Previous in Forum: Line shaft Bearings - Vessels   Next in Forum: Standard Belt Tensioning
13 comments
Water hammer
05/22/2007 1:58 PM
on a chilled water piped system which engineering method I can apply to relieve water hammer on the pipe when you shut up a valve??
Thank you
Tu conoceras la Verdad y la Verdad te hará Libre......Jesus
Pathfinder Tags: piping Pressure water hammer
Re: Water hammer
05/22/2007 2:06 PM
Simply install a water hammer arrestor - an air filled chamber, at the valve. Available at your local hardware store.
Good Answers: 40
Re: Water hammer
05/22/2007 3:42 PM
or change your valve to one that closes slower
Good Answers: 54
Re: Water hammer
05/22/2007 8:34 PM
Yup, both the water hammer arrestor and the slow closing valve are good ideas.
Another idea (more expensive but still valid) is to use a soft-start/stop motor drive. This thing starts or stops the pump slowly so that the pressure doesn't build up or collapse too rapidly.
We, however, use variable-frequency-drives. It allows us to control the chilled water flow as needed. It also incorporates the soft-start/stop feature.
This way, the valve is only used for isolation during maintenance.
Re: Water hammer
05/23/2007 1:51 AM
Water hammer usually occurs due to too many bends. If you can modify the piping to reduce the no. of bends this will relieve the system.
Good Answers: 97
Re: Water hammer
05/23/2007 2:17 AM
The advantage of too many bends is to confuse and rule.
The two sides that must be connected always seem to be on opposite sides of an obstruction. Would replacing the bends with tees and crosses reduce water hammer?
Re: Water hammer
05/23/2007 6:49 AM
Generally bends are of Radius = 1.5 x Dia of Pipe. In the above case it may solve the problem by using Long Radius Bends where Radius = 3.0 X Dia of Pipe which are available in market. Using Tees or crosses will be of no help since these also cause sudden change of direction in the momentum of water and thus create a hammering effect when a valve is closed.
Good Answers: 54
Re: Water hammer
05/23/2007 9:00 AM
Water hammer is caused by the sudden stopping of the flow of water (or fluid) due to the valve being closed too suddenly. The mass of the flowing fluid being forced to stop produces a shock wave that can burst pipes and damage other equipment that may be on the pipeline. I've also heard pipes hammer when the pump is direct-line started (ergo: water is forced to move too quickly).
Reducing the number of bends is always a good suggestion but it will not necessarily stop the hammering.
Re: Water hammer
05/23/2007 7:10 AM
Stick a big loop or bend in the line or an accumulator to absorb the " pulse"
Re: Water hammer
05/23/2007 12:12 PM
Frank--I investigate waterhammer accidents although I've never heard of one in a chilled water system. The # of bends in the pipe is immaterial. Can you describe where and when the hammer is happening. For example--is it when a pump starts or stops or a valve opens or closes? Does it happen at a high point in the system?
Re: Water hammer
05/23/2007 8:17 PM
It is something I suspect, could happen on the botton of the pipe in a high rise building, the sudden shut of the valve make the dynamic pressure of the pumped water to suddenly become a static pressure and start a shock wave.
What do you think about that??
Re: Water hammer
05/23/2007 1:14 PM
here are a couple of methods
1. cut remove the last elbow in the system insert a tee from the open end of the tee start a vertical pipe (an elbow may be necessary) but in an adapter for a larger size pipe make a vertical stand of the larger pipe approx. 18" and cap the top. when you refill the line this will create an air pocket that absorbs most of the shock. If you get hammering again after many months drain the line and start again.
2. replace the last 10 or more feet with new plastic hosing (approved in most states) this stuff needs no elbows or fitting so it is easy to install with the right crimp tool. since there are no corners and the pipe is more flexible than metal it absorbs much of the shock
No matter how much you know....God knows more
Re: Water hammer
05/23/2007 8:19 PM
Thanks a lot pals, Im gathering all valuable info and star laying out a system, Iwill let you know..
Re: Water hammer
05/24/2007 2:55 AM
I feel the best solution is the one against comment #1 i.e. to provide an air filled chamber near the valve and thus prevent any shock from being transmitted through the piping system.
Register to Reply 13 comments
Anonymous Poster (1); bhankiii (1); Frank-Jazz (2); Hendrik (1); kasharma (3); kirsner (1); mech eng (1); techno (1); Vulcan (2)
