Previous in Forum: 3 Phase Fan, Large Industrial Model, As Generator   Next in Forum: ESP Air Leak Test, Boiler Duct Air Leak Test
Steam Turbine Interlayer Heating
09/10/2012 7:37 AM
What is the specific purpose of inter layer heating during steam turbine rolling?Prewarming is just like flange heating as it is done in BHEL turbine.But interlayer heating is found in Dongfang (chinese) turbine.Please explain me.
Pathfinder Tags: STEAM TURBINE ROLLING
Re: steam turbine interlayer heating
09/10/2012 8:21 AM
Is the Operation Manual deficient in its description in some way? If so, how?
Good Answers: 19
Re: Steam Turbine Interlayer Heating
09/10/2012 11:00 AM
Why ask us and not contact Dongfang?
09/10/2012 2:09 PM
If ur plant is at commissioning stage u shud ask donfang ppl only. anyways interlayer heating is a significant phenomenon in cold rolling of turbine start up. here when u charge the HP-LP bypass systm ur outer casing temperature wud increase but inner casing will not increase as per required. so a tapping is taken from the MS line n given to the inner casing layer of turbine in order to warm the inner layer of casing. Also ensure tht ur MAl drains of turbine casing are full open before rolling.
"No matter how hard the past,you can always begin again."
Register to Reply 3 comments
ducon (1); PWSlack (1); vir540 (1)
