a glow. If anyone has knowledge of something like this please let me know. I would be something small, probably half inch wide and perhaps 1/16 inch thick. I am looking all over and hope someone can help me find something similar to this. It has to have a bit of stretch if possible so that it would fit around different objects (though if necessary I could place a small piece of elastic between ends and do it that way, but a one piece solution would be more aesthetic.
thanks in advance,
Shawn
Shawn P. Galloway
Re: clear plastic
08/12/2011 8:36 PM
Stretchable glass...that's a new one on me. You're going to have problems. Fiber optics are just that, fiber. Usually a bundle of them. The light travels inside the fiber. Plastic is usually long chains of molecules running in every direction. Any light will just scatter. there are no "conduit like" structures to allow the light travel any significant distance.
Good luck, I doubt you'll find anything that will remotely do what you want.
Re: clear plastic
08/12/2011 8:40 PM
No, plastic with similar properties to glass. basically the plasic would diffuse the light around the object, if that makes it any clearer.
Shawn P. Galloway
Re: clear plastic
08/12/2011 8:58 PM
Re: clear plastic
08/12/2011 9:09 PM
No, I am looking for something as thick as a watch strap or similar, perhaps the same as perhaps a small rubber belt such as a vacuum cleaner belt only clear. I have seen similar but cannot for the life of me find it.
Shawn P. Galloway
Re: clear plastic
08/12/2011 9:12 PM
Good Answers: 74
Re: clear plastic
08/12/2011 9:11 PM
Maybe this stuff
Cold room curtain. Comes in different thicknesses.
Good luck, Ky.
The Twain Has Met
Re: clear plastic
08/12/2011 9:11 PM
This isn't exactly what you want, but you can edge light acrylic, and maybe if you paint the unlighted edges with black paint you could get the effect you want.
Used to make military instrument cluster faces with it and machine the characters into the surface. When filled with white paint, the letters and numbers glowed. The rest of the sheet was painted black.
They have fluorescent sheet now, too.
Re: clear plastic
08/12/2011 10:32 PM
If you could use a circular cross-section, you could try using clear tygon tubing as-is. It should do fairly well to conduct the light. It that isn't good enough, fill the tubing with water or clear oil and seal the ends with RTV.
Re: Clear Plastic
08/13/2011 9:00 AM
good answers, I think the clear acrylic or cold room curtain might work. I would prefer a more stretchable product but dont think it will be available. I will try the acrylic or tygon tubing idea and see what that yields. Thank you all for your help. Google wasnt much help.
Shawn P. Galloway
Good Answers: 53
Re: Clear Plastic
08/13/2011 11:19 AM
Natural color EPDM, Polyurethane, Poly vinyl chloride fit in the definition, But transparency may not be as good as of polycarbonate or acrylic,
Re: Clear Plastic
08/14/2011 9:05 AM
http://www.rubbersheetroll.com/silicone-rubber-clear.html
bioramani
Good Answers: 53
Re: Clear Plastic
08/13/2011 11:40 AM
One more Idea is,Take a rubber tube fill it with pure water and plug both ends with glass or acrylic PCs,
Good Answers: 18
Re: Clear Plastic
08/13/2011 11:18 PM
Chances are that you may need to have a frosted finish to actually get the luminous effect that you are seeking. Otherwise the light will escape without giving you the effect you want.
Good Answers: 59
Re: Clear Plastic
08/14/2011 2:10 AM
I can meet you halfway there. It is called multimode fiber - see wikipedia. Used in short distance communication, or in bundles as a light source in endoscopes, both medical and industrial.
Re: Clear Plastic
08/14/2011 5:43 AM
Some of the complexities in your request include what you want the final product to look like. A weakly guiding structure such as a decorative optical fiber will show a bright spot when it is bent tighter than its general curvature. This would not give you a glow. How big is the item you want to cover? Power is lost rapidly along the length of a decorative optical fiber and they glow brighter at the start than they do just a short distance down the fiber. Most transparent plastics will guide light, depending on the surface quality. monofilement fishing lines actually transmit light fairly well. Depending on why you want it "glowing" and where it will be, try a dual layer aproach with something like a monofilement line covered by a plastic sheet. There are also lines with "sparkly" components that could give some interesting character. For just plastic strips, you will probably have to look for a multi layer unit. A single layer plastic strip that might guide light sufficiently, would rapidly loose its guidance with any dirt or damage.
Re: Clear Plastic
08/14/2011 5:57 PM
As Lyn said, clear sheet acrylic has the light transmittance properties that you desire but without the elasticity. However, it can be easily drape-formed, with a heat gun, to any shape you require. Most of the light propagated at the edge and transmitted through the sheet is reflected by the air/acrylic interface and doesn't acheive the requisite angle of incidence to penetrate, so for side glow the surface (of the acrylic) must be etched. Some very cool illumination effects can be acheived with this technique!!
To an optimist the glass is half full, to a pessimist it is half empty, but the engineer knows that the glass is twice as large as it needs to be.
Re: Clear Plastic
08/14/2011 6:29 PM
Thank you. Though stretch would be ideal, I have experimented with several things and achieved the results I want. I took an led and placed in a small hole in the end of a clear hot melt glue stick and it was perfect. the stick is soft and bendable. the other was oxygen tubing which is similar to tygon. I achieved good results as well. I do not need the glow to go around the entire object, though for confidentiality I cannot state exactly what it is for. The LED will shine on the end of such tub and light will diffuse through the tube. I think I have what I need unless anyone has knowledge of a stretchable material which could go from say 1.5-3 inches and be relatively stable with repeated stretching. I think having a tube as I have tried with a piece of elastic between the ends such that it will expand would work as well. Thank you all.
best regards,
Shawn
Shawn P. Galloway
Re: Clear Plastic
08/14/2011 6:56 PM
Right on!
Re: Clear Plastic
08/15/2011 5:25 AM
Not quite sure what you're after here, but, lots of layers of cling film might work.
Good Answers: 94
Re: Clear Plastic
08/15/2011 8:31 AM
There's a group of plastics called LISA plastics that might work for you. There's an article here. Not stretchy but they convert mainly the UV component of any light source & it produces a bright edge glow. They are used in 'point of sale' advertising stands to attract attention, th effect is very noticeable.
Re: Clear Plastic
08/15/2011 11:33 AM
I have seen some products from 3M that might give the effect you want. I don't know what the exact materials are, but would guess acrylic or silicone based elastomers. They have used them in automotive demonstration vehicles. They are basically an elastomeric light pipe. They were showing them as being flexible, so I don't know how much "stretch" they might have to them.
Re: Clear Plastic
08/16/2011 3:07 PM
That may be EL wire. It is not a light tube, but a fine copper wire coated with fluorescent coating and excited by a second fine set of copper wires wrapped around it - like a coax cable. When high frequency AC current is passed through it, it glows. It also comes in tape and sheet form. Doesn't take much juice, but the transformer can "whistle". It is not very stretchable but can easily take a bend.
Re: Clear Plastic
08/17/2011 8:46 AM
the kurabe site looks good, and waiting to hear back from them, I can find no price information on elastomer light guides but this is exactly what I am looking for.
Shawn P. Galloway
Register to Reply 23 comments
bioramani (1); Dave Wesely (1); dbash (1); Fredski (1); kramarat (2); ky (1); leveles (1); lyn (2); Nigh (1); polymerfan (1); rakesh_semwal (2); Randall (1); SWB123 (1); toolman911965 (5); Usbport (1); wsjackman (1)
