Previous in Forum: CR4 Tidy Up   Next in Forum: UAV's Used To Spy.....
32 comments
Solar Dump Load
06/20/2013 7:23 AM
Hi,
I'm thinking of installing 300 to 400 watt of PV solar panels on my roof to charge my 320 amp hour 12v battery bank. I consume approx 250 watts of electricity per hour during the day. This battery bank was basically to provide house power during brown outs when it powers a 2000 watt (4000 watt surge) pure sine wave inverter which runs a Pc, small led Tv, 2 fridges & a freezer, & is recharged with a mains battery charger at the end of the brown out.
I'm now thinking, if I install the pv solar panels, that I can create a fairly balanced system whereby I could turn off the mains power between 9am - 5pm & still have the battery bank well charged by the time I revert back to mains power. (On cloudy days I could switch back to mains power earlier in the day)
The Solar Charge Controller will need to be connected to a dump load. I'm wondering if a 240v 13amp kettle would work ok as a dump load if connected to the solar charge controller which has the potential to deliver 400watts 12v DC power into the kettle.
(I'm not concerned with boiling the water, just want to know if this will be effective as a dump load)
Green to Brown & Blue to Bits
Good Answers: 918
Re: Solar Dump Load
06/20/2013 7:53 AM
Will your battery pack and inverter have enough power to manage the inductive kick of your motors starting for the refrigerators and freezer?
Re: Solar Dump Load
06/20/2013 8:10 AM
We know you mean locked rotor amps starting current.
Re: Solar Dump Load
06/20/2013 8:17 AM
Attention!
Attention!
Meaningless units alarm: <...250 watts of electricity per hour...>!
Arroooooooooooooooooooooooooooooooooogah!
Re: Solar Dump Load
06/20/2013 2:46 PM
Huh? I understood it perfectly.
250 watts per hour would be 250 watt hours of electrical power consumed per hour.
Next you will be telling me that my 5 horse power pump that ran at full capacity for an hour didn't do 5 horsepower hours worth of work because I was not grammatically perfect?
BTW, how are those OCD meds working? Are you taking the right milligrams per dose or are you just taking them per day?
Re: Solar Dump Load
06/20/2013 8:34 AM
  • 320Ah x 12V = 3840Wh.
  • 3840Wh / 2000W = 115min without solar support
  • 3840Wh / [2000W - 400W] = 144min with solar support
So the battery pack isn't big enough at the moment to support 2kW load 9am - 5pm (480min), with or without solar.
  • Recommendation: install more batteries first: 480min / 115min = 4.2 times. (4.2 - 1) x 320Ah = an additional 1024Ah is needed. Strategy: install perhaps another 300Ah and see if it is enough for current needs (pun intended). If not, then increase it.
  • Strategy: the justification for going solar support depends upon the amortised cost of the solar panels, installed, over the energy supplied versus the price of energy from the grid. There is insufficient information in the original post to enable calculation on this. Once installed, the preferential power source would be solar, not grid, on economic grounds.
  • Dump loads are not required, generally, for solar panels. It makes far more sense to charge batteries with any surplus.
  • Tactic: Consider combining the contents of 2 fridges into 1, and go internet TV via the laptop during the black-out to extend battery back-up time, and ditch one fridge and the TV from the battery supply. The spare fridge may have residual value via an internet auction site, or as a gift/loan/sale elsewhere in the community.
Good Answers: 918
Re: Solar Dump Load
06/20/2013 8:45 AM
Yeah, I am confused about the "dump load", too.
All you need is the solar array, voltage controller/charger, and the battery array.
Then you can use voltage inverters to supply AC power from the battery array.
Re: Solar Dump Load
06/20/2013 10:37 AM
Probably should have made it clear that this is a back up supply for the frequent brown outs we have here. The cost of installing a full solar system would be prohibitive.
Usually the unplanned brown outs last for less than 2 hrs, planned ones for utility maintainance work are usually 4 to 8 hrs & I realise my batteries will have died well before that point.
Many thanks to all for the time you gave taken to assist me working this out! My load is 250 watts (max) the solar panels I'm planning to install are either 300 watts or 400 watts
Re: Solar Dump Load
06/20/2013 11:12 AM
Now that's been clarified, the batteries already have sufficient capacity.
A dump load is not needed.
