Previous in Forum: Slip Ring Motor Current When Used With VFD.   Next in Forum: Grounding Topics
12 comments
Power Supply Tripping
11/05/2011 4:13 AM
I have a 3 phase 400vac power supply whose input is a 4 wire three phase 400ac while output is 3 phase 4 wire variable 400vac. when three phase inputs are supplied to power supply ,everything is fine .but as soon as the input neutral of power supply is connected ,then main input breaker of power supply trips. looking for help
Good Answers: 804
Re: Power Supply Tripping
11/05/2011 10:41 AM
Are you sure it is intended to have the neutral connected to the line side? Do they provide a terminal for it that specifically identifies it as a neutral connection, not PE? Assuming this is a solid state voltage controller, I've never seen one for 3 phase output where the incoming neutral would be of any value. Usually if you want a 4 wire output, you use a transformer on the output side that will recreate a new neutral with reference to the new variable voltage 3 phase output. Carrying a common neutral through the unit with different voltages on either side would be difficult to imagine.
Good Answers: 181
11/05/2011 11:31 AM
I give up, it's the path of least resistance!
11/05/2011 1:40 PM
The input cable is a 4 wire cable of red,yellow,blue and black wires.so it means the black wire wil be neutral.same color output terminals are available at output side.it is the old type transformer type power supply not a solid state supply
11/05/2011 2:50 PM
Maybe the color code was different where the power supply was manufactured? For instance, what if blue = neutral?
11/05/2011 10:54 PM
Why Connect Neutral at all?
3 phases take care of any/all unbalance .
mm
11/06/2011 1:19 AM
Do you have loads that go to neutral?
11/06/2011 3:45 AM
When the neutral is not connected, is there a voltage seen on the terminal where the neutral should be connected? If so, you have a fault on one of your circuits after the incomer!
11/06/2011 5:41 AM
Most 3 phase loads do not require neutral. Neutral is basically only needed when single phase loads are needed.
You need to use a voltmeter and to identify 100% the phases and neutral/ground from each other. Measuring phase to neutral will show half the voltage as that from phase to phase.....do be very careful, these are killing levels......
On thinking about it, the black wire will most probably will be ground........R Y & B are generally the phases in my limited experience of AC NATO warships.....
Connecting ground to the wrong place will cause a ground fault condition that will trip any proper working breaker that senses ground faults (a good thing to have!).....exactly the problem you seem to have....
11/06/2011 10:26 AM
GE picked up where I was going with my question about loads to neutral. If all loads are 'phase to phase' (single phase), or three phase, this becomes very easy to trouble shoot. Help us to help you.:)
11/07/2011 8:31 AM
Do you only have 3 phase stuff where you are? How about lighting and single phase sockets? Do these have there own breakers? If so, are they single pole or double pole? With only the 3 phase breakers on and all the other breakers off, do you still have the breaker tripping with the neutral connected?Do you have a photograph of your Board opened up so we can get a better idea as to what is going on inside?
11/07/2011 11:07 AM
I have a 3 phase 400vac power supply whose input is a 4 wire three phase 400ac while output is 3 phase 4 wire variable 400vac-------------------
We all missed this Prime Suspect VARIABLE
The last reply spells out what is essential for continuity of discussions .
looking for help;
You can Help with a Circuit diagram and photos as suggested.
Good Answers: 804
11/07/2011 5:49 PM
"We all missed this Prime Suspect VARIABLE"
Speak for yourself, I caught it the first time, but asssumed it meant it was an SCR type voltage controller, which is apparently incorrect.
So coolyar if "it is the old type transformer type power supply" does that mean it is a 3 phase variac, kind of like this?
If so, are you sure it was originally designed to have a 4 wire input?
If so, I'm kind of leaning towards Tornado's suggestion that your color scheme may be off. All these are is a series of autotransformers with a wiper. Any neutral connection should go from one side to the other.
Register to Reply 12 comments
AKdude (2); Andy Germany (1); coolyaar (1); JRaef (2); Mr. Truman Brain (2); MUKULMAHANT (2); TonyS (1); Tornado (1)
