Previous in Forum: API 1104, Branch Connection, Pipe to Weldotet Joint is Butt Weld or Fillet Weld?   Next in Forum: Ventilation for sewage lift station
Steam Extract - Heat Recovery
03/16/2013 3:12 AM
Hello, I have a number of large cooker extracts and know the volume and temperature of the steam exhaust but what I am trying to design is a large heat exchanger that will totally condense the steam back to liquid and in exchange heat water to be stored for hygiene. Any suggestions or direction to a design site?
Pathfinder Tags: heat recovery
Re: Steam Extract - Heat Recovery
03/16/2013 6:26 AM
Look at the flowrate and temperature of the steam. Work out the total possible rate of recovery of the energy by using Steam Tables. Compare that with its value in terms of the value of the energy supplied from elsewhere. Then make a judgement as to whether or not it is worthwhile recovering it before proceeding further.
03/16/2013 9:35 AM
A condenser, but the information you supply we cannot give you an intelligent estimate or suggestion.
What is the lbs of steam available you want to condense?
What themperature of water do you want?
Good Answers: 38
03/16/2013 2:14 PM
The device you are interested in is called a "waste heat boiler", economizer or recuperator...
Attempting to condense exhaust steam will change the amount of flow above the cookers.
As the steam condenses, it occupys less volume, induces a slight vacuum and pulls gaseous flow from whatever direction possible. This may reduce the draft ( pull above the cookers.
It is considered wise to "leave some heat on the table" ( you cannot take out all of the heat from the stream or you will not get adequate draft.
Pre-heating of inlet water streams is considered to be a good application for this waste heat. Be prepared for increased corrosion on the surfaces of this new heat exchanger. Have a properly designed condensate drainage system.
I assume that there are non-condensibles and that there must be adequate draft for the cookers after the modification.
What are your temperatures and volumes ?
How did you measure the steam volume ?
Register to Reply 3 comments
MJCronin (1); phoenix911 (1); PWSlack (1)
