Previous in Forum: Coal Mill Fire and Explosion   Next in Forum: Flat Wire 6*1.5mm Possible in Wire Drawing Machine?
10 comments
(6MW) Qing Dao Single Extraction Condensing Steam Turbine
01/08/2013 11:45 AM
Respactd sir.i have a (6MW) Qing DaoSingle Extraction Condensing Steam turbine 3000 Rpm.. This turbine control Via Woodward (505E) Controler through Cpc. Cpc inlet pressure is 9.5 bar. And CpC Outlet pressure is (2 Bar TO 6Bar) (4mA TO 20mA)& Valve Postion is (0 To 100) Operated. By Cold test. that ok. (startup of steam turbine) Menualy Turbine Reset & through 505E Reset turbine speed first Se t point is 500rpm 2nd is 1200 rpm. & third set point is 3000rpm. After 1200rpm menuly increas 3000 rpm through pluse oil pressure. Zearo Speed Turbine pluse oil pressue is a 2.94 bar 3000 rpm 4bar pluse oil pressure.shift the electric load 1mw turbine speed decrease 2800rpm and after 10 to 20 rpm sowly slowly increase turbine speed via woodward 505E Controler 2930rpm.Turbine speed menualy increas through pluse oil pressure 3000rpm .Controler is the control speed set point. +-3 rpm.& 2nd step shift the load 2MW. This postion is Same first poiston and wht changing is governor valve is hunting i mean Hp Governor Valve & Lp Governor valve turbine hunting. please advise me how to slove the problem. Thnx.
Re: (6MW) Qing Dao Single Extraction Condensing Steam turbine...
01/08/2013 12:05 PM
Reduce the integral action in the speed controller.
01/08/2013 12:26 PM
Woodward Controler is Configrate orginal setting is ok. Sir
Imran Butt
01/09/2013 5:17 AM
Then there's a disagreement.
01/09/2013 11:56 PM
Dear Enginer I have purchas in brand new Woodward505E & Old Is Card demage . New instal 505E with Compny Configar Oregnal settings. Turbine running is not smooth operation. Kindly help me?
Imran Butt
Good Answers: 19
01/10/2013 12:38 AM
http://www.ge-mcs.com/download/orbit-archives/1Q09_Equate.pdf
Butt Sb., check this out
Re: (6MW) Qing Dao Single Extraction Condensing Steam Turbine
01/08/2013 4:42 PM
Then don't reduce the integral action in the controller....
Good Answers: 19
01/09/2013 11:02 PM
I fail to understand that why you need to ask this in this forum. Why are you not asking your steam turbine supplier Qing Dao ? You are under a warranty 1 year and with 2 years spares.
01/09/2013 11:32 PM
Dear engineer this Turbine pruchas other factory. Warranty is Expier. please advise me how to slove the problem. Thnx. or Woodward 505E Configaration method .
Imran Butt
Good Answers: 19
01/09/2013 11:58 PM
Butt Saheb, ok now I understand but frankly i doubt if this can be solved in this forum unless Qing Dao is contacted and paid charges to solve this. This is major reason why I do not recommend used turbines or deal with a Supplier who cannot give backup.
01/10/2013 12:16 AM
You might look at some of these.
ducon (3); Iybutt (3); PWSlack (2); Tornado (2)
