Previous in Forum: Unbundling To Save Money   Next in Forum: Understanding Engineers: Which Mindset do you Most Agree With?
20 comments
Hydraulic Pump Will Only Go Down
08/24/2013 12:14 PM
I recently purchase a hydraulic pump double acting i conected and no matters what button i press up or down will only go down please any help will be apreciated thanks in advance
Pathfinder Tags: Double acting hydraulic pump
Re: Hydraulic pump will only go down
08/24/2013 12:18 PM
Read the instructions.
Reverse the hydraulic connections.
Take it back and ask for help.
With no useful information from you, all I can say is read the instructions.
08/24/2013 12:23 PM
I bouth it from ebay and there is no instruction
08/24/2013 12:40 PM
I shouldn't have to tell you this, but if you can find the manufacturer's web site, you can download the pump manual.
Seriously, do some searching on your own.
08/24/2013 1:07 PM
I been doing the search thats how i end up here but thanks
08/24/2013 12:24 PM
Thanks
08/24/2013 12:40 PM
This is the link for the pump http://www.ebay.com/itm/12-VDC-Dump-Trailer-Pump-Double-Acting-Hydraulic-12-VDC-3-Quart-/221230564450?pt=BI_Pumps&hash=item33825e8462
08/24/2013 12:44 PM
OK,
Do you want someone to take you by the hand, wipe your nose and do the trouble shooting/hookup for you?
READ THE MANUAL!!!!!!
<unsubscribe>
08/24/2013 12:48 PM
There is no manual but thanks
08/24/2013 1:26 PM
So how are you getting it up in the first place if it only goes down?
I am guessing the pump motor runs when it's trying to lift?
Is all of the air bled out of the pressure lines?
is the relief valve working properly or is it stuck?
Is the pump actually pumping fluid or is the pump gearset broke or worn out?
08/24/2013 2:00 PM
I desconect the hose and will release the loading ramp when i said is going down is because is a trailer the loads the front so down will be opening the ramp and close will be lifting the ramp thanks for your help
08/24/2013 2:02 PM
The pump release true only one of the hoses
08/24/2013 1:42 PM
Did you notice that the e-bay link includes contact e-mail address?
Now a hydraulic pump is such a simple machine (Archimedes designed several) that a little simple exploration and analysis of the mechanics should tell you how this pump should work. We cannot do this for you. You may find from your exploration that this double action pump is not what you wanted. What you actually wanted was a reversible pump. Now if you find out that the valves in this pump will allow a reversing liquid flow but only if the motor reverses rotation then a miss wire or bad switch may be your problem.
08/24/2013 1:57 PM
I ask the seller about the manual no answer back thanks for your help this pump is for a car carrier if this help
08/24/2013 2:37 PM
I get the impression that english is not your primary language?
What we need is the pump brand and model numbers. Everything else is irrelevant.
Do you have fluid in the pump to begin with and will it shoot fluid out of any port when the hoses are disconnected and the motor is ran?
08/24/2013 3:00 PM
Re: Hydraulic Pump Will Only Go Down
08/24/2013 10:58 PM
You have a 12 volt lift pump package used to lift a load when running. To lower the load the down button is pressed to allow the hydraulic fluid back into the pump. If it will only pump down the hose is connected to the wrong port on the clyinder. This pump is normally used on single acting clyinders. The UP button runs the pump and the DOWN button releases the load.
Good Answers: 203
08/25/2013 12:45 AM
Does the pump have a reservoir on it? #1-- If yes, is the volume of the reservoir on the pump almost as large as the volume of the cylinder?
If yes- you have a single action system and the pump only raises the cylinder. The weight of the car is what pushes it back down when you push the down button.
If the answer to #1 is no--you have a double action system where the pump transfers the fluid in both directions and the output of the pump is transferred to the other end of the cylinder. If this is the case, disconnect each hose from the cylinder one at a time, hold a can or absorbent pad under the hose, jog the motor for less than 1 second and see if the fluid is flowing in the correct direction. If they are in correctly the motor may be miswired or the pump broken. Trouble shoot it from that point if necessary.
If you bought it from e-bay, was it used or new? Was it missing any parts? do you trust the guy you bought it from?
Good Luck, Old Salt
08/25/2013 2:48 PM
as i seen on e bay ,the pump runs with pilot operated solenoid switch the round one (mounted on the motor ) and there are 2 solenoid valves (the black coils ) which seems to be used for direction (A & B ) kindly check the connections of the hand console ,i think the both button,s output is going to same coil.or you can energize the power and exchange the coils .i think it will solve the problem .motor connections shows that its single direction .just the flow is controlled by 2 black coils.
regards
love4everyone
08/25/2013 3:43 PM
Thanks to every one who try to help me i finally found the problem was the remote on the pump was build for a 3 cable and they converted to a 4 cable i change the remote and is finally working , thanks for the patience on my english . I speak spanish
08/26/2013 9:15 AM
Hey man, what's goin' down?
Register to Reply 20 comments
Helppleasethanks (9); James Stewart (1); lyn (3); Nebrfarm (1); old salt (1); redfred (1); sohail0110 (1); SolarEagle (1); tcmtech (2)
