Previous in Forum: Dampening Cable Vibration   Next in Forum: What Caused This Change?
Can Use Valve With U Seal?
08/02/2012 2:17 AM
my question is that can we use any type of valves with upstream or downstream of mechanical U seal for isolate u seal path?if we use or not please give reason.
Re: can use valve with u seal?
08/02/2012 3:20 AM
How about a ball valve or two?
Line size?
08/02/2012 4:42 AM
Oh, and - the usual - what is the process fluid, its temperature and pressure?
Good Answers: 97
08/02/2012 5:02 AM
By U seal do you mean U trap?
In a kitchen sink with a trap a plug is used upstream with good effect.
A downstream valve will be equivalent to a blockage and may cause the trapped material to rise to the sink as well.
Re: Can Use Valve With U Seal?
08/02/2012 12:02 PM
We call 'em P traps, here in the USA. And it isn't because of the fluid they transport.
Register to Reply 4 comments
Hendrik (1); lyn (1); PWSlack (2)
