Previous in Forum: Tallest Building in the World?   Next in Forum: Soil Safe Bearing Capacity
14 comments
Concrete Reinforcement Fibers
12/09/2012 6:43 AM
HOW TO MAKE CONCRETE REINFORCEMENT BY FIBERS?
Re: FIBERS
12/09/2012 6:54 AM
Please take CAPS of. Look at the rules and my other post.
To answer your question.
You put the fibre in the concete!
Re: FIBERS
12/09/2012 8:12 AM
TURN OFF caps lock.
Good Answers: 179
Re: FIBERS
12/09/2012 8:38 AM
You would think he would have figured out the caps lock by now after 3 postings?!
Do a Google search for your answers. The questions that you've been asking are fairly elementary and you can usually find the answers in Wikipedia.com
Re: FIBERS
12/09/2012 8:39 AM
Please turn off your caps lock. All capital text is considered to be SHOUTING and is very rude.
You have already been given excellent information on concrete reinforcement with fibers in another thread. We can answer your questions here at CR4 with our personal experience and by referring you to sites and publications available outside of this forum. We cannot make you comprehend our answers.
Re: Concrete Reinforcement Fibers
12/09/2012 5:04 PM
I have personally poured a lot of fiber reinforced concrete, we ordered that way from local concrete company, it's fiberglass that's already mixed in concrete, but besides glass, fibers can be steel, polypropylene, or nylon. Only your local concrete supplier can do it economically.
12/10/2012 7:07 AM
Please turn off Caps Lock.
How about adding shredded tyres/tires?
12/10/2012 7:27 AM
Not sure if shredded rubber would give you any strength benefit.
12/10/2012 8:42 AM
Pure rubber I suspect will not reinforce concrete. However, I believe shredded tires with their integral threads in belts and sidewalls will reinforce concrete.
12/10/2012 11:49 AM
Yes, I did not think about the steel belts. But would shredding the tires then mixing them into concrete be more econimical then mixing fiberglass from insulation??? Fiber reinforced concrete is not that much more expensive when ordered from a concrete supplier.
12/10/2012 11:59 AM
I have no idea if tire reinforcement will be economical. It will be an added method to dispose used tires and as such it may have hidden benefits. It may also not be as effective as just adding fiberglass as you suggested.
12/10/2012 12:04 PM
Old tires have a million uses, I am sure putting them into concrete can be one of them. We built a playground with some shredded, 50' x 60' x 16" deep. That was not cheap, all the metal had to be removed from the rubber and the shred had to be smaller than 1/4".
12/17/2012 9:57 PM
12/18/2012 3:49 AM
I COULD NOT GET THE ADDRESS , MAY I HAVE IT?
12/18/2012 11:08 AM
CR4 ADMIN - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Register to Reply 14 comments
129CBRider (2); CaptMoosie (1); HASSAN ELRAMLI (1); IdeaSmith (1); JPool (4); lyn (1); PWSlack (1); redfred (3)
