Previous in Forum: Flow Rate Question for Alcohol   Next in Forum: Electroluminescent Inkjet Printing
9 comments
How to Purge a Natural Gas Pipeline?
09/04/2013 5:38 AM
There all,
I need solution to the problem below:
I am in charge of handling the purge in natural gas pipeline
My question is how to calculate the amount of nitrogen in case of purging 30-inch, 16km-long natural gas pipeline
and how to calculate the amount of natural gas to serve the natural gas pipeline
finally, what is the essential procedure of purging and serving pipeline for example
purging pressure of nitrogen and natrual gas
thank you so much
Re: HOW TO PURGE NATURAL GAS PIPELINE?
09/04/2013 5:43 AM
Start by calculating its volume.
Are there no procedure documents surviving from previous similar activities that could be adapted to suit, on the basis of not reinventing the proverbial wheel?
Why was this not considered and reviewed at the HazOp Study so as to be ready in time?
09/04/2013 5:52 AM
And who is in charge of you, pray tell?
09/04/2013 7:23 AM
I hope you have a flare stack
Re: How to Purge a Natural Gas Pipeline?
09/04/2013 9:40 AM
Find a job you know something about.
You are a danger to society!
09/04/2013 11:12 AM
I hope this isn't the one you're talking about.....
http://www.naturalgaswatch.org/?p=210
09/04/2013 3:52 PM
I believe it is in the relevant standard. I don't know what the standard numbers are or what countries standards you are working to thou, but there should be standards for this sort of testing and operation. Please look them up.
Alternatively hire a professional contractor to perform said work.
09/04/2013 10:12 PM
The United States has averaged about ten natural gas pipeline incidents a month. The average property damage per incident is about $14,000,000. Fortunately the fatality rate averages to less than one death every other incident but usually somebody does get hurt every incident.
If the only place you can get information on how to safely purge a natural gas pipeline is anonymously from a public forum,
RUN!
Do not even try to get your final paycheck. Just run. Get away from your employer before they kill you.
Hobbies - CNC - New Member
09/05/2013 12:13 AM
Deer awl,
I'm in charge of re-manufacturing spent plutonium fuel rods.
I figure that we chuck them up in a lathe and turn it down because the bad part is on the outside.
Right?
What size do I need to turn it down to and how much with each pass.
What I really need is the calculation on RPM versus mm per pass?
Thank you so very much!
BA
Reply Off Topic (Score 6)
Good Answers: 176
09/06/2013 9:54 PM
This paper, Purging Air from Piping and Vessels in Hydrocarbon Service, is a virtual public service by the small engineering firm that hosts it.
His opening statement is profound: "After motor vehicle accidents and underground excavation accidents, purging air from piping and vessels in hydrocarbon service is the next most dangerous activity undertaken within the oil and gas business."
http://www.muleshoe-eng.com/sitebuildercontent/sitebuilderfiles/s4Ch19purge.pdf
Fredski (1); Iris (1); jack of all trades (1); lyn (1); Original_Macgyver (1); PWSlack (1); redfred (1); SolarEagle (1); Tornado (1)
