Previous in Forum: General Relativistic Blue-Shifting for Observer on Relativistic Velocity Body   Next in Forum: Visualizing 'Past Light Cones' in 'Closed' Space-Time?
32 comments
Ceiling Fan with Vaulted Ceiling
12/04/2011 8:42 PM
Ok I knew ceiling fans went in different directions in different seasons but I did not know about the ceiling height making a difference. So I guess I am wanting to make sure I understand all of this correctly. In the summer and when the ceilings are over 8 feet (in the winter), it runs counter-clockwise (blades up leading), and in the winter it runs clockwise (low blade leading), correct? But does it matter if the fan is hangs down a ways (at probably a little higher than 8 feet) from the vaulted ceiling (not snug with ceiling like a lot of fans)? So, should it then still follow that rule of going counter-clockwise?
Re: Ceiling Fan with Vaulted Ceiling
12/04/2011 9:10 PM
It really doesn't matter, it's a matter of personal preference...The speeds and direction can be in any combination at any time according to personal comfort...
Good Answers: 62
12/04/2011 9:47 PM
Nominally think in terms of circulation doughnut between the center of the room and the walls, so I usually leave it run with the airflow upward in center of the room. Less perceptible.
If you want to run the room warmer you can reverse it so you get some evaporative effect off your skin.
12/04/2011 10:24 PM
It depends mainly on where your furniture is located. If the furniture is along the walls then having the fan run in 'reverse' where it lifts the air upward means than it will create a downward flow along the walls and over the furniture, which you might want in the summer but not in the winter. On the other hand, if the ceiling fan is over your bed then maybe you do want to run it in 'reverse' in the winter time to avoid having a cold breeze on the bed. (Or not run it at all in the winter.)
12/04/2011 10:55 PM
Tomayto tomahto is what I suspect, but simply try out both directions and see which seems better.
12/05/2011 3:43 AM
So it has nothing to do with the Coriolis Effect, then? How strange.
12/05/2011 4:02 AM
You seem to be forgetting that fan blades for the Southern Hemisphere are built to the opposite hand. This gains about 0.001% in fan efficiency, which a clever designer would surely not overlook.
12/05/2011 9:04 AM
are you really serious? which direction does the toilet water spin at your house?
come on tornado, i'm starting to lose respect.
12/05/2011 11:23 AM
I would assign more value the blades being right-hand or left-hand pitch than I would assign to the water in someone's toilet bowl. This more or less defined factor will determine suck or blow on blade rotation... as has been said, I doubt it makes enough difference to to be of any significance in this case.
12/05/2011 4:58 PM
Vaulted ceilings seem nice, but they just amount to wasted space that collects heat in the summer and winter.
I would run the fan on low or medium in the winter, (either direction), to move the heated air back down into the room where you can feel it. I wouldn't run it at all in the summer, since there's no reason to cool an area that you won't be occupying.
I intentionally looked for a house with 8' ceilings throughout. They may be passe, but heating and cooling is far more efficient.
12/05/2011 11:02 PM
For summer ceiling fans work on the principal that moving air will evaporate moisture from your skin and hence cool you, this works best if you are under the fan, and the air is blowing down onto you.
For winter the hotter air that is trapped against the ceiling needs to be forced down to floor level, this is best done by forcing the air up and then down the walls and across the floor to where you are. This eliminates the cooling effect if you were to keep it in the summer mode, as above.
Try both ways and see which you prefer.
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
12/06/2011 5:34 AM
I went to look at a new build house recently - all ceilings lower than 8' - one floor had 7'4" ceilings.
Chaos always wins because it's better organised.
12/06/2011 5:53 AM
Was this in the Shire, perchance?
Good Answers: 75
12/07/2011 4:04 AM
ROFLMAO!
Nope, a 3 storey, 5 bed house in a rural county city. Oh hang on, it's in *******shire....
