Dear all
I have two questions about pipe wllthickness calculation:
1-usually in Piping Material Specification we are categorize classes according to ASME B16.5 pressure rating:150#,300#.....900 and 1500,….
When we are calculate the wall thickness we consider the Pressure that we have in ASME B16.5, my question is :
If we have a 900# class and we calculated our pipe wall thickness( from 1" up to 14") inaccordance with ASME B16.5, is it possible(for economy reasons) to consider some lines( 18" and above) with their design pressure which is less than the pressure we have in ASME B16.5? (Do we have any problems with Flanges thickness and Pipe wall thickness?)
2-I know that for underground piping in a plant (ASMEB31.3 standard) the claculation we have for pipe wall thickness is enough, my question is:
If ther are some additional loads on the location which we have under ground piping how we should consider the additional load into our calculation which cause more thickness for under ground pipe
(if it is possible please give me an example).
Thank you very much
