Previous in Forum: Joining Glass with Invisible Adhesion Point   Next in Forum: Electrodes Baking
31 comments
Reporting Inspection Results
12/20/2012 8:06 AM
Recently I've been ask by my boss to provide written evidence why we report an additional integer on our inspection reports, e.g., if a dimension reported on a print is shown as 1.500, and our measurement finds it at 1.5004, that is the number we show on our report. Throughout my extensive training in many different fields including metrology labs, this was a common practice. Applying a tolerace to the above example such as +0/-.001, normally we would reject the part. However my boss believes we should round off the number thus the part would be found in tolerance. I have researched many college books, ASTM, ASME, Y14.5, MIL and FED standards, etc. but can't find nothing related to this inquiry. Can anyone help?
InspectorK
Pathfinder Tags: Posting measurement results
Good Answers: 34
Re: Reporting inspection results
12/20/2012 8:12 AM
Trust this helps:
Significant figures - Wikipedia, the free encyclopedia
en.wikipedia.org/wiki/Significant_figures - Cached - Similarleading and trailing zeros which are merely placeholders to indicate the scale of
the ... Trailing zeros in a number containing a decimal point are significant. ... as
many decimal places as the measured number with the smallest number of
decimal ... ASTM E29-06b, Standard Practice for Using Significant Digits in Test
Data to ...
Re: Reporting Inspection Results
12/20/2012 8:22 AM
Your boss is right.
The 4 is meaningless. Don't report it.
Good Answers: 69
12/20/2012 8:24 AM
OK, zero means zero, but your boss might still be right, you both have to go to engineering and ask about the positive tolerance manthisa, which in the case of the negative margin, only gets to the third digit.
12/20/2012 9:09 AM
Your boss is an ass, if he doesn't want the last digit he can ignore it.
IMO you should report exactly what is indicated, no more no less.
The interpretation of the figures is an entirely different question.
If everybody starts interpreting and rounding it will end up like some sort of Engineering Chinese Whispers...
The full data may be of use at a later date for some usforseen use, even maybe checking the measuring equipment or method of measurement.
Feel free to cut, paste and E-mail the above directly to your boss.
Hasn't he got something useful to do?
(I'm quite happy to be wrong on this or in contravention of some half arsed standard, but I will stand or fall by what I've said)
12/20/2012 9:19 AM
Without seeing the documentation requirements, it's anybody's guess, but why report insignificant numbers? They add nothing but confusion.
12/20/2012 9:22 AM
Confusion or noise? Just askin'.
12/20/2012 9:33 AM
Evidently Del the cat, you've worked with precision components unlike the other poor unexperienced responses I've read on this topic. Thanks for your input and British humor...love it! :-)
InspectorK
12/20/2012 9:52 AM
If you knew the answer, why ask the question?
To endear your self to the "poor unexperienced" responders?
12/20/2012 9:50 AM
I thought I offered quite a lucid explanation, I don't really have much to add.
unless you'd like a little light sarcasm? *
Imagine there is a tolerancing issue at some later point and they want to apply a new go/no go limit. Or maybe some other part can't be made to tolerance and they have to select specific parts to match with others? I can't see how the extra figure can do any harm, if you don't want it just put your paw over it.
It may be useful later for analysis of machine wear, or even just to prove it's 'noise' and random variation.
Heck those spare digits can come in handy for constructing bankers bonusses
*If an extra digit adds confusion I'd submit the person reading the data should be making the tea instead (other hot beverages are also available).
12/20/2012 9:54 AM
They must do things differently in England.
If I can measure out to 10 digits and my tolerance is to 3 digits, the other digits are meaningless, and add to the confusion.
12/20/2012 10:02 AM
To be fair, this isn't my field, and I'm happy to be wrong.
It's my interpretion of 'Report'.
For production or my own use, I'd just work to the tolerance, but for a 'report' I'd simply report exactly what I read, no more no less.
Probably the usual case of language getting in the way of communication.
(I shall go and measure my secret cat nest to the nearest paw width)
12/20/2012 10:06 AM
I'm sure the OP make will make clear his intentions.
I'm taking my ignorant self out of this one.
Happy Holidays.
Good Answers: 266
12/20/2012 10:09 AM
The process of inspection is separate from the decision of rejection or acceptance. What you are reporting in the inspection is the full capability of the test equipment.
With out a tolerance listed unless it's dead on it's rejected. What your boss is doing by wanting you to round off is making a implied tolerance. So he can increase productivity. Do as he says but have him write off on it.
12/20/2012 11:15 AM
I disagree with a lot of the other commenters.
