Previous in Forum: Load   Next in Forum: Under Ground Pipe Thickness Calculation
Measuring Scale - Marked as "Engine Divided"
02/01/2013 8:43 PM
Dear CR4 MEMBERS,
I have come across a 12 Inch Scale, made out of Stainless Steel and I found a mark, in the Scale "THIS SCALE IS ENGINE DEVIDED." On one side it is in inches and other side in centimetres.
Now I want to know what is meant by "ENGINE DEVIDED."
Thanks,
DHAYANANDHAN.S
Re: MEASURING SCALE - MARKED as "ENGINE DEVIDED*
02/01/2013 8:52 PM
I think it means logarithmic scale.
02/02/2013 4:01 AM
Thank you Mr.lyn, for your posting.
The scale what I referred is a Plain Scale, made out of SS Material and the flat thickness is 1/16 of an Inch - on one side in INCHES, as 1/16, 1/8 division etc. and the other side in CENTI METERES as 1 MM division and not logarithimic scale.
Thanks,
DHAYANANDHAN.S
02/01/2013 9:49 PM
"Devided" would be a misspelling of "divided." "Engine divided" means that the marks were placed by some machine, with some gears or linkages; rather than by, say, silk screening or other copying. (Usually considered as a sign of accuracy.)
02/01/2013 9:52 PM
I think you are right. <both of you>
02/02/2013 4:03 AM
Thank you Mr.Tornado,
You are RIGHT. It should be DIVIDED and NOT DEVIDED.
Thanks, for correction and error is regretted.
DHAYANANDHAN.S
Good Answers: 110
02/01/2013 9:49 PM
It means that the scale is engraved into the metal rather than just painted on.
Think big. Drive small.
02/02/2013 4:05 AM
Thank you Mr.K.Fry, for your reply.
It appears to be etched/engraved and NOT painted.
Thanks,
DHAYANANDHAN.S
Register to Reply 7 comments
dhayanandhan (3); K_Fry (1); lyn (2); Tornado (1)
