Previous in Forum: Modifying IF Bandwidth on a Radio   Next in Forum: Electrical-Motor Control Circuit
10 comments
Backup Time of UPS
07/24/2012 10:19 AM
Suppose I have two units of 10 kW single phase UPS with backup time of 30 minutes that supply two different loads:
- 5 kVA load with pf 0.8
- 5 kW load with pf 1
Which load will drain the ups faster?
Pathfinder Tags: UPS Backup Time
Re: Backup Time of UPS
07/24/2012 11:18 AM
Switch off the mains and measure it.
What do the original commissioning records say?
07/24/2012 11:37 AM
Er, wouldn't it depend upon the condition and state-of-charge of the batteries at the moment of mains disconnect? Are these batteries new or what?
07/24/2012 11:46 AM
And, are you powering both circuits at the same time?
07/24/2012 11:57 AM
...and is this 30min backup time governed by a pre-programmed timer within the UPS?
07/24/2012 12:23 PM
The second.
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
07/24/2012 5:39 PM
First up, If the 30min is due to software settings in the UPSs, they will both go offline at 30 mins.
Your first load is 5kVA X 0.8 = 4kW
Your second load is 5kVA X 1 = 5kW
Now that the values are the same, you should be able to work out which will drain first.
Regards,
Sapper
It's all about the Boom! - MythBusters
07/24/2012 11:02 PM
With voltage level of 220V
The second load will draw 5kW real power (I=22.72A)
The first load will draw 4kW real power (I=18.18A) + 3kVAr reactive load (I=13.63A) with the same magnitude of 22.72A.
My question is: does the 13.63 A of reactive load give different result compare to 4.54 A difference of the real power?
07/25/2012 6:32 AM
Well, it does rather depend on the resistance of the downstream cable:
  • Are all the connections tight?
  • Is it correctly sized?
Has the experiment been carried out yet?
07/25/2012 12:01 PM
Thank you all for the comments, but maybe I have to rephrase my question.
The rating of the UPS is 10kW/12.5kVA 30 minutes of backup time, that is equal to 6.25 kVAh.
Can I say that, with 5 kVA load, regardless of the pf, the backup time should be 1 hour and 15 minutes?
Good Answers: 110
07/25/2012 12:57 PM
I think this paper should clear up any confusion.
Think big. Drive small.
Register to Reply 10 comments
K_Fry (1); Local_Eng (2); lyn (1); PWSlack (4); Sapper (1); Tornado (1)
