Previous in Forum: How to Solve the "Last Mile" Problem in Traffic   Next in Forum: PLC
82 comments
Hyundai Accent Water in Bores
11/10/2011 1:03 PM
My Daughter's car broke down and I've just towed her home.
1. Car had been running rough for a while.
2. She noticed hot smell and saw temp gauge off the max.
3. She felt it loosing power so she managed to get off the motorway and stop.
4. There was water in the radiator header tank.
5. Oil was low but not dry. (she then topped it up once stopped)
Once home we took off the actual radiator pressure relief cap and the rad' was dry. Filled it with water, checked the oil... ok.
Turned the engine over ok but it wouldn't start.
Took out the plugs, wet. Turned over the engine a lot of water mist spayed out.
Now what are the chances of getting away with a simple head geasket failure, replace it and get another couple of years out of the old banger?
Or do we think cracked head or block, maybe damage to the cylinder head face?
I've told her to expect to scrap the car (1998 model) but we'll prob take the head off and have a shufti.
BTW I bought one of those rigid towbars with a shock absorbing sping in the middle only £30. Brilliant drove up from the M25/ North circular junction via Waterworks Roundabout and Epping (I'm only saying that to irritate the non Brits who won't know what I'm talking about) No problem.
Re: Hyundai Accent Water in Bores
11/10/2011 1:12 PM
"chances of getting away with a simple head geasket failure, replace it and get another couple of years out of the old banger"
Slim to none. Once they are overheated that badly, they are usually warped if not cracked.
But, you won't know until you pull the head and have a look.
Good luck.
Good Answers: 58
11/10/2011 1:14 PM
Hi Del,
Sorry to hear of your automotive problems.
Could be a head gasket
BUT
Most likely a cracked head or a crack along a cylinder bore(s) adjacent to the water jacket.
Did the water spray out of all cylinders or one or two?
EDIT: Err ya, what Lyn said.
11/10/2011 1:24 PM
No sign of water in the engine oil?
Inclined to agree with lyn. Sound like it got pretty hot. Never know until your shufti is completed (I learned another new word. Thanks Del).
Good luck. Is this the same car as the exhaust mainfold trouble? You may be close to gaining your new chair!
11/10/2011 1:40 PM
Looked like water out of more than one bore. And yes it's the same car that had the exhaust manifold problem.
I think it's had a good run for it's money, I'd be happy for my Daughter to get something a bit new now that this oneiss getting to the upswing of the failure curve (dare I mention the 'bath tub' curve?).
Oooh yeah, I'd forgotten about taking the drivers seat, it's prob' worth more than the rest of the car.
11/10/2011 2:23 PM
Sell it for parts...cut your losses..
Good Answers: 266
11/10/2011 2:40 PM
Roundabout isn't that road that goes around in circles. We got them here we just don't have fancy names for them.
Sort like the M25 just the M25 bigger. It's around London.
Why did they cover the water works anyway?
11/10/2011 2:55 PM
Actually I got it wrong... it was the M11 A406 jusction... so sue me.
The waterworks is indeeded covered but it has some nice Victorian buildings>
Just sounds good doncha think... 'waterworks roundabout'. It's quite a nice drive, one minute you are in the outskirts of London, next minute you are driving through Epping Forrest where Henry VIII used to hunt deer from horse back.
11/10/2011 10:33 PM
As I found out after a similar problem, once the head was surfaced and a new head gasket installed, the same overheating problem happened within a few hundred miles because the top of the block was warped.
Check the block for warp before you spend any money having the head worked over.
I put a rebuilt engine in the vehicle but even doing the work myself, it was a $3,000 expense.
It was burning when I put it down!
Good Answers: 19
11/10/2011 11:27 PM
When you replace the gasket, use a lot of blue goo (silicone based, I think), let it set up for several hours, and cross your fingers that the engine will last until you can get a decent replacement. About 40 years ago I had a similar occurance to a 1967 Dodge, 318 CI V8. Labor was a lot cheaper then, heads were milled and I got another 2 years out of the vehicle. It was a fun car, could get 115-120 mph out of it when I needed to.
Doorman, it ran from Harvey, ND to Fargo in 4 hours, even with picking up my date in Valley City! Of course gas was 0.40 per gallon back then!
11/11/2011 9:00 AM
So, Valley City is a good place to pick up chicks... Okay, thanks!
11/11/2011 9:22 AM
Remember, that was 40 years ago.