<unsubscribes>
Good Answers: 918
Re: Solar Dump Load
06/20/2013 11:18 AM
The Watts are not apple to apples.
A 100 Watt light bulb consumes 100 Watts of power at 120 Volts.
Your best case power out with a 400 Watt solar panel is 400 Watts at 18 VDC.
Now you need to convert that 18 VDC to 120 VAC, which even at 100% efficiency means that panel is only producing 60 Watts of power at 120 VAC. Actual power will be only 50 to 55 Watts after losses are considered.
So, just to power that single 100 Watt bulb requires two 400 Watt panels running full tilt. Note, that panels can not produce 100% power all the time because the Sun's angle through the atmosphere, clouds, shade, and angle of incidence vary throughout the day.
Re: Solar Dump Load
06/20/2013 11:28 PM
Amperage is (roughly) inversely proportional to voltage, but except for losses, an inverter's AC output wattage is substantially equal to the DC input wattage.
Re: Solar Dump Load
06/21/2013 10:24 AM
What?
my 100 watt solar panel @ 18VDC charges my 12V battery for 1 hour.
My 85% efficient inverter (12VDC to 120VAC) means I can run my 85Watt @ 120VAC light for 1 hour, of course barring any losses in cables (minuscule).
Good Answers: 918
Re: Solar Dump Load
06/21/2013 11:16 AM
You are right. I realized that about an hour (after I woke up :) )after I posted it. Breakfast of Champions - eating your own words. :)
Keith, welcome to CR4!
Re: Solar Dump Load
06/21/2013 9:04 AM
Scrap the whole entire PV thing, get some magnesium, and a steam engine, add water, a voila, you have green energy (no CO2) on demand. Also, buy some large fresnel lenses, and focus the sunlight down really tight onto a Cr+3, Nd+3 doped YAG crystal and you have a solar-pumped laser to convert the magnesium oxide back to magnesium. Hey if they can do this at University of Tokyo, so can you.
Re: Solar Dump Load
06/20/2013 9:31 AM
To answer the actual question.
The dump load needs to be rated for the same voltage as the supply. E.G a mains rated kettle isprob no good as a load for 12v DC. The element will be designed for 240 V and may be too high a resistance (even when cold) for 12v...
On the other hand it may work... but without water it may just blow.
Re: Solar Dump Load
06/20/2013 9:49 AM
The original poster won't have enough power from the panel as it is. The need for a dump load as it stands at the moment is abstruse.
Re: Solar Dump Load
06/20/2013 12:14 PM
Hey... donna start ona me... I justa ansa da question.
I canna da help if she's a dafta da question...
You wanna sleep widda fishes? Eh?
Re: Solar Dump Load
06/20/2013 9:32 AM
Solar dump load...?
Re: Solar Dump Load
06/20/2013 9:47 AM
Re: Solar Dump Load
06/20/2013 9:39 AM
Re: Solar Dump Load
06/20/2013 10:18 AM
Thanks for the replies so far
I've been using the battery bank & the inverter for a week now. After installation I tested it for 2 hours, with all the appliances turned on. Nothing failed & after 2hrs the battery bank voltage had dropped from 12.6v to 11.7v. Another test a few days later with a 'plug-in' electicity meter showed that in the space of one hour I had used 250 watts, hence my statement that I consume 250 watts of electricity per hour.
I thought that if I could charge the battery bank with the solar panels at the same time as discharging them with the appliances they would happily remain at a good voltage. (You've all probably guessed that I'm not an electrician, My rational went something like -' The battery bank is like a water butt full of water. If I turn the tap on It empties at a rate of 1 gallon a minute. If at the same time I pour water into the but at the rate of 1 gallon a minute, then the butt will remain full.)
In the unlikely event that the batteries become fully charged during the day my understanding is that the Solar Charge Controller will send the power from the panels to a dump load, which prompted my question re using a resistive 240v device to accept the 12v 'overflow' (The water butt ir rearing its ugly head again!)
So I really need to know, is my water butt analogy flawed?
kebang
Re: Solar Dump Load
06/20/2013 10:25 AM
<...in the space of one hour I had used 250 watts...> ??? <...250 watts of electricity per hour...>
Please read the instruction leaflet for the plug-in electricity meter again. Then read the read-out again, and please stay away from meaningless units:
  • Power is energy per unit time.
  • Energy is power multiplied by time.
