Previous in Forum: Is There Restriction for Out Let Flow Path From Vertical Pump or Not?   Next in Forum: ASME Sec IX-QW 404.9
Lood Test
07/23/2012 7:50 AM
Hi All,
Need you help, how much load is required to carry out load testing.
Regard
Re: lood test
07/23/2012 8:43 AM
Load testing of what?
Good Answers: 48
Re: Lood Test
07/23/2012 8:46 AM
Loads & loads.
Good Answers: 137
Re: Lood Test
07/23/2012 11:49 AM
If you have no specific instructions or guidance, I would say something like 1.5 - 2 times the max load that will be seen in service.
Re: Lood Test
07/24/2012 6:03 PM
when personal safety factor, the load test rating should be "capacity x 5."
Good Answers: 19
Re: Lood Test
07/25/2012 4:02 AM
Very simple - as much load as you can carry.
Re: Lood Test
08/06/2012 1:40 PM
Load test of what?.. Jula or cranes or chain blocks or what?.. please clearly mention the item which is going to be load tested
Good Answers: 19
Re: Lood Test
08/06/2012 3:58 PM
His Brain.
Codemaster (1); ducon (2); durtieduck (1); Holzfeller (1); PWSlack (1); sivabalan (1)
