Previous in Forum: Voltage Drop Problem.   Next in Forum: How To Make Simple AVR For Generator 1.5 kva 3 Phase
Rating Of Wire And Type Of Connection
04/25/2012 4:32 AM
hai engineers, i have used 7.5kw motor, for that i have connected a 4core 2.5sqmm cable in delta connection.... is this way is right or wrong....?
Re: Rating of wire and type of connection
04/25/2012 4:41 AM
British Standard 7671 gives the correct protocol for sizing on the basis of the installation method and parameters.
Re: Rating Of Wire And Type Of Connection
04/25/2012 10:29 AM
We would need to know the current draw of the motor (or the voltage so we could calculate the current.)
Good Answers: 19
04/27/2012 11:16 PM
You have not indicated whether copper or Aluminium cable.
If it is Aluminium cable,it would preferable to use minimum size of 6/10 sq.mm
I do not understand ,what is meant by DELTA.Is it Star delta starter ?please explain.
Ramesh,Freelance Electrical/automation Consultant
Register to Reply 3 comments
PWSlack (1); ramvinod (1); Tornado (1)