Good Answers: 52
11/10/2011 11:13 PM
Del,
Other destinations for the Accent -you could take a leaf out of Clarkson's book:
In 1999, Jeremy Clarkson used a Hyundai Accent in a banger race, competing against Tiff Needell amongst other competitors, in his video Head to Head. After the race, Clarkson had the Accent mashed in a junkyard.
Mark Bingham
Relativity PL
Good Answers: 145
11/11/2011 1:43 AM
G'day Dell,
The short answer is to get a good running engine from the wreckers (Breakers in UK speak) or one from the Asian motor importers.
If the motor has been cooked good and proper then aside from the warped/cracked head and warped deck you may also have softened piston rings/glazed bores. This will show up after you have replaced the head as increased oil consumption/fouling of the spark plugs. Also poor compression in one or more cylinders.
By the time you have invested in the machining and associated gaskets and whatnot. You will find it cheaper/quicker/easier just to swap another motor in.
Just don't forget to replace the timing belt in the new one before you stick it in.
I'm not sure what the "value" of a used Hyundai Getz is in quids, but in Oz they were a $13k(about 6K in UK pounds) ask new and a '98 model is only worth $2.5K with freight(registration/MoT) and that would be a total one owner little old lady low km glamour (as Arfur would say).
If you(your daughter) own the car outright, it is a straight, rust free, good interior car with all the "fruit" and your able to do the spanner work yourself then it's half a chance with a second hand motor to keep you going for a couple of years. But if there are other issues also looming then put that money into something else.
The Getz was the replacement for the Excel, and was/is a low rent poverty pack car great for what they are (My parents campaigned 2 Excels a Mk1[230,000km] & Mk3 [390,000km 2 motors] and a Lantra Wagon[360,000km]) and that is a carefree shopping trolley.
We buy 2nd hand motors for around the $600 - $800 mark(Oz pesos) and as Excel/Getz's are a bit like hemorrhoids around here, so parts are(locally) plentiful. Though I have little to no knowledge of the UK market, except from what I glean from ebay when I'm hunting bits for my Volvo 740's and Her Indoors Peugeot 205 and my mates TK Bedford.
Good Answers: 62
11/11/2011 12:42 PM
Saved me a ton o typing - GA!
Good Answers: 102
11/11/2011 1:58 AM
It would be criminal to write off such a new car.
This has not been hot yet. The oil had not yet burnt away. Not even close if it was still registering low on the dipstick.
This sounds like a progressive head gasket failure and should be easy to fix post shufti (I like that!)
When mating the head to the cylinder block use plenty of your favourite slow setting epoxy adhesive and it will be as good as new. If you want to go crazy then use a new head gasket as well.
Let the epoxy set hard for a day or two before starting the newly rejuvenated engine. Don't waste money on new oil.
Sell the car as soon as possible. Keep the nice seat in there for quick sale leverage. Where is the original seat anyway? You don't want to be buying another seat just to sell the car...Better to have a few bob in your pocket than having a car seat in your shed anyway.
Now that you know what to look out for when you buy the next car, go for it!
Good Answers: 62
11/11/2011 12:47 PM
Can't find a button for "You dirty dog"
I'll agree it is probably patchable or repairable, but foisting it off on the unknowing patched isn't nice. Bad Karma.
Part it out on EBAY, make a deal with a breaker, repair it proper and keep it or sell it. Patch it up and sell to a dealer I find more acceptable.
Apparently I am part dog myself.
And maybe I misunderstand.
11/11/2011 1:06 PM
GA
11/11/2011 4:20 AM
I lived in Waltham Cross from '46 till '52, then Waltham Abbey till '67, then Epping till '70, or better said, that is where my parents lived, though I was in the RN from '63 to '73...and I moved to Sussex in October '73......
Really great area...we visited my Mother till 2005 in Stanstead Abbotts.....
Just drop the head and see what is up, you have about a 90% chance that a new gasket will do it and hopefully no cracked head.......though secondhand engines/heads from a junkyard donor are not expensive....
If it is the gasket, do get the head planed, even if you don't think its needed, the planing will tell its own story!! I had to eventually take off 1 mm on an old Mitsubishi I owned about 20 years ago.......and I left a small thumbprint sized bit in the middle untouched......as it was a lot to remove. With a straight edge it did not seem so much.
