Previous in Forum: Eddy Current on Large Threaded Subjects   Next in Forum: Difference Between L, M, and H Type Vented NiCd Cells
18 comments
Power Factor
01/05/2012 5:28 AM
my meter is showing value of power factor 1.3, what it mean
Re: power factor
01/05/2012 5:30 AM
It's fu.... kna...... faulty.
Re: power factor
01/05/2012 5:34 AM
sir,
is it possible that value of pf>1 if yes then in which conditions.
Help me
Re: power factor
01/05/2012 5:56 AM
Can a cosine exceed 1.0 (rhetorical question)?
Re: power factor
01/05/2012 6:33 AM
how can judge to leading or legging power factor by it's numerical value.
Re: power factor
01/05/2012 7:10 AM
It is invariably lagging, though a value of 1.3 is just silly.
India - Member - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
Location: Chennapattanam (Coromandel Coast of the Bay of Bengal).
Re: power factor
01/05/2012 5:51 AM
Power factor is the ratio of real power to the apparent power. If it exceeds 1 the real power will become greater than the apparent power its an abnormal condition in general practice......however some cases......http://www.cumminspower.com/www/literature/technicalpapers/PT-6001-ImpactofPowerFactorLoads-en.pdf
Good Answers: 164
Re: power factor
01/06/2012 3:08 AM
Dear mandi,
....abnormal condition in general practice......however some cases......
This implies that in some cases the PF can be > 1 ??? Do you mean that ??? i am sure i must have misunderstood you....
Re: power factor
01/06/2012 7:08 AM
Dear Guru kvsridhar
Never PF > 1 .....apologies for typing wrong
Good Answers: 164
Re: power factor
01/06/2012 7:13 AM
Ahh .. thank you. i was sure you didn't mean that, just that it was open to being misunderstood... hope you did not get offended, sorry anyway
Re: power factor
01/05/2012 5:54 AM
It does not mean anything...get it fixed
Good Answers: 170
Re: power factor
01/05/2012 6:51 AM
It just means only one thing! Change the meter immediately.
Re: power factor
01/05/2012 6:56 AM
Somebody painted bogus numbers on the dial.
Re: power factor
01/05/2012 8:29 AM
You've got your meter set for the wrong hemisphere. Somewhere, there's a switch marked "N" and "S". Change it to the other position and the meter will read correctly.
Re: Power Factor
01/05/2012 10:16 AM
It means that one or two of your CTs is connected backwards.
Anonymous Poster #2
Re: Power Factor
01/05/2012 12:39 PM
Great achievement, Where is the party?
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
Re: Power Factor
01/05/2012 4:14 PM
If its a digital meter, Its Faulty...get it replaced.
If it an analog meter, you have the wrong meter in place, PF meters are marked Lead\Lag with 1 being the centre point...so get it replaced.
Regards,
Sapper
It's all about the Boom! - MythBusters
Good Answers: 44
Re: Power Factor
01/06/2012 12:58 PM
What? Where? I want one!!!
Re: Power Factor
01/09/2012 1:10 PM
i m sure its digital type.. analog ones don't have a reading scale > 1.
get it rectified..
Register to Reply 18 comments
Anonymous Poster (2); cuba_pete (1); electricalexpert65 (1); gaurav.glory (2); harjeetsinghengg (1); kvsridhar (2); lyn (1); mandi (2); muditmah (1); PWSlack (3); Sapper (1); Tornado (1)