  • Power per unit time is meaningless in this application.
Please advise further: the corrected result is important as it will help determine the correct strategy, tactics and recommendations, and has financial implications that may be important locally.
If the load is lower than the maximum power available from the solar panel, then additional batteries may not be necessary. However, what has been posted so far does not state this.
Good Answers: 918
Re: Solar Dump Load
06/20/2013 11:08 AM
I don't think you need a solar recharge rate at the same rate of usage.
The reason is that you are not trying to remain off-grid, but to create a UPS (Uninterruptible Power Supply) for the duration of the brown/black outs.
What I would recommend is to first do a power budget, which includes the total number of maximum Watts used at any one point in time and the average number of Watts used.
Next, you need to determine the maximum amount of off-grid time you need to operate at your average load.
With that information you can build a battery backup system (basically extend the system you have) to meet those requirements.
Notice that the word "solar" never appeared in my suggestion. The reason is I think your off-grid power needs are measured in hours, not days. Solar is expensive. Even a 250 Watt panel is really only 250 Watts @ its rated voltage (usually 18 Volts at its peak), which translates to 20 Watts or less at the AC side of the inverter. That's a dim light bulb at best for a single panel that costs $500 or more.
You can see that you quickly need lots of solar panels to achieve parity with an average home consumption of 250 Watts (120 VAC) and can spend many thousands of dollars doing that.
Additionally, solar power is really only available a small segment of the day. Usually, this is given in Peak Hours. In Florida it is rated as 4.5 hours a day. That means I will average about 4.5 hours of full output over the course of sunrise to sunset (if the panel is aimed at the Sun). The power delivered by the panels needs to be in sufficient quantity to offset 24 hours of home use plus power that is lost in the conversion process.
As an example, my home consumes about 2500 kWh per month. I would need about 20 kW in solar panels to achieve off-grid power for my home. That is 10s of thousands of dollars to build a system that can power my house off-grid or supply power equal to the rate of discharge on batteries over a 24-hour period.
Since you do not need extended or full-time off-grid power, the cheaper alternative is to size your battery system to your worst-case needs and just trickle charge those batteries off the grid.
The other alternative is a simple generator, preferably natural gas to extend your current system's reach.
If it was me, I would simply add capacity to your battery bank and you can do that a little at a time until you reach enough capacity to manage your worst case needs.
I would also look into what loads you might be able to shed or do without during a power fail to extend your off-grid time.
Re: Solar Dump Load
06/20/2013 10:21 AM
OOps! No idea how that smiley got so big! (Now edited back to normal size)
Re: Solar Dump Load
06/20/2013 12:58 PM
Your load is going to vary according to what happens to be running at the time you are taking your reading....I would calculate the average load at 1kw per hour....Your battery pack@320x12= 3840wh your solar panel array is ok to maintain batteries under minimal load, but you will need a charger running off of grid current as a backup....once the circuit is broken by the charge controller, the panels stop producing electricity, so no dump charge thingy is needed....
Re: Solar Dump Load
06/20/2013 8:20 PM
Now that my incorrectly phrased question has been interpreted (Sorry about the confusion - especially to Mr. Slack who spent time doing maths which would have probably been unnecessary if my question had been posed correctly) my understanding is as follows:-
1. When installed the 400 watts of pv panels will start to charge the batteries at low rate before 9am, probably less than 150watts (daylight here is 6am - 6pm all year round).
2. Between 9.30am - 3pm the panels will be charging at their peak, so on a sunny day I might expect 275-350watts going into the batteries during this period.
3. After 3pm watts will start to decrease.
My conclusion, (& please correct me if I am wrong), The battery bank will remain near full charge if I use 250watts continiously between the hours of 8am & 4pm. In practise, in the early days after installation, I will take battery readings every 15mins after 2pm to establish the best time to switch the inverter off & revert to mains power.
The logic behind purchasing pv panels as opposed to doubling my battery bank is based on finance.
The 100watt panels cost 9,500 pesos, a 100ah deep cycle battery costs 10,000 pesos. The panel will last over 20yrs, the battery 5yrs.
In an 8hr 'maintainance' brown out, which happens during daylight on Sundays, the batteries will not be seriously drained
Good Answers: 141
Re: Solar Dump Load
06/20/2013 11:38 PM
Re: Solar Dump Load
If you are interested in daily production. This is what 4.750 Installed panels produced the last 10 days. Mark also that we had cloudy skies that brought the average down by 20% in this period.
