Previous in Forum: MCCB   Next in Forum: Electrical Motor
10 comments
Borehole Pump Installation
01/14/2012 8:16 AM
We have recently drilled a 200m deep borehole which produces 7 cubic metres of water per hour. Now we need to install pump and electic controls. We invited several companies to quote for the job. Trouble is that each is quoting for different items. Eg one quote for 6mm submissible cable while others qoute fo 4mm. Is there a way of finding what pump size is needed, the motor required to drive it and the cable size necessary etc
Re: Borehole pump installation
01/14/2012 8:56 AM
At some point you will need to find out what the water level is while you are actually pumping it. For example, imagine that the static level is 150m deep, but while pumping it is 175m deep. This means that you are pumping 7m3/h to a height of 175m. From that you can calculate the hp or kw of the pump.
Next you need to know the motor voltage, which then enables you to determine the current required. This in turn enables the cable size to be selected, which will be a certain minimum amount to handle the current. Finally, because the cable run is rather long, you may need to increase the cable size in order to minimize voltage drop. Cables are usually sized by mm2 rather than just mm, but conversion is easy.
01/14/2012 10:56 AM
The water rest level is 140m.
the voltage either 415v 3 phase or 240v single phase
01/14/2012 11:19 AM
Okayy.... That answers one question among several.
01/16/2012 3:28 AM
Do keep British Standard 7671 handy. It will be needed....
Re: Borehole Pump Installation
01/15/2012 2:03 AM
For what kind of duty do you require the pump?. Is it for short time to fill a tank(s) or bowsers or to continuously operate 24/7 for sprinkler irrigation called centre pivot system?. You must pump water out till level goes very low and measure well production(how long it takes for the water to comeback to -or near- the original level). Based on that you should decide Q.His known to you,so write to manufacturer.
pnaban
Good Answers: 102
01/15/2012 2:03 AM
What size motor were these disparate quotations offering?
Did the vendor who quoted a smaller size cable also offer a smaller motor?
Did the vendors offer any calculations with their proposals?
Make the vendors work harder for their money.
If you can calculate what is needed independently than you can vet the proposals confidently.
Pumping volume rate and head will determine your pump size. The pump size, operating voltage and cable length will determine the conductor size.
Re: Bore hole Pump Installation
01/15/2012 7:12 AM
  1. Do a prolonged and reliable pumping test.
  2. Determine water level at various flow rate.
  3. Get pump's mfg performance charts.
  4. From the charts determine number of stages required.
  5. Calculate power required based on your water level and flow rate and number of stages
  6. Get submersible pump cable specs.find Ampacity, take a good safety margin.
Your pump is relatively small. 4" multistage. if you have 3φ system USE it. Get the best pump you can afford and design it WELL. getting a pump from 150 meter deep is a pain in the butt...Hope it helps.Wangito.
Never trade luck for skill.
01/15/2012 10:16 AM
Don't forget to take water sample,measure its temperature at starting and after pumping for long time and get sample tested in a lab for anions,cations,pH,sand content,TDS, etc
and send to manufacturer with your quote request. For the pump installation there should be low level alarm,dry running protection,voltage monitor relay,thermistor relay etc
pnaban
Good Answers: 179
01/15/2012 4:08 PM
Here is a very good Link that you and every layman can follow regarding the development (design of pumps, yield testing, etc.) of your water well:
http://www1.agric.gov.ab.ca/$department/deptdocs.nsf/all/wwg408
Note: In order to obtain consistent quotations from the Contractors you will need to prepare some sort a Contract Documents and Bidding Forms (both of which are legally binding documents) that effectively (and exactly) spell out what is required from them regarding their price quotes. Make sure there is language within these documents that pints out that any bidding deviations from them could result in their bids being rejected by you, the Owner.
Honestly, I think you need to hire a local Licensed Civil Engineer to oversee this process, as well as to properly design and size the well pump, it's controls, etc., plus provide Construction Administration to verify conditions and to assure you that everything has been installed properly pursuant to the Contract Documents.
Water well construction is extremely expensive and you may want to hire a design professional to prevent undersizing/oversizing of the well pump. To do otherwise could potentially cost you a lot of money to rectify errors and omissions regarding the installation work. Also, it is extremely important that water well Yield Tests be performed. I can't stress that requirement enough!
01/15/2012 11:18 PM
Why did you recommend to hire a civil engineer for this?. An experienced(pumps/water supply) mechanical engineer should be considered.
pnaban
Register to Reply 10 comments
CaptMoosie (1); mbuthiam (1); pnaban (3); PWSlack (1); Tornado (2); Wal (1); wangito (1)
