Previous in Forum: Books for Learning and Practicing Profibus DP in Industry Field   Next in Forum: Diff - Directional and Non Directional Current
11 comments
Which One is Best Correct Battery Symbol?
12/20/2011 11:34 PM
Can anyone tell which one is the correct symbol according to the connections shown?
"Two heads are better than one"
Re: Which one is best correct Battery Symbol?
12/21/2011 12:03 AM
2.
12/21/2011 12:16 AM
12/21/2011 12:41 AM
12/21/2011 12:21 AM
A. Chelladulral; #1 is 2 cells, #2 is a battery, usually the longer line is positive. perry
India - Member - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
Location: Chennapattanam (Coromandel Coast of the Bay of Bengal).
12/21/2011 1:48 AM
Symbol 1: A cell has two ends, labelled + (positive) and - (negative).
Symbol 2:A cell pushes the electric current from the positive terminal round to the negative one. This is the way that conventional current flows.
Two or more cells can be connected end-to-end to make a battery. A typical cell has a voltage of 1.5 volts (we write this as 1.5 V). By connecting cells in series, we can makes batteries with 3 V, 6 V and so on.
Good Answers: 22
Re: Which One is Best Correct Battery Symbol?
12/21/2011 11:58 PM
The symbol-1 depicts a battery with two cells connected in series and thus is more specific. The symbol-2 depicts a battery in more general terms - having more than one cell, connected either in series or parallel.
Raghunath
12/22/2011 5:11 AM
I've always seen and used #2.
12/22/2011 7:12 AM
Always seen and used 2.
Johannes
Good Answers: 18
12/22/2011 9:46 AM
2).
The most valuable of all talents is that of never using two words when one will do. ~Thomas Jefferson
12/22/2011 5:58 PM
Never seen #1. Always seen and used #2. Never noticed an accurate correlation between the number of repeats on the drawing and the voltage, needed a note to be precise. -- JHF
Good Answers: 12
12/23/2011 1:04 AM
I would assume that 1 is two independent cells while 2 is a single battery of two or more cells.
Bill
Register to Reply 11 comments
Circuit Breaker (1); EElectrician (1); Johannescnc (1); mandi (1); perry (1); raghun (1); Rixter (1); Sciesis2 (1); SolarEagle (2); Tornado (1)