Jun 11: 22.5 kWh
Jun 12: 21
13: 30
14: 16.5
15: 29.5
16: 26.5
17: 27.5
18: 29.5
19: 29.5
20: 28.5 kWh
Note also that when the production per day is on a graph per hour, that it looks like a approximate half of a sinus.
7.00: 0.5 kWh (over one hour)
8.00: 1.3 kWh
9.00: 2
10.00: 2.6
11.00: 2.1
12.00: 3.6
13.00: 3.8
14.00: 3.6
15.00: 3.5
16.00: 2.7
17.00: 1.3
18.00: 0.5
This is recent information to date, about at the height of Ft. Lauderdale, Florida.
Your gain there is to correlate with the given values, divided by a factor 12.
When you use a MPPT charge controller and you "float" your batteries you have no need for a dump at all. Once the charge threshold has been reached, your panels are disconnected from the batteries by the charger as per its specific setting.
This is something real to think about. The cost of the panels Grade A per 125 Watts is $80.00 nowadays. Thus $3,000.00. A MPPT charger costs $370.00.
A very good grid tie inverter (5000 Watts) costs $2,300.00 (10 years warranty)
Deep cycle batteries with Lead Acid I bought for $90.00 ( 6 Volts/230 Ah equals 1.38 kWh @6 volts)
Everything look good?
Submit this Comment
Want to change something?
Plenty of room here
Good Answers: 141
Re: Solar Dump Load
06/20/2013 11:41 PM
I have problems posting a reply. The system doesn't process my answers well.
The given values are "end product" 240- 250 VAC/ 60 Hz, after inverting. Tks
Plenty of room here
Re: Solar Dump Load
06/21/2013 12:44 AM
Many thanks for those figures, I find them extremely useful. Looks like I should produce 1.5 to 2 KW of electricity each day, sufficient to keep my batteries fully charged for 6 to 8 hrs.
The prices for your equipment are very good! Here in the Philippines the best price I have found for a 100w panel is equivalent to $230 (US)
Need to shop around a little more.....
Re: Solar Dump Load
06/21/2013 12:58 AM
Dump load concept is used in the context of windmill generators and NOT in the context of solar PV panels. An unloaded generator, can mean the windmill can run to higher speeds without limit- depnding on system inertia. If very high speeds are reached- it may cause damage to blades, bearings etc- depending on wind velocity at that point of time. Hence dump loads are connected to wind mill generators- which draws current, when batteries are full. IT IS NECESSARY to draw current or apply mechanical breaks there.
There are no so such emergencies with solar panels. Well if sun is shining, but battery bank is full and not drawing current, it will generate a voltage- which is still limited by panel design and within limits- no damage ever occurs. Hence no one uses dump loads with solar panels.
Re: Solar Dump Load
06/21/2013 2:23 AM
Somewhere along the line the difference between power and energy needs to be recognized. Energy is what a battery stores, or what a solar cell puts out over a period of time. Power is the rate of conversion of energy from one form to another. i.e. sunlight to electricity. Power would be measured in watts or possibly kilowatts or horsepower (746 watts). Energy would be termed in watt hours or horsepower hours, or whatever units apply to the system in use. The battery energy would be the product of time times amps times voltage...Have fun...Clint
Clintb3252
Re: Solar Dump Load
06/21/2013 9:13 AM
...or you could get one of these and forget about the solar...It will keep the batteries charged when you have AC, and automatic switches to DC inverter when the AC goes away.
http://www.theinverterstore.com/3000-watt-inverter-charger-12-volt.html
Re: Solar Dump Load
06/21/2013 7:47 PM
Well my original post relating to a 'dump load' for pv power was obviously erroneous!
I'm very glad I posted it though as it has generated masses of valuable information & suggestions for the forthcoming installation; information which very probably would have escaped my consideration.
My thanks to all who have contributed their time & effort to assist me in this.
kebang
Register to Reply 32 comments
Anonymous Hero (5); Anonymous Poster (1); Clintb32 (1); dvmdsc (2); James Stewart (1); kebang (6); keith503 (1); lyn (1); PWSlack (6); SolarEagle (2); tcmtech (1); Tom_Consulting (1); Tornado (1); user-deleted-1105 (2); xyz (1)