12/05/2011 11:00 PM
Ceiling fans should only be used when the room is occupied, in the summer,they should blow air down, creating evaporative cooling on the skin of the occupants.
During the winter they should move room air upwards to the ceiling,then down the walls to the floor,this moves the warmer air that rises ,back into the air that is occupied by people,increasing their comfort.
Running ceiling fans is solely to improve comfort of the occupants, at a higher set point in summer ,and a lower one in the winter.
12/06/2011 12:47 AM
The one thing you need to be careful of is if the blades are just above your head. This matters more in the bedroom. A friend of mine playing a joke (I think) jumped into the blades, knocked himself out, but before he did this, he tied his wife to the bed. Made for an extremely uncomfortable situation when the neighbor had to break in to their house and take care of the situation. We live in the sticks and not close to my friend who has since moved on. Watch the height of the blades and do not jump up for any reason near a ceiling fan.
"Real Bass Players" do not use picks
12/06/2011 1:17 AM
"to my friend who has since moved on"
Must have been some ceiling fan!
Another thing to watch is that the fan has good clearance to the ceiling - say one blade length or more. But clearance above head is more important, of course.
If roof / ceiling does not have good insulation, a floor fan may be better in summer than a ceiling fan - leave the heat up there.
Most effective & most cost effective roof / ceiling insulation for tropics is the reflective stuff - up to 97% effective. Usually feels like free air conditioning, no running costs.
Floss or die!
Good Answers: 11
12/06/2011 10:06 AM
Good point, Stuart! This is why old homes had 12' ceilings. Before air conditioning, the idea was to allow the hot air to rise above the heads of the occupants. It makes no sense to pull the hot air down in the summertime. The cooling effect of a fan is created through evaporation due to the movement of air over the perspiring skin. I wonder, though, if even a floor fan would create currents causing the hot air above to be drawn into the circulation of air in the room. Any thoughts?
12/06/2011 11:32 AM
Specifier asked "I wonder, though, if even a floor fan would create currents causing the hot air above to be drawn into the circulation of air in the room. Any thoughts?"
To a certain extent yes, but still considerably less than with a ceiling fan.
Something else re the winter / summer thing is that a turbulent breeze (i.e. direct impingement - blowing 'down') has a greater cooling effect than a steady breeze (blowing 'up', with cooling by donut effect)
Floss or die!
12/06/2011 1:25 AM
CR4 Admin: Vulgar/Rude/Improper Behavior: This post was deleted because it did not adhere to the behavioral policies of the site. Please review Section 14 of the CR4 Site FAQ and the Rules of Conduct.
Good Answers: 62
12/06/2011 8:56 AM
Enough of that now!
Why would anyone repeat a bad joke, much less a racist bad joke - oops I repeat myself
Everyone move along - nothing to see here!
Good Answers: 179
12/06/2011 8:12 AM
Now, that's a good one! Some serious m**fdiving going on there!!! LOL
Pray tell, did the neighbor take pics? hehehehhehe
12/06/2011 6:29 AM
I was thinking, with a relatively low ceiling and therefore a relatively high mounted fan, it might be better to have the fan blades set to vertical, so that they push the air sideways out to the edges of the room, instead of pushing it up at the near ceiling, stopping the warm air gathering up near the ceiling in winter.
Some years ago, while working on the ceiling in my bathroom, I was horrified at just how much warm air was gathered in the last top foot of air, it was almost too hot to be comfortable......it spurred me onto only use LED and CFLs in my house......
12/06/2011 8:02 AM
That's kind of the point I was trying to make in my OT post. I've spent a lot of time up in these ceiling areas...............................it gets really hot. In the summer, I would leave the ceiling fan off, leave the hot air up there alone, and use a simple box/rotating fan at floor level to move the air, if needed.
I'll go ahead and mark myself OT on this one.
You can lead a horse to water...........................................
Good Answers: 58
12/06/2011 9:03 AM
I have a one and a half story vaulted ceiling over my living room and dinning room areas.
