Previous in Forum: Blending Unit   Next in Forum: Solublity of Gas in Fuel
8 comments
Boiler Feed Pump
10/17/2012 7:40 AM
We have replaced the bearings bearing housing and lub oil as per OEM OF THE BFW pump.
But the still the thrust bearing tempreraure is high.
Can any one give any superior idea to get rid of that.
Pathfinder Tags: bfw
Good Answers: 34
Re: BOILER FEED PUMP
10/17/2012 7:54 AM
What is the temperature of the boiler feed water?
What is the temperature of the thrust bearing?
10/24/2012 5:07 AM
It is 125 deg c. c and the temp of thrust bearing is going as high as 98deg c.
Good Answers: 34
10/24/2012 5:31 AM
Water boils at 1000 C. Is it not apparent to you that boiler feed temperature is unduly high? Please read this:
The Feedtank and Feedwater Conditioning
10/17/2012 8:01 AM
How are bearings cooled? Separate electric pump or shaft off the motor or pump?
Check for adequate flow to bearings.
Also have your vibrations guy check for problems (providing he is better at vib analysis than I am :)
Drew K
10/24/2012 5:12 AM
cooling is by a shaft mounted fan. it is new. oil circulation is by oil rings only. the same pump (stand by) thrust bearing temp is 56-60 deg c. but his pump mentains above 85deg c.
vibration of both the pumps are equal.
Re: Boiler Feed Pump
10/18/2012 3:30 AM
Well, it must be worth a couple of telephone calls to the OEMs of both the bearing and the pump.
10/24/2012 5:15 AM
have done shaft , bearing seal replacement by OEM Only.
Good Answers: 19
10/28/2012 1:22 AM
What is the height of your Boiler Feed tank?
Register to Reply 8 comments
ASHOK KUMAR JENA (3); Drew K (1); ducon (1); Joshi (2); PWSlack (1)