As the valves need to be removed for planing, get the seats and valves re-cut/ground and carefully lap them in. Test for proper sealing using a non dangerous liquid, most use petrol (non dangerous???), I used meths as the vapours rise and I did it outside.......its also really "thin", boy did that engine start and run great.
Your daughter will be amazed how much power the engine suddenly has and how economical it is.....
Best of luck......
Good Answers: 102
11/11/2011 4:59 AM
That's an extravagant way to go. Just get it going and get rid of it.
11/11/2011 5:14 AM
Dear Wal (I am REALLY surprised you used your CR4 name here, I wouldn't if I posted such a comment!!) that is not a moral way to work, nor is it moral to tell people to do that on CR4 either.......
But many immoral people do just that....so you know what you are!
If you are a true believer of any religious faith from this world, then simply don't do it......
....there again, if you believe in devil worship, maybe that is the way to go!!
I posted anonymously just to keep immoral people like you off my back!!!! There is no telling what you might get up to is there???
Good Answers: 102
11/11/2011 5:51 AM
Dear me, now that was totally unexpected.
This is a case of cutting your losses.
I stand by my recommendations. I believe them to properly reflect the value of the asset.
The subject vehicle is not worthy of proper restoration.
Anybody buying it would be cognitively doing so at their own risk. ( It's an old car!) So where's the moral dilemma?
My recommendations are an option not a directive.
11/11/2011 7:18 AM
Possibly an immoral option......so why even post it? You are not now going to tell me that you intended for Del to fully inform the buyer..........that I will never believe.
If Del takes the head off as he proposes and sees that its a lot of work, he will probably find a buyer, happy to be fully aware of the exact problems, Del might just then still get rid of it for a not unreasonable price (2nd hand price minus repair costs and time etc.).......if not, scrapping is the only moral way to go.....
Near where I live, there are people/small companies, who buy such cars for as low a price as possible and do them up and sell them again.....if it still has an MOT certificate especially......
Anonymous Poster #2
11/11/2011 9:11 AM
"(It's an old car!)"
I thought he said it was a '98 model. That's not so old. Only about 13 years. Barely broken in, although it sounds like his has been thoroughly abused.
Now, I have an old car. I drive to work every day a 1968 Chevrolet pickup truck. It's only about 43 years old. Still runs great with the original engine. I just need to clean up some rust from the body.
11/11/2011 9:26 AM
Old car is a very relative term. If you like in a dry sunny climate it will last much longer than if you live on the coast. It also depends what type of milage and how many miles. Endless short city runs are a lot worse than motorway miles.
Also bear in mind that this is a small vehicle not a Sherman tank like you guys in the US drive.
It looks a bit like this ,although ironically this pic seems to be a USA one!
11/11/2011 9:35 AM
No dry sunny climate here! I live in Mobile, Alabama, USA, which is on the coast of the Gulf of Mexico. My house is within 15 miles of the Gulf, so the air is plenty salty. And we get around sixty-six inches of rain each year. I don't know how that compares to your location, but I'm told that is the most rain of any city in the continental US.
The mileage has been a mix of farm fields for the first 10 years, mostly highway there after, but mostly city for the last 10 years.
It comes down mostly to a matter of maintenance and taking care of the vehicle. Anyone (original post) who lets the radiator go dry, isn't taking care of their car. I'm sure there were lots of small warning signals long before the events related in the post, indicating a need for attention.
11/11/2011 10:43 AM
Yeah, but there was water in the header tank! So my Daughter didn't realise it was running low, or maybe the head gasket went and then the water dissappeared...we don't know the sequence of events.
Any how there can't be too many girls in UK who have changed clutches, drive shafts, main bearings and big ends on vehicles.
And you don't want to pick on my Daught...
Else she'll shoot yo a$$
11/11/2011 11:53 AM
Great training for the bust!!!
11/11/2011 9:38 AM
Well, here's a UK one.
Cannibalising two to make one good one, then disposing of the unwanted parts for spares, is also an option.
Ooooooh, look. It's got a happy face!
Good Answers: 179
11/11/2011 9:44 AM
Well I have an old car too.....it's 13 year old 1998 Dodge Avenger Sport with 153K on the odometer, but then again it's been pampered ever since I bought it new.....used Castrol Full Synthetic all along too and it runs like the day it was brand new. Hells bells, it even looks new inside and out, so why get rid of it? Especially when it has been paid off years ago, and still runs like a top?
