Previous in Forum: Concrete Reinforcement Fibers   Next in Forum: NZ Quake Collapse Building Design 'Deficient'
Soil Safe Bearing Capacity
12/10/2012 5:54 AM
any body knows the SBC of black cotton soil,soft murrum, and hard rock?
pravin dhameliya B.E.civil 1994 pass out.
Re: soil safe Bearing capacity
12/10/2012 5:55 AM
Anybody who opens and reads Kempe's Engineers' Yearbook does.
12/10/2012 7:06 AM
12/10/2012 7:38 AM
I was sick that day in school when we covered it also.
12/10/2012 8:02 AM
Re: Soil Safe Bearing Capacity
11/25/2013 4:00 AM
Hi Pravin; assuming you are looking to design foundation, the SBC for BCS is taken as 100mPa in general. Morum with water or what are you refering to? If you mean with water then go with SBC:100mPa else you can take upto 180.
For the Hard Rocks it varies - better to have a Strata test done - Granites in our country vary too much - for example in southern AP - Uncracked Silica Granite test yielded upto 800mPa while similar looking granite had less than 450. So I cant give you correct figures for granites - your designs shall be based on actual tests. Assumptions can be dangerous some times.
lyn (1); Mohammed Fareeduddin (1); phoenix911 (1); PWSlack (2)
