Previous in Forum: Unstable Voltage From Drive   Next in Forum: Difference Between Grounding, Earthing and Bonding
11 comments
Voltage Drop Calculation for Generator?
10/24/2012 8:50 PM
I want to know how to calculate voltage drop of alternator at the time of selection/design stage?
Re: Voltage drop calculation for Generator?
10/24/2012 9:44 PM
Which is it? Alternator, or generator? Not that it matters.
10/25/2012 4:30 AM
Actually I want to calculate voltage dip at deisel generator terminal at the time of starting largest motor?
10/25/2012 4:53 AM
Oh, that's easy. It's in the protocols in British Standard 7671.
Good Answers: 34
10/25/2012 5:25 AM
"Actually I want to calculate..."
You are wasting everybody's valuable time. You did not know, what you wanted, in the 1st place, yet you posted.
10/25/2012 8:42 AM
Without having more information that you have given here, you can't calculate anything.
You can measure the starting current if you have the motor. Then you can confer with the generator manufacturer for his recommendation.
This is starting to sound like homework.
10/24/2012 9:54 PM
You may need to be clear about voltage drop vs. voltage droop, and the contexts for each.
10/25/2012 12:34 AM
check this please
10/25/2012 12:57 AM
That's voltage drop of a conductor, not of an alternator.
Good Answers: 34
10/25/2012 2:55 AM
You may find what you are looking for HERE.
Good Answers: 42
Re: Voltage Drop Calculation for Generator?
10/28/2012 1:21 PM
At first you have to state if your generator will be connected with a grid [network] or will be isolated [island]-the generator dedicate to a load.
If the generator is connected to Grid then the current supplied will pass through busbar or cable, a step-up transformer and may be a short
overhead line. Since the Grid voltage and frequency could be considered constant then the generator speed and voltage will be adapted automatically.
If the generator is connected directly to the load-could be a step-up transformer and a step-down transformer and cable supply and so on, between the Generator terminal and load terminal-then the voltage drop up to load terminal has to be checked. You need to know the current, the power factor and the impedance for each part of the supply circuit and you may calculate partial voltage drop and summarizing the total drop.
Alternator nevertheless it is same meaning with generator it is usually referred to battery charger-in a vehicle mainly.
Julius
11/05/2012 10:51 AM
Dear Rajnish5404,
For 3 phase Alternator it is TERMINAL VOLTAGE + IMPEDENCE VOLTAGE = INDUCED VOLTAGE. Here, the Impedence Voltage is the Voltage Drop.
The Impedence Voltage is the VECTORIAL SUM and NOT arithmathic addition, and can be calculated as follows.
Iz = I x R + I x (Xl-Xc) where Xl is voltage drop on account of Inductance and Xc is Voltage drop on account of Capacitance.
DHAYANANDHAN.S
Register to Reply 11 comments
7anoter4 (1); dhayanandhan (1); Joshi (2); lyn (2); nobodysomebody47 (1); PWSlack (1); rajnish5404 (1); Tornado (2)
