Previous in Forum: Rock And Water Containers For Heat Storage Mass   Next in Forum: Concreting of RC Column
9 comments
Fiber Pieces
05/09/2012 2:20 AM
WHY SOMETIMES WE USE FIBER PIECES IN CONCRETE AND ASPHALT MIX?
Re: FIBER PIECES
05/09/2012 2:22 AM
Reduce weight add strength...
Re: FIBER PIECES
05/09/2012 2:34 AM
In particular, concrete and asphalt have low tensile strength (though good compressive strength). The fibers, even though small, add considerable tensile strength.
Re: FIBER PIECES
05/09/2012 6:56 AM
WHAT ARE PHYSICAL AND CHEMICAL PROPERTIES OF FIBERS?
Please Stop Shouting!
05/09/2012 8:52 AM
Chopped fiberglass, straw, horsehair, steel strands... all have been used.
Good Answers: 179
Re: Fiber Pieces
05/09/2012 9:25 AM
Fibers used in concrete and asphalt mixes are typically used to minimize "micro-cracking" of the cured mix. Also, they are used to minimize concrete shrinkage cracks, which are produced by the Heat of Hydration process when concrete is curing.
BTW, TURN OFF YOUR "CAP LOCKS"........in essence you are YELLING at us!
Do a Google search to find the material properties of fibers.....typically, steel and plastic fibers are used in the Civil Engineering world.
Re: Fiber Pieces
05/10/2012 3:52 AM
I DO NOT MEAN MAIN REINFORCMENT , I MEAN SMALL PIECES 2 CM LENGTH AND VERY THIN?
Good Answers: 179
Re: Fiber Pieces
05/10/2012 7:53 AM
THAT is exactly what I was discussing in my post above; fibers, and not main steel reinforcement bars.
Good Answers: 179
Re: Fiber Pieces
05/10/2012 8:02 AM
Do us all a great big favor and visit this website, and learn from it before bothering us again with your attitude:
en.wikipedia.org/wiki/Fiber-reinforced_concrete
One of the largest manufacturers of concrete fibers is:
www.fibermesh.com
Re: Fiber Pieces
05/15/2012 2:01 AM
mr. hassan , you need to use fiber and aspalt to protect the concrete and the steel rod inside the concrete inprastructure . and make this also to be waterproof,
hope you get a little idea on this messege.
i want ot helf piple need assistance and to share my knowleged in technical
Register to Reply 9 comments
CaptMoosie (3); Doorman (1); HASSAN ELRAMLI (2); SolarEagle (1); toink (1); Tornado (1)
