Previous in Forum: Convection Inside Electrical Enclosure   Next in Forum: How Much W Do I Need?
20 comments
Drop Pump Load
10/31/2012 7:31 AM
Suppose a centrifugal pump is running on 70% electrical load. I want to drop this load upto 60% without changing the motor, flow rate and head.
Any suggestions please?
au.umair
Re: Drop pump load
10/31/2012 7:59 AM
Lower the specific gravity of the fluid being pumped.
Dropping the load, "upto 60% without changing the motor, flow rate and head" will be very difficult.
You can't get something for nothing.
Good Answers: 266
Re: Drop pump load
10/31/2012 8:40 AM
Bucket brigade to do the work you want to save on electrical load.
The 70% represents the work the motor is doing. Sort of like asking a race horse to run a race in the same time on half rations.
Re: Drop pump load
10/31/2012 9:14 AM
I think it comes down to someone may have spec'd something wrong.
Good Answers: 92
Re: Drop Pump Load
10/31/2012 1:53 PM
Change the pumped fluid to one with a specific gravity that is 6/7th of the original fluid. Or find a pump that is better suited to your requirements by the same amount and install it on your existing motor. As noted in previous posts, you can't get something for nothing.
Also note: unless this is just a mental exercise, the motor is likely not running at full efficiency at 70% load. If this is a typical operating parameter, you may find that replacing the motor with a high efficiency unit that is correctly sized will give you the same result- but that's a question for your pump supplier.
Re: Drop Pump Load
10/31/2012 2:02 PM
Come on, you size the pump for the process, not design the process around the pump.
Good Answers: 92
Re: Drop Pump Load
10/31/2012 2:15 PM
True, but that's not what was asked!
Re: Drop Pump Load
10/31/2012 2:21 PM
it was more of a statement than an answer.
As far as looking for a solution to the question from the op, it was a poor one as far as having an understanding of centrifugal pumps. Or actually electric motors for that matter.
Leaves one to speculate the budget is tight.
Re: Drop Pump Load
10/31/2012 2:07 PM
I think the OP is confused.
"I want to drop this load upto 60%". Reducing the SG by 6/7 will not help them realize their dream.
Good Answers: 92
Re: Drop Pump Load
10/31/2012 2:14 PM
Very!!
(Actually, I didn't read the OP very well- I saw 60% load instead of reduction in load! But if they change from pumping somethin like mercury to acetone they might pull it off!)
Re: Drop Pump Load
10/31/2012 2:45 PM
Maybe they do want a 10% reduction in load, but I can't tell by the question.
I see this mentality a lot. Please tell me how to reduce costs/increase efficiency, without putting forth any effort, or money.
Re: Drop Pump Load
10/31/2012 4:41 PM
What is "70% electrical load"?
Perhaps a different pump selection could operate closer to its best efficiency point (BEP) than the present one. Unfortunately, sufficient details were not given.
Re: Drop Pump Load
10/31/2012 4:50 PM
70% electrical load is too much.
The OP wants Froggy to plunk his magic twanger and make the electric bill go down.
Re: Drop Pump Load
10/31/2012 5:08 PM
au.umair,
Do you know what the pump curve for your pump looks like?
I'll stop here, before the devil tempts me to ask the obvious question.
Good Answers: 19
Re: Drop Pump Load
10/31/2012 11:06 PM
Increase the efficiency of your impeller. A more efficient pump impeller will require less energy to move the same flow and head.
Re: Drop Pump Load
11/01/2012 8:10 AM
I do not believe you have a viable solution here.
Good Answers: 19
Re: Drop Pump Load
11/01/2012 9:19 AM
I'm not sure this is a viable question either.
However, on further thought, you are partly correct. Moving x amount of weight (flow) through y amount of distance (head) takes a minimum certain amount of work plus whatever friction or other inefficiencies exist in the process. If the pump has a low efficiency impeller and you replace it with a high efficiency impeller, the less energy will be lost in the process. However there is still that theoretic work definition that cannot be changed.
Re: Drop Pump Load
11/01/2012 9:33 AM
I agree,
I like challenges but everything here is too vague.
Good Answers: 92
Re: Drop Pump Load
11/01/2012 10:03 AM
Well, if you want a challenge try nailing down this specific from the OP:
  1. the OP is running the motor pump combination at 70% electrical load
  2. the OP wants to reduce this by "up to 60%"
  3. this new load would equal a minimum running draw of 28% (40% of 70%)
  4. Now throw in an assumption- regardless of actually pumping anything, lets say the motor is a standard AC induction motor operating at nameplate speed and line voltage without any form of controller, and is only experiencing operating losses of the motor and the pump
  5. In my experience, a free running motor is going to draw at least 30% plus losses in the pump or other drivetrain item!! Where do you go from here??
Re: Drop Pump Load
11/01/2012 1:01 PM
ha, you forgot #6 not to change the motor or pump?
Now where did I put my magic wand?
Re: Drop Pump Load
11/01/2012 10:52 AM
Simple...just magically change the eficiency oif the pump at that specific point of its perfprmance curve. Otherwise slow the pump or start closing the discharge valve. Watch hte amp meter until you get to the desired 60% electrical load.
I'm not being sarcastic, merely silly.
The painful truth of the matter is if using the same pump either the head must be increased or the speed reduced, both of which will reduce the GPM and the BHP. The other choice is rep;acing the pump and motor. Another choice is trimming the diameter of the pump's impeller...this will also reduce GPM ,head and BHP basically the same as replacing the pump but at a lower cost. The pump manufacturer can give you guidance in this process.
Good luck...Lou Bindner
Register to Reply 20 comments
JNB (4); Lou Bindner (1); lyn (5); ozzb (1); phoenix911 (6); Ried (2); Tornado (1)
