Previous in Forum: Lead Acid Batteries   Next in Forum: Design of Earthing for Power Plant
Query
12/10/2011 1:59 AM
I want to know how the neutral is shifted due to the unbalance and what is it's effect?
Re: query
12/10/2011 2:18 AM
This might help...
"The advantage of this approach will be to minimize
bearing currents and leakage currents to ground."
http://enjeti.tamu.edu/journal-papers/neutral-shift.pdf
Re: query
12/10/2011 3:16 AM
It alters the shape of the "phasor diagram" according to whichever element is "in control"; but then all the lengths and angles are still correct.
Good Answers: 170
Re: query
12/10/2011 5:26 AM
Do you or can you understand vector algebra? If yes, then I will answer your question.
Re: query
12/10/2011 6:39 AM
Some time I wonder
2 is easier to type ot 'to'
especially since after 'want, ' to' already has the 't' common.
Register to Reply Off Topic (Score 8)
Re: Query
12/12/2011 3:23 AM
The neutral is there to carry the imbalance current. Its voltage will differ from the earth voltage by the current multiplied by its resistance - assuming an IT earthing system is not present.
Anonymous Poster (1); electricalexpert65 (1); PWSlack (1); SolarEagle (1); Tornado (1)