Dell's daughter's Korean junker sounds like it's at the end of it's life cycle and possibly has been abused by the previous owner(s). At best it's probably a parts car (errrr, "Hanger Queen"????). Even though I didn't mention it before, but I'd worry about cylinder glazing and the possibility of a cracked block on top of the obvious head gasket failure.......
11/11/2011 9:50 AM
Another Synthetic fan!!! 'ain't it GREAT!!!
Good Answers: 179
11/11/2011 9:59 AM
Yeah, I love the stuff Andy!!!!
My kid brother, who is a Chem Eng. (with a MSME degree from Union College as well), works for Castrol/BP running their Racing Oil Testing Program & race sponsor program.....most notably sponsoring NHRA Funny Car driver John Force's team. He knows and deals with John all of the time.....a very sweet career, and well rewarding, if you ask me!
Good Answers: 62
11/11/2011 12:51 PM
Ah synthetic fans!
Question - do you still use the regular change cycle?
11/11/2011 1:07 PM
No, as I posted before, I double the mileage.
Good Answers: 62
11/11/2011 1:25 PM
Yet it is over double the cost?
Better be something I'm keeping forever.
11/11/2011 3:57 PM
Not here!!! Esoecially since I buy Longlife III for only about $30 for 5 Liter canister on ebay......
Look here:-
http://www.ebay.de/itm/5W30-Longlife-III-3-VW-504-507-5W-30-MB-229-51-5-Liter-/160555979955?pt=Autopflege_Wartung&hash=item2561e1d4b3
The saving of an oil filter must also be calculated in as well.
I tend to keep my cars for a long time, the fact that I can drive 500,000 possible miles or more without an engine repair or replacement is difficult to calculate........
I also feel that the fact that I am not having to properly "get rid" of double the amount of old oil and filters, should also be taken into account in some manner.....
I look more on the longterm, many don't. We are lucky here to have several very cheap suppliers of high quality Synthetic oil......Pennasol is just one of them......
Good Answers: 62
11/11/2011 4:01 PM
Thanks for the information!
Been wanting to talk to a synthetic user - should have guessed you
11/11/2011 4:07 PM
You need to drive a car for a lot of miles to get a feel for Synthetic.
I have been using it since 1990 on all my private & company cars, but since 2001, it is a requirement for all VW Diesel engines at least.....
Good Answers: 179
11/11/2011 6:51 PM
I typically pay around $28~29 for 5 Quart jug of the Castrol Full Synthetic Extended Mileage oil (Gold color jug) at Walmart, which is a very good price, and better than what I can find on Ebay + s/h costs. I also get the extended mileage Gram oil filter there too, but I don't remember the cost, though it is a tad pricier than the standard Fram filter. It's worth every penny IMO.
All-in-all, going with this type oil and filter I don't have to change the oil so much.....3k~6k mile intervals is a joke, a waste of good oil, and detrimental to the environment....and since I do my own oil change work it's less of a hassle too, especially in the winter months!
Good Answers: 62
11/11/2011 7:10 PM
Not much more than the Delo 400 I poured in my diesel
11/12/2011 4:10 AM
You are so right!!
Is that a synthetic oil that you mention?( I have not see it here)
We are lucky in Germany in having several good small manufacturers of Synthetic oil, that sell well under the price tabs that the big "Multis" want.......
Good Answers: 62
11/13/2011 10:01 PM
Sorry, no
It is one of the old school lubricants for diesels
In reply to #59
11/14/2011 12:04 PM
ESPECIALLY for Diesels, Full Synthetic is the best choice there is, simply double the mileage before changing the oil and the filter.....
I feel strong enough to say that the worst true synthetic is still better than the best conventional oil.....but you will never know it till you have tried it....
Also it means less old oil to dispose of.......
What anyone who has no trust in Synthetic must do is take an old pan, preferably aluminium, put a few drops of conventional oil on one side and a few drops of synthetic on the other.....heat and watch. That is why any engine with an air cooled Turbo should have Synthetic.....
I would guess, but for an engine that is still in good condition, a change to SO could easily more than double the expected life span......
The only two drawbacks that I know of (price evens itself out with double the mileage and half the number of filters and less maintenance costs if you let a shop do the work) are:-
1) that its not good (I am told) for old air cooled Beetle engines (no proper filter, only a strainer........perhaps if there was a proper filter system it would be OK.
2) The engines run in far slower than on conventional oil. All the Diesel engines I have had since first using Synthetic are still reducing their oil consumption at well over 100,000 KMs. Though even at 0 KMs, the oil consumption is way below expected......
