Previous in Forum: Measuring Scale - Marked as "Engine Divided"   Next in Forum: Area, Volume, and Hydraulic Diameter for Regenerator
Under Ground Pipe Thickness Calculation
02/01/2013 11:36 PM
HELLO,
Can anyone pls explain me the procedure for thickness calculaion for underground piping?? i m in urgent need of it, pls mail me any book or material for the same.
Re: Under ground pipe thickness calculation
02/02/2013 12:37 AM
I'd tell you where I found these, but I can't remember.
Guidelines for the Design of Buried Steel Pipe
Pipe Wall Thickness Calculation‎
Re: Under Ground Pipe Thickness Calculation
02/02/2013 10:19 AM
There is no need. One uses published tables of pipe for design purposes, and for practical measurements one uses ultrasonic thickness gauging equipment. And the sort of things that are needed to progress this are:
  • What does the Process Engineer say about the system maximum operating pressure and temperature, for instance (rhetorical question - NNTR)?
  • What is on the process data sheets (rhetorical question - NNTR)?
  • What impact does what is being carried inside the pipe have on piping material selection (rhetorical question - NNTR)?
Register to Reply 2 comments
