Previous in Forum: 150 Class Valve With BW End   Next in Forum: Thermo Syphon Hot Water Runs With No Pump
18 comments
Sheet Metal Mike
11/28/2012 12:26 PM
HI ALL,
I Am building low pressure duct system using aluminum. the galvanized standard for this particular size would require 24 gauge material. I am going to use .040 aluminum for this project will this be adequate.this will be both supply and return ducts. The duct size will be 18" x 18"x 48" lengths.Like i stated this will be low velocity ducting.
Thank You, mike
Good Answers: 101
Re: Sheet Metal Mike
11/28/2012 12:55 PM
What do your local laws, codes, and regulations say?
11/28/2012 1:05 PM
210.0366 (0.93)0.028 (0.71)
220.0336 (0.85)0.025 (0.64)
230.0306 (0.78)0.023 (0.58)
240.0276 (0.70)0.02 (0.51)
250.0247 (0.63)0.018 (0.46)-
260.0217 (0.55)0.017 (0.43)-
First column= gauge
Second column Galv. Steel
Third column aluminum
270.0202 (0.51)0.014 (0.36)
11/28/2012 7:03 PM
That's interesting: calls for thicker galvanized than aluminum.
11/28/2012 7:18 PM
It's a weight thing. Metal is sold by the pound. From:
Sheet metal - Wikipedia, the free encyclopedia
Sheet metal thickness gauges for steel are based on the weight of steel, allowing more efficient calculation of the cost of material used. The weight of steel per square foot per inch of thickness is 41.82 lb (18.96 kg), this is known as the Manufacturers' Standard Gage for Sheet Steel.[4] For other materials, such as aluminium and brass, the thicknesses will be different.
Gauge and Weight Chart for Sheet Steel, Galvanized Steel,Stainless ...
Gauge
Sheet Steel
Galvanized Steel
Stainless Steel
Aluminum
Gauge Decimal
Lbs. per Sq. Ft.
Gauge Decimal
Lbs. per Sq. Ft.
Gauge Decimal
Lbs. per Sq. Ft.
Gauge Decimal
Lbs. per Sq. Ft.
300.01200.5000.0160.6560.01000.141
290,01350,5630.0170.7190.01130.160
280.01490.6250.0190.7810.01260.178
270.01640.6880.0200.8440.01420.200
260.01790.7500.0220.9060.0180.7560.01590.224
250.02090.8750.0251.0310.01790.253
240.02391.0000.0281.1560.0241.0080.02010.284
230.02691.1250.0311.2810.02260.319
11/28/2012 11:08 PM
I appreciate the explanation.
I am still fuzzy on how gauge standards being based on weights of steel can result in a less dense material, like aluminum, being thinner for a particular grade.
It seems like whether it was just about weight per square foot, or if it were based on rigidity, the same gauge aluminum should be thicker, not thinner.
Can you help me understand why basing it on weight would lead to aluminum gauges being thinner than the same numeric gauge of galvanized?
11/28/2012 11:19 PM
I think it has to do with how much sheet metal you can make with a pound of material.
This is different from wire gauge.
You're making me think way too hard here.
11/28/2012 11:35 PM
0.040 aluminum should work fine compared to 24-gauge steel. Do the same cross-bumping on large flats.
11/29/2012 12:05 AM
Mike, you need to think more about heat sink that metal thickness. Aluminum is a much better transformation metal and will transfer heat and cooling to the outside walls of the duct system. Galvanized sheet metal is not a very good conductor of heat and cold and that is the underlying reason for using it. If you want efficiency of your cooling and heating through ducts then aluminum would not be a very good material. If you wrap the sheet metal duct with insulation it will yield more cool air and warm air to the ends of the duct work. The best of the best would be a piece of PVC pipe large enough to serve the purpose and have it wrapped with fiberglass insulation. The reason is that plastic is a very poor conductor of heat and cold.
Good luck with your project.
A hand without an arm is a useless tool
11/29/2012 12:21 AM
Good Answers: 25
11/29/2012 11:02 AM
Ahoy!
Heh.
11/29/2012 1:09 PM
seemed like the most appropriate response to #8
Carry on, smartly.
11/29/2012 1:26 AM
Byron,
That's pretty far out. Totally wrong, too.
11/29/2012 3:44 AM
Asking this question this way is a bit like closing the stable door after the horse has run off:
  • If 24 gauge galv is the standard, and a decision has already been made to use .040 aluminium instead, then there is nothing left in the question for the forum to answer.
11/29/2012 8:04 AM
After careful reflection, I have to agree with you 100%.
11/29/2012 1:57 PM
Hi, I was just wanting to make sure the .040 was the comparison to 24 ga galvanized
and maybe drop to a thiner gauge.
Good Answers: 59
11/29/2012 10:50 PM
Did you consider mechanical properties? Everything else being equal, steel is stiffer and stronger than aluminum. What about vibration?
11/29/2012 11:16 PM
That's why the aluminum is thicker. (I.e., everything else is not equal.)
Good Answers: 101
11/30/2012 7:54 PM
And thermal...
Register to Reply 18 comments
Byron Jay (1); Ed Watts (1); leveles (1); lyn (5); PWSlack (1); RICHARDMICHAEL (1); RVZ717 (2); Tornado (2); truth is not a compromise (4)