You say the key dimension is " 1.500, and our measurement finds it at 1.5004, that is the number we show on our report. Throughout my extensive training in many different fields including metrology labs, this was a common practice. Applying a tolerace to the above example such as +0/-.001, normally we would reject the part."
NO, you would not. A measured value of 1.5004 is within the +/- 0.001 tolerance on a 1.500 dimension. Your tolerance allows a part as large as 1.5010, so this part 'passes' with 0.0006 to spare.
If, however, your part was toleranced at 1.500 +0/-0.002, then reporting the measured dimension is necessary for the cause for rejection. In this alternative case the part is too large by 0.0004.
In the case you are citing, though, your boss is correct (or, at least, not incorrect) since the part meets the tolerance you cite. There is no need to state the measured size to 4 decimal places if it meets the criterion at 3 decimal places. In some companies a simple 'Pass' criterion is all that is needed in a case like this.
12/20/2012 2:52 PM
D'oh. I really need to wait til I've had my morning coffee. Just ignore this^.
12/20/2012 12:06 PM
It depends on wether you want to take attribute data or variables data. With attribute data, each measurement is less powerfull for making a judgement. Varaibles data is much more powerfull to monitor your process. I would use the 4 digit data to determine the standard deviation from print nominal. By using only 3 digits of data, you are essentially doing an attribute inspection with Pass or fail indications. This means your boss wants to see that a unit is perfect or fails with no in between. You know the parts are not all perfect or failing. Of course some of the parts are perfect and some fail, but most are somewhere in the middle of these two extremes. You will know what your process is capable of with actual measurements as opposed to pass fail criteria.
12/20/2012 2:47 PM
The tolerance that the OP reported was +0/-.001, therefore the part would be a reject no matter the number of decimal places on the print. There is a good chance that the part would not fit together with its mating part if it was passed through inspection.
The tolerance in the example given is effectively 1.500 - 1.499. Anything 1.5(insert as many zeros here as you like)1 or larger, or 1.498(insert as many nines here as you like)9 or smaller is a reject. There is no rounding into tolerance. The part is in or it is out.
Mike W.
You have to actively participate in the manifestations of your own joys and good fortunes - they are not ready made for the taking, they are available for the making.
12/20/2012 2:57 PM
Most of you who've commented have made some very valid points with only one person directing me to a written document from a reliable source. However, it in itself refers to testing results and not dimensional measurements. Other documents I've reviewed are from Y14.5, and ISO 8015. I'm currently have asked people at NIST, and other doctorate degreed individuals in which I'm still awaiting responses. There are many pro's and con's to this but has anyone really nailed it in an accepted document as an accepted practice?
InspectorK
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
12/20/2012 6:04 PM
The man who sighs your paycheck should get what he wants.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
12/20/2012 6:13 PM
Yeah, I sigh when I get my pay check too.
I always say 'The usual bonus?'
and the guy who gives it to me says 'yeah, the usual bonus'
Anyhow you are wrong on so many counts. The guy who signs the pay check should get what he pays for , which may not be what he wants. Those idiot managers on Challenger bullied people to get what they wanted instead of the correct scientific opinion they'd paid for and people died.
Good Answers: 73
12/26/2012 10:04 PM
The comment was meant to be tongue and cheek, but I'll stand by it. You live and die by the print and the process sheet. The customer sets your tolerance, you and everyone in your organization must strive to meet that. Yes, we have SPC to log and show trends. The print will tell you how many points out the customer desires.
If you produce the part within that spec, you've done your job, and it's time to move on to the next piece. Remember, time is money, and the lowest bidder stuff. From Wiki:
Statistical process control (SPC) is a method of quality control which uses statistical methods. SPC is applied in order to monitor and control a process. Monitoring and controlling the process ensures that it operates at its full potential. At its full potential, the process can make as much conforming product as possible with a minimum (if not an elimination) of waste (rework or trash). SPC can be applied to any process where the "conforming product" (product meeting specifications) output can be measured. Key tools used in SPC include control charts; a focus on continuous improvement; and the design of experiments. An example of a process where SPC is applied is manufacturing lines.
Contents
12/20/2012 11:16 PM
Manufactured parts vary, and manufacturable designs specify tolerances. Useful measurements are sufficiently precise to show variation within tolerable limits. Suppressing deviations makes measured values indistinguishable from pass-anything, rubber-stamp "measurements." Rounding measurements may move them farther as well as nearer to specifications. Trends in deviations may provide early warning of the development of potential problems. Limiting reporting of deviations to one digit is sensible.
You may have a hard time finding an authoritative reference for these assertions, because they are so fundamental. My guess is that your best bet might be a textbook used in a freshman course in an industrial engineering curriculum.
