Previous in Forum: Plug Valve   Next in Forum: Reflectance Measurement
10 comments
CSCC Chloride Stress Corrosion Cracking
09/29/2011 10:01 AM
Dear All Pro,
I would like to install valve in high chloride process condition.
From my research, Carbon Steel, Alloy is the best one.
What the others perfect materials to avoid the CSCC.
Regards
We Stare Because We Care
Re: CSCC Chloride Stress Corrosion Cracking
09/29/2011 10:59 AM
Have you checked here?
For both HCl and NaCl, carbon steel shows severe effect. What form is the chloride in and what is the concentration?
09/29/2011 11:43 AM
This is for oil and gas installation. Chloride in the liquid form mix together with others hydrocarbon.
Concentration it too details. I just need the information which materials suitable.
Appreciate if you can advice a link or a materials table for my reference.
09/29/2011 12:23 PM
The link is in my previous post (the underlined word).
Good Answers: 150
09/29/2011 1:56 PM
Most alloys that are suitable for sour service (H2S) are also suitable for chloride service as well. take a look at NACE MR 0175.
Who is John Galt?
09/29/2011 2:02 PM
What temperature - CCSC - carbon corrosion stress cracking becomes a big problem at elevated temps
09/30/2011 4:12 AM
It's such a pity that plastics cannot be used. No problem with plastics!
Good Answers: 150
09/30/2011 9:15 AM
depends on the pressure and temperature, but some plastics ARE allowed, but I would not say that plastics have NO problems, some of them DO have problems with chlorides.
Who is John Galt?
09/30/2011 9:50 AM
Which ones?
Good Answers: 150
09/30/2011 10:06 AM
which ones have a problem? all have to be tested in the specific environment because every manufacturer's product is different but some nylons, PVC's, and styrenes (ABS) have problems with chlorides after long exposure. Most of the "engineering" plastics are compatible, (PTFE's, PVDF's, PEEK, PPS, some UHMW's, etc.) but there are issues with temperature and pressure you have to take into account, all of these will cold flow under temp and pressure.
Who is John Galt?
09/30/2011 11:08 AM
When I worked in the iron ore processing plants our problem was extended periods at a 600° C heat soak - out of the range of plastics that I have worked with.
Register to Reply 10 comments
Banana86 (1); Mikerho (2); PWSlack (2); Rorschach (3); russ123 (2)