In my present engine, with trailer work, I am running between 0.5 and 1.00 liters of oil in around 30,000 KMs. That is typical. Oil consumption never goes completely to zero as in some older good engines with conventional oils, probably its too thin to have NOTHING burnt in use....
Due to it's fluidity at all temperatures, it reaches all parts of an engine at a very high speed at the start!!! Which also helps to reduce wear and tear...... I use 0-30 SAE in my Diesel engine from VW. Its a requirement.
Good Answers: 179
11/11/2011 2:19 PM
My answer is no.......I typically drive major highways (90% of the time), so I can change the Castrol Full syn oil (the "extended use" oil in a Gold gallon jug) typically between 12,000 and 15,000 miles. Oil has always bee fairly clear and clean when I drain it....Also, I'm religious about changing the Fram extended use oil filter every time I change the oil.
11/11/2011 6:08 AM
How about sending a well-known on-line auction website to the rescue?
(A recently-disposed-of Vauxhall Vectra with a similar problem raised £610 GBP!)
11/11/2011 7:19 AM
GA
11/11/2011 6:21 AM
I've advised my Daughter to consider it a write off and sort out another vehicle. We can then have a go at it at our leisure.
Problem is I haven't got a covered workshop (it's full of my bow making stuff) and I've got a stinking cold so I'm not really up to working on it at the moment (don't really want to leave it with water in there, but I just cant face getting under and draing oil and water. Daught is V busy at the mo' and she'd want to do it with me supermavising.
If we can have a look at our leisure then maybe it can be sorted and at least sold as a runner.
If I had decent facilities (and was 20 years younger...but then I'd be working) I wouldn't mind spending the time refurbishing it to a decent condition, but to be honest it's pretty tired, although over the years it's been a good work horse.
11/11/2011 6:30 AM
Hey Del, i may not be British but i do know that an M25 is a 25mm bolt and a circular junction is also known as a flange. But i must admit the Waterworks Roundabout and Epping does sound rather like an embarasing medical problem.
11/11/2011 7:20 AM
Ha Ha Ha.......very good.......
11/11/2011 7:51 AM
It's a good job it didn't conk out in Dorking, Nempnett Thrubwell or Six Mile Bottom, then!
Good Answers: 102
11/11/2011 7:03 AM
Don't leave this for too long.
No need to drain the oil mate.
Have you got any Araldite?
Hope you get over your cold soon.
11/11/2011 7:04 AM
Ok
Ok
Yes
Cheers
11/11/2011 7:15 AM
After reading this thread, I see that I won't understand anybody when the misses and I go to York next June!!
rrnut-2
11/11/2011 7:58 AM
If York is bad, try Gateshead, Hartlepool or Middlesbrough.
Good Answers: 179
11/11/2011 8:54 AM
Like others that have previously posted, I would if in your shoes:
1. find a new replacement vehicle.
2. If it's too cold outside now you can always wait until next spring (when it warms up, if that's even possible in the UK? LOL) to work on the engine. Appears to be a bad head gasket IMO. If the head is aluminum there's a strong possibility that it is warped and require some machining to bring it back to specification. Once fixed, your daughter can use it as a back-up vehicle, or sell it outright.....you will get more $$$ back selling it fixed versus a broken car.
No mention how many Km are on the odometer. Km? But if you say it's getting tired, get rid of it anyway....it's 13+ years old, right? Keeping it is going to cost your daughter more and more UK Pounds year after year, so put money into a new car payment instead as well as receiving a piece of mind (relative to cost of diminishing returns and reliability......your daughter will be driving a brand new vehicle with many more safety features than the old junker.....and cars have grown much much more safer in the intervening 13 years.)
ps: Epping Forest....a new place for Del to play with his bows! Let's go hunting (poaching?) for little bunny Whabbits!!! hehehehe Ohhh Gosh, how I love those old Bugs Bunny & Elmer Fudd Loony Tunes!
11/11/2011 9:45 AM
I have to agree with your post.
But if he waits till next year before repairing, the bores will be too far gone with rust. He must at least take the head off and spray the bores with a lot of WD-40 or simiar to make sure that no rust starts. Check and turn the motor occasionally.....
Thick grease and occasionally turning the motor by hand to check will achieve the same result.....
Good Answers: 110
11/11/2011 9:58 AM
I say make a mechanic out of your daughter! (But that's only so you can share in my misery of making a mechanic out of my son.)