Good Answers: 34
12/20/2012 11:29 PM
12/21/2012 12:46 AM
The horse's mouth is apparently ASTM E 29. This has become an essentially legal document, incorporated by reference into innumerable contracts and specifications. As such, it can be downloaded for free from legal resource sites on the Web. It raises several questions. My (lay) opinion, after reading it, is (1) if the report in question is a "measurement report," all available precision should be used; so that rounding can be done only once; and (2) if the report is a "conformance to specification report," measurements should be rounded to match the specification, with or without tolerance limits according to the specification.
12/21/2012 12:52 AM
Here's a link.
United States - Member - US Navy Veteran
Location: Nothing sucks more than that moment during an argument when you realize you're wrong.
Good Answers: 22
12/21/2012 10:52 PM
ASME Y14.5M-1994 2.4 Interpretation of limits
To determine conformance within limits, the measured value is compared directly with the specified value and any deviation outside the specified limiting value signifies non-conformance with the limits.
With 1.500 (+0/-.001) most would probably consider 1.5004 to be out - not me.
I feel if .0004 is a problem with fit/form/function then it should have a tolerance of ( +.0000 / -.0010 ).
I would call it good with a 3 place tolerance rounded down to 1.500.
What if it's .000063158 on a CMM? Do you kill it for .0001?
You never know when it will strike, but there comes a moment when you know that you just aren't going to do anything productive for the rest of the day.
12/21/2012 11:36 PM
The passage you quote does not seem to appear in ASME Y14.5-2009 2.4 Interpretation of Limits, but is consonant with this, which does: "All limits are absolute." This appears to correspond with the "absolute method" of ASTM E 29 and contrasts with the "rounding-off method" in the same place.
I read the +0 tolerance as max, and your notation suggestion--using the absolute method--as requiring an infinite number of decimal places. Your next assertion and final question are perfectly reasonable, but appear to assume the rounding-off method.
It was my impression that the questioner has no problem deciding when parts are good. Rather, his boss wants him either to change his long-standing reporting practice or to find authoritative support for it. My own strong prejudice is that a guard digit is a Good Thing (but rounding more that once is not).
12/26/2012 7:18 AM
Thanks Halb1t, you understand my dilemma correctly and I couldn't agree with you more. I appreciate your intelligent comments!
InspectorK
Good Answers: 22
12/26/2012 9:04 PM
It's been my experience that this issue goes away if you stick to the print.
1.500 ( +.000 / -.001 )
With a 3 place nominal and tolerance the .0004 material condition is no more of and issue than .00006 would be.
Our engineering group has questioned my department the same way your currently being questioned and they were right.
We now report print value - nothing more/nothing less.
12/22/2012 3:27 AM
With 1.500 (+0/-.001) most would probably consider 1.5004 to be out..
No they wouldn't. Nobody would consider it out, because it isn't out!
12/26/2012 4:03 PM
Why do you believe the 1.5004 measurement? How are you sure that is correct?
Don't tell me you know it is correct because the measurement instrument is calibrated. That info means very little except in the Cal Lab itself. The Cal Lab is a controlled environment. If you were to take that same instrument (properly calibrated) and set it in the bed of a pick-up truck driving down a dirt road, would you still trust the measurements made on it? Your manufacturing or incoming receiving areas are not that bad, but they do influence your results.
Someone earlier asked "confusion or noise?" This is a basic question for any measurement system. How much variation is in your measurement system? To answer that, you need to know how much variation is introduced by the equipment, the operator, the environment, and the procedure. If you can't answer each part of that question, I would assert that the last digit(s) of your reading is(are) unknown.
Look up Gage Repeatability & reproducibility (GR&R). AIAG has an excellent document, "Measurement System Analysis", which will take you through the how and why and even gives you a report form.
I applaud you for wanting to know the answer to your question. No data should ever be taken unless you know exactly what you are going to do with it. Apparently, pass/fail criteria are not well defined. Clearing this up now comes under the heading of continuous process improvement.
Finally, in my opinion, a QC/QA document which has only "pass" or "fail" written on it is useless. I recommend the inspection record clearly identify what is being inspected, what procedure and equipment is used, who is inspecting, what the acceptable range of measurement is, the actual reading taken, then the pass/fail determination.
Register to Reply 31 comments
Anonymous Poster (1); Bricktop (2); halfb1t (4); harley (1); InspectorK (3); Joshi (2); lyn (5); markar (2); Mike W (1); ozzb (1); PWSlack (1); reward54 (1); Usbport (2); user-deleted-1105 (4); Yahlasit (1)