Four years ago I installed a "Big Ass Fan" up top.
No seriously....................it's a "Big Ass Fan" manufactured by "Big Ass Fans"
My Big Ass Fan is similar to this one:
I run it blowing up at its lowest speed during the winter. I have found that the warm air blowing down the walls makes the area feel warmer during the winter.
During the summer I run it blowing down at the lowest speed. The upstairs loft/bedroom share this space, this being why I blow the hot air down. It does actually keep the loft area cooler during the summer.
I have tried running my Big Ass Fan at high speed but the air flow tends to blow things about the room that weigh less than 2 pounds.
I love my Big Ass Fan!
12/06/2011 12:20 PM
Its really the top of a Helicopter......upside down of course.....
Good Answers: 58
12/06/2011 12:25 PM
12/06/2011 9:07 AM
I'm surprised no one quoted any energy savings figures...
This is the info I send customers who ask the same question.
12/06/2011 2:49 PM
In the southern part of the US, many of those old houses with the 12' ceilings also had tall windows that opened at the bottom and the top. The middle part of the window was fixed. The top, opening, part of the window was so high that they had to be operated with some kind of hook or pole to unlock and open them. The bottom opening portion of the window was closer to the floor than is normal today. With both top and bottom windows open the stratification of the air in the room promoted a circulation of the air. Of course, they were open in the summer to let the heat out. The windows were closed top and bottom in the winter but the tall ceilings made heating the rooms very difficult.
I think that ceiling fans were invented to take advantage of the stratification of the air in these tall rooms. In the winter the fan could pull the hotter air straight down from the ceiling to the people in the room, avoiding the colder air next to the cold walls. In the summer the fan would bring the cooler room air up to displace the hotter air close to the ceiling and hopefully push the hot air toward the open top windows and out of the room. At the same time it would help draw cooler air in the bottom open windows.
I'm not sure that they make as much sense in 8' ceilings, where my head reaches into the top 2' of air. I still have them installed in my house, because the ceiling is a convenient place to mount a fan that you use a lot of the time.
It gets interesting when you put fuel and oxygen in the same molecule, without allowing them to react, YET!
Good Answers: 19
12/06/2011 4:39 PM
Any air blowing directly on you, even from a ceiling fan mounted to a vaulted ceiling with hot air, is going to feel cooler than the actual ambient temperature as it mixes with the cooler air before it reaches your skin. Then cooling you down.
It is best to create a gentle breeze up towards the ceiling and then down the wall to mix with the cooler walls and windows making the area feel warmer, as the warmer air will be attracted to the cooler air as is passes down the wall back to the center of the room.
This will result in blending with the warmer supply air and then begining its convection cycle once again in the room.
12/06/2011 5:38 PM
In addition to replies #1 and #11
12/06/2011 7:11 PM
Air blowing down in the summer, up in the the winter. Maybe down in the winter for a very high fan,in a two story open structure,for a typical vaulted ceiling, blowing up in the winter.
12/08/2011 5:48 AM
I think that if the fan is close to the ceiling, it will be more efficient moving air downward. The movement of air behind a fan is not the reverse of the air movement in front. Put your hand behind a fan and you feel a little breeze, but nowhere as much as in front. The fan is fed from air in all directions from the rear. From an efficiency standpoint, the ceiling obstructs the air flow much more if the fan is blowing upward.
Register to Reply 32 comments
Andy Germany (2); bayareacool (2); CaptMoosie (1); Doorman (1); durtieduck (1); edignan (2); English Rose (2); Haajee (1); Jimh77 (1); KJK/USA (2); kramarat (2); Lapin (1); PWSlack (1); Rainbow Spirit (1); Rixter (1); Simon Magnus (1); SolarEagle (1); specifier (1); Stedou73ish (1); Stuart21 (2); Tornado (4); Usbport (1)