I gave my son my old 1990 Daihatsu quite a while back. Eventually, the oil pump failed, and we decided to fix it, requiring a crank regrind, a connecting rod or two, etc, etc. In the US, parts are not generally available, so getting parts, used and new, required looking all over the world. It also involved funny stories of parts hand-carried on an airliner from Australia.
The dam thing runs now (after only who knows how much time with parts scattered all over both bays of the garage and outside, all my tools being impossible to locate for the duration, -- a year? -- etc, etc.)! He's not driving it yet because the ignition timing is not quite right (he missed by one tooth on the distributor drive) and the 15 minute timing job seems to have stretched on for months.
But it runs... and he did essentially all the work himself. Another car was essential in the interim, of course.
Oh... re your kids car: I'd say there is a better than 50% chance that planing the head and regasketing will do the trick. There are some crack checking products that will show up cracks in cylinders pretty well Zyglo (I think) being one.
Think big. Drive small.
11/11/2011 10:55 AM
Indeed! She's done a fair bit already, changed a clutch, dropped out a crankshaft and fitted new mains & big ends, had a head off, changed drive shafts on some of her old cars.
All with a bit of cattly supervision of course.
Good Answers: 179
11/11/2011 11:03 AM
Good going Del for training your youngster very well in regard to automechanics!
At least she won't be snookered by some future garage mechanic once you've retired and moved away to sunny Catropolis (wherever that may be located?)!!!!!
[Man, she can really stretch that Long Bow......must be a Brit thing.....anyhow I'd hate to be on the receiving end of Cupid's Arrow!! Hope she's landed a boyfriend before taking up archery as a passtime!!!!! LOL]
Good Answers: 12
11/11/2011 12:04 PM
A few tricks that I used when working on MG's, Austins, Morris Minors & the like when working at BMC dealership as a mechanic. [I replaced a lot of these: AUD9096, AUF206] Back then, grind valves every 15k to 30k miles & o'haul engine at 60k.
If no oil in water, good chance only head gasket and not cracked.
Pull the head and place it upside down. With valves closed fill with solvent. If it holds, valves are still seating.
Put solvent on top of pistons, if drains right away, rings are gone.
With a straight edge, check flatness of head and engine block.
If overhead cam and surfacing bottom of head, also remove cam towers and surface top side. Otherwise, cam will be bowed and brake in short order.
Good Answers: 62
11/11/2011 12:57 PM
And getting back to your aside - I do love good tow equipment!
So much better than running the chain through a pipe
11/13/2011 10:02 PM
Del,
You won't know for sure until the head is off, it doesn't sound good, but no water in the oil is a good sign, and the engine didn't seize, that also is a good sign - perhaps she stopped before any real damage was done.
Unbolt the head in gentle stages starting with the middle bolts, working towards both ends in accordance with the manual to minimise any additional warping.
good luck
In reply to #60
11/13/2011 10:14 PM
WAIT A MINUTE!
I believe the manual would tell you to start on the ends and work to the middle to remove the head.
Check first.
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
11/13/2011 10:16 PM
Last time I did a head casket it was...
Remove from the Centre and Install from the ends....
May be specific to engine.??
Definately worth checking the manual.
Regards,
Sapper
It's all about the Boom! - MythBusters
11/13/2011 10:31 PM
"Last time I did a head casket it was"
You did a casket for a head? I'd just take it to the tip. That's Britspeak for dump, I think.
Ok, it's probably a lot more critical on manifolds than heads. But still, I'd consult a manual, first.
In reply to #63
11/13/2011 10:50 PM
Meant Gasket....
Must be that fat finger syndrome....or listdexia
Regards,
Sapper
In reply to #63
11/14/2011 12:11 PM
People from Oz, don't do "Britspeak" unless they were born and lived in the UK before emigrating.......
The people in Oz call Brits "Piles", "they are a pain in the arse and they won't go back"
11/13/2011 11:09 PM
Mine says remove and instal from the centre in gentle stages, ie don't bring the centre to full torque with the ends loose....
11/14/2011 12:07 PM
It depends upon which side of the bed the manual author got out of when he wrote the method!!!
In my experience, its the tightening procedure that is most important.....
Good Answers: 123
11/14/2011 1:09 PM
Only south of the equator.
