Previous in Forum: LOGO   Next in Forum: Variation in Excitation Current of Synchronous Generator
Output Choke for VFD
01/19/2013 1:24 AM
What will be the max cable distance from VFD to motor for an output choke of 1260A , 8.6micro henry 690v .
Re: output choke for VFD
01/19/2013 7:24 AM
What is the VFD worth? Better what is the rating. What is it for? The motor data? any?
Why choke?
Re: Output Choke for VFD
01/20/2013 4:15 AM
Dear Mr.coolguuy,
Max. distance should not exceed 30 Metres - after VFD. But it is better to as near as possible.
DHAYANANDHAN.S
01/28/2013 6:40 AM
sir,
i asked what will be the distance between the choke(which is connected near and next to vfd) and motor . what will be the max distance the choke can run without failure.
01/20/2013 3:11 PM
A CE-marked VFD does not need an external output choke.
01/21/2013 1:35 PM
As there are so many variables that effect the maximum cable distance it is advisable to directly contact the VFD manufacturer for application specific advice.
Alternatively some VFD manuals will have the necessary information in them.
Jack - Used to sell and service VFDs.
01/21/2013 2:14 PM
The limitaion for the cable length will depend on the slew rate of the outputstage of the VSD. Some VSDs have high slew rate henec putting more restrictions on maximum cable length with dv/dt filter to 30 m. I advise you to contact your equipemnt manufacturer to confirm the selection of the dv/dt limiter.
Register to Reply 6 comments
coolguuy (1); dhayanandhan (1); IdeaSmith (1); jack of all trades (1); PWSlack (1); rodeh (1)
