Previous in Forum: 'Jacob's Ladder' info please.   Next in Forum: iPod Battery
12 comments
non-contact measurement
05/30/2007 12:50 AM
Can someone tell me if there is a non-contact way to measure for cutting things such as boards or pipe. The measuring device has to be stationary with the object to be measured/cut moving under it. Need to measure variable lengths with maximum length about 45 ft. Speed is up to 5 ft per second.
A contact wheel with a magnetic pickup to send a signal to a digital readout doesn't work because the surface is to rough. I thought maybe a laser but one sales rep said 'no" although I'm a little hesitant about one person's opinion.
Thanks for any help and advice.
"don't be so open minded that your brain falls out" unknown
Good Answers: 54
Re: non-contact measurement
05/30/2007 2:43 AM
Hi Randyl,
I've no experience with non-contact length measurement but here's one idea that I have:
You install two photo sensors a few inches or centimeters apart (designate distance as "D"). You will also need two timers (T1 and T2).
T1 measures the time it takes to break beam A and beam B.
T2 measures the time it takes to break and unbreak beam A.
Your length will then be:
L = D ÷ T1 × T2
The accuracy will depend on how well you control the speed of the pipe or board. If it's constant, the accuracy will be high.
05/30/2007 11:18 PM
Vulcan,
Thanks for the ideas! They are good. Our problem is that speeds will vary and sometimes the material will even reverse direction before the final cut is made.
Randy
05/30/2007 7:18 AM
I use a laser phototcell and a encoder which is in a fixed position on a converyor and with a digital diplay use it to display the length of steel plate in mm to the operator on the line which runs up to 30 meters/min.If you think this could help you then contact the company Banner and ask a sales rep to come and see you.
05/30/2007 11:24 PM
Thanks...this sounds like what we are looking for. I found Banner Engineering which looks to be the company you referred. I'll check them out.
Thanks again,
Randy
05/30/2007 9:47 AM
Randyl, is this to measure the length to make the cut, or is it just as the first post suggested to measure a cut length of pipe etc...?
If its to measure where to make a cut then how accurate does the measurement need to be?
John.
05/30/2007 11:36 PM
Electroman,
It's to measure the length for the cut and which can be anywhere from 8'6" to 41'.
On a lot of the projects it can be sloppy. + or- one inch, although my preference would be .125 of an inch.
OK, I know this sounds sloppy but the cut material will be further processed into a finished product.
Thanks,
Randy
Good Answers: 54
05/30/2007 8:30 PM
Another one just popped up. Mount your laser emitter at an angle and height such that when the pipe or board breaks the beam, the length of the board is just right for cutting.
05/31/2007 8:24 AM
<Surface is TOO ROUGH>
How rough?
<moving under it>
-Moving on SOME Roller--take the measurement *off that Roller.
Best way out.* Rubber tyred pickoff signalling out 1 pulse every 1" or 0.1 foot?
Or maybe the <boards or pipe> can be First marked with a paint marker every 1' or 0.1' before loading to this Length-Measured-Cutoff Table . TOO-ROUGH will be now bypassed . Sense-the -coloured-spot system will take over.
Laser Salesman was right.
05/31/2007 8:29 AM
use a laser sensor length wise looking at the end of the tube. Out put a analouge signal to small plc and use this to cut at whatever threshold required.
05/31/2007 11:07 AM
Give Keyance a call. They have the non-contact systems you need and the design group to help.
Good Answers: 40
06/05/2007 12:19 PM
Here is a lot of companies that specialize in what you are asking
http://steellinks.com/pages/Sensors__Gages_and_Measuring_Devices/Length/index.html
06/08/2007 1:58 AM
Thanks everyone! You got me on the right track. I think we'll have this project under control shortly.
FYI. I got a call from a Keyence rep. Unfortuately... he didn't know they sold what I was looking for. They do as well as several other companies.
Register to Reply 12 comments
Anonymous Poster (1); Electroman (1); garryvg (1); MUKULMAHANT (1); Randyl (4); techno (1); Vulcan (2); Ydobon (1)
