Previous in Forum: Detection of Inter-Turn Winding Short-Circuit Fault in Single-Phase Transformers   Next in Forum: Using Existing Outgoing Feeder as an Incomer (415v Distribution Board)
9 comments
Why Is Delta-Wye Transformer Used In Distribution Transformer
08/15/2013 11:39 AM
Hi guys.
would like to know why does most distribution transformer uses delta-wye connection. What are the reasons behind it.. and why are most instrument transformers wye-wye connected?
Please advise !
Thanks !
There is no limit towards how much one can learn.
Good Answers: 444
Re: Why Is Delta-Wye Transformer Used In Distribution Transformer
08/15/2013 3:59 PM
Deltas don't pass third harmonics, wyes provide a convenient neutral/grounding point.
08/16/2013 4:59 AM
Dear Mr. RAMConsult,
During our college study days, my Professors have taught that STAR- CONNECTION - because of 120 Degree, Phase Angle the 3rd Harmonics are totally nullified. But your point is Delta connection nullifies 3rd Harmonics. Pl. clarify.
DHAYANANDHAN.S
Good Answers: 444
08/16/2013 12:14 PM
Mr. Dhayanadhan:
In a delta the third harmonic currents circulate within the delta and turn into heat thereby increasing the loading on the cooling system.
Wye connections are different because of the neutral point (grounded/ungrounded), where it appears (Primary/Secondary), and whether the source is grounded or not, making a total of sixteen different scenarios (which I will not bore you with, for more info see the Westinghouse T&D Handbook).
To simplify(?), for certain wye-wye grounding configurations, the third harmonic current has no choice but to pass through the transformer, appearing in the phase to neutral voltage but not in the phase to phase voltage (which is probably the case that your Professors taught you). If there is a delta tertiary then the third harmonics will be suppressed regardless of either wye windings' grounding.
In general from ibid "..The paths permitting the flow of third harmonic currents are determined by the system and transformer zero-sequence circuits..." (which are even more arcane (mysterious, secretive) than the above discussion!)
08/19/2013 12:28 PM
Thank you very much for your reply. Indeed a good amount of explanation given by you, which will help to up-date the knowledge. What we studied in the college and what we see in the Industry varies some times.
You have mentioned "...........making a total of sixteen different scenarios (which I will not bore you with, for more info see the Westinghouse T&D Handbook)."
I never feel bored, and I want to know more about the 6 different Scenario. I also request you to give me the web-link where I can down-load the Westinghouse T&D Hand Book or you can send to my cr4 personal messaging system.
Thanks,
DHAYANANDHAN.S
Note: Sorry for delay in acknowledging your reply.
08/16/2013 7:53 AM
GA
Perfect answer.
Good Answers: 181
08/15/2013 8:36 PM
The various types of transformers are used for many different reasons. Some economic, some may be phase sequencing, along with the many other requirements a transformer is used for.
Unfortunately for you, you have to research why they are used in each circumstance.
Tell me why you think Yy is used on MV instrumentation or why ∆Yn is used for MV/LV distribution? I'll help if you help yourself.
08/15/2013 10:44 PM
Wye xformers are used in 4wire systems for increased current capacities as their leg to leg potential value is derated by 1.713. As the neutral is center tapped the unbalanced loads are a non issue. Delta xformers are better for transmission as their leg to leg potentials are higher to compensate for I2R losses. Ie 120/208 in commercial and 120/240 in residential.
Don't believe everything you read on the internet just because it's qouted by a famous person. Benjamin Franklin
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
08/16/2013 4:50 AM
3-wire delta is cheaper than 4-wire wye, not just for cable costs, but narrow trenching if its underground, so you would only use 4-wire if you have a currently carrying neutral.
BSEE but always learning
Good Answers: 27
08/16/2013 8:37 AM
The type of transformer connections (wye or delta) has each own individual and unique characteristics.. They are connected / terminated depending on the needs or as governed by its intended application. Intended application therefore will determine how, to take advantage of this inherent and fundamental connection characteristics..
You need to study to better understand the basic theories relating to transformers.
vsar
Register to Reply 9 comments
1capybara (1); Andy Germany (1); cvogel (1); dhayanandhan (2); RAMConsult (2); TonyS (1); vsar (1)