Bob
Good Answers: 123
11/14/2011 1:16 PM
How about some cheap easy tests? Start by re-torquing the head bolts, and see if it will now hold water in the cooling passages. Leave the spark plugs out and try pressurizing the cooling system. Then spin it over and again look for water coming out of the plug holes. If you are as lucky as me, it will hold again.
If not, you can buy some time by filling the cylinders up with a mix of engine oil and diesel. Then reinstall the spark plugs and let it sit.
If she is set on a replacement car, there should be some affordable Chevy Cavaliers available.
Good luck my friend.
Bob
In reply to #70
11/14/2011 5:30 PM
Yeah, I'm going to drain the water and get some oil into the bores then leave it until I (and Daught') have some free time to hasve a play.
Good Answers: 110
In reply to #70
11/21/2011 11:13 AM
I fear that Del does not have ready access to Cavaliers, but perhaps there is a Vauxhall with similar characteristics. If not, then having a Cavalier air freighted over would be a good bet. That may sound extreme, but the freight bill will be balanced against immense owner satisfaction.
As we all know, a simple search on Cavalier on this sight shows that the Cavalier is the single most popular car with astute engineering types. Mercedes, a brand once though to be particularly well-engineered, doesn't even come close to having the number of enthusiastic posts that show up for the Cavalier.
The Cavalier is a car than can provide its owner with the sort of joy that comes from putting together a really complicated jig-saw puzzle.
In reply to #73
11/21/2011 11:26 AM
My current wheels comes with insanity inducing 'intellikey' system which won't let you lock the car because it thinks you haven't turned off the ignition, put on the handbrake, put it in Park, opened and closed the doors in the right order or with the right hand or eaten your 5 portions of fruit, or whatever takes it's fancy.
Good Answers: 62
In reply to #74
11/22/2011 12:34 AM
Had a friend whose intelligent dongle went in the swimming pool.
Seats, mirrors, radio settings wouldn't even stay where you left em.
$500 to replace and reprogram damned thing.
Good Answers: 123
In reply to #75
11/22/2011 7:30 AM
Del won't have to worry about that if he scoops up one of those fine Cavaliers. Heck, for $500 he could probably replace it with another one. Next thing you know, he will have a whole flock of Cavaliers there. Good day mate.
Bob
Good Answers: 123
In reply to #76
11/22/2011 7:32 AM
When you get to seven of them, you can label them: Monday, Tuesday...
Bob
Good Answers: 19
In reply to #77
11/22/2011 8:44 AM
That would be for which one gets repaired on that particular day!
Time for a cup of coffee.
Good Answers: 123
In reply to #78
11/22/2011 8:52 AM
No, of course not. It would be for which one needed to be pushed that day. Just like rotating stock on the grocery store shelves.
Perhaps he could paint holiday greetings on different Cavaliers, and use them as lawn displays. Thanksgiving this month.(come on Del, just humor us). Christmas next month. Followed by New Years, then Ground Hogs day. Hell, he can just let his imagination run wild with the freedom.
Bob
In reply to #79
11/22/2011 9:03 AM
I don't have a front lawn...
The old Hyundai is parked in front of the garage... maybe if we decide to scrap it I could shoot a few arrows into the doors.
Good Answers: 123
#81
In reply to #80
11/22/2011 9:27 AM
You better get it moved soon. I have 2 Cavaliers on the way.
Oh, I forgot to tell you, the Renault Fuego is gone. I'm sorry, if I had only known, I would have given you a better deal than I offered it to Lyn for. (Just don't tell him)
Bob
In reply to #81
11/22/2011 9:39 AM
I always thought the Fuego was quite pretty... not to mention the Matra Simca Bagheera.
11/21/2011 9:05 AM
If the water is in ALL the bores, it may not be the head gasket, it may be a hole in the intake manifold which is on some engines has coolant running through it.
I'm not familiar with the Acceut bnt engine but if this is it that aluminum fuel intake 'bottle' looks suspect. Just can't see the backside of it to tell if it has coolant connections.
Register to Reply 82 comments
129CBRider (1); Andy Germany (14); Anonymous Poster (3); bob c (6); CaptMoosie (6); Doorman (2); edignan (9); JIMRAT (1); K_Fry (2); KJK/USA (1); lyn (4); Mike Davis (1); mrehmus (1); ozzb (1); PWSlack (4); Relativity PL (1); Ried (2); rrnut-2 (1); Sapper (2); Snave (1); SolarEagle (1); Tobugrynbak (1); user-deleted-1105 (11); Wal (4); WAWAUS (2)
