Previous in Forum: Power Factor   Next in Forum: Max. No. of Three Phase and Single Phase Circuits to be Connected
12 comments
Capacitors
09/12/2013 1:26 PM
Sir,
I have some problem when I am trying to increase the power factor for motors. I have fixed new capacitors for 20HP motors 2 nos and fixed 6 KVAr 3PH capacitor for each motor.Then I have checked the Power factor,it shows 0.57.Why not increasing the power factor and what will be the reason.
Thanks
Re: Capacitors
09/12/2013 2:33 PM
Where are you measuring the PF? On the motor leads only, or at a point that includes both the motor and capacitor?
Good Answers: 445
Re: Capacitors
09/12/2013 4:02 PM
How about telling us what the PF was before you installed the capacitor. Also important is more info on the motor type, ratings, etc., and exactly what information/calculations/logic that you used to select those particular units.
Good Answers: 140
Re: Capacitors
09/12/2013 4:11 PM
Now come on RAMC... the ones they chose from the catalogue looked pretty.
Re: Capacitors
09/12/2013 4:42 PM
How are you measuring the PF?
Re: Capacitors
09/12/2013 4:42 PM
Re: Capacitors
09/12/2013 5:05 PM
Do you have a load on the motor? If the motor is unloaded, that looks about right. PF increases with motor load.
You have to actively participate in the manifestations of your own joys and good fortunes - they are not ready made for the taking, they are available for the making.
Good Answers: 804
Re: Capacitors
09/12/2013 11:13 PM
  • "Do you have a load on the motor? If the motor is unloaded, that looks about right. PF increases with motor load."
Bingo. For all we know, the unloaded PF was .2, now with the caps it is at a .57, which would indicate that the caps are accomplishing something very significant. But that would also mean the initial premise was flawed at the outset.
Re: Capacitors
09/12/2013 11:24 PM
Dear Mr.marariayan,
How did you connect the two Capacitors - Is it in series or is it in parallel. What was the Power Factor before connecting the Capacitors.? What is the supply frequency. Is it 50 c/s or 60 c/s.? Where did you connect Capacitors.?
DHAYANANDHAN.S
Re: Capacitors
09/12/2013 11:42 PM
Size of PFCC depends on speed,voltage and frequency and % load on motor.
pnaban
Re: Capacitors
09/13/2013 3:31 AM
Exactly. If the motors are not doing much work, their power factors will be pretty low.
Good Answers: 40
Re: Capacitors
09/13/2013 1:33 PM
"Pretty-good-answers, all..." however, given that mararjayan NEVER (since 2011) made it back to his first request:
"What are the precuations to be taken before energising a 250 KVA oil type,11KV/440V transformer of a unitised substation and how to check the transformer oil is good or not. Experts please give me the answer."
...nor has he followed-up with further info after this:
"I have a Generator 3PH,415V. There is no name plate on it. How do i know the capacity(Kva) of generator.Please let me know."
... I doubt that he will find his way back here, so as to receive this "Well-Wish":
May the road rise up to meet you....rather than you stumble-and-fall-nose-first.
May the wind always be at your back....so that no sparks might fly into your face.
May God hold you in the palm of His hand....keeping you far-away-from any energized circuits.
(truly, wishing him well...)
Re: Capacitors
09/22/2013 7:26 PM
It might depend on how you connect the capacitors to the motor working of a 3 phase supply. You may want to connect the capacitors in delta configuration and then connect the bank of capacitors in parallel with the supply at the terminals of the motor. Let's say that the capacitor delta configuration (a trianglular arrangement is A, B & C. L1 goes to point A; L2 goes to point B and L3 goes to point C. Or you may connect a synchronous motor, running on "no-load", in parallel with the motors. Make sure to increase the DC excitation current of the motor to give a leading power factor.
Register to Reply 12 comments
dhayanandhan (1); JRaef (1); Mike W (1); ndt-tom (1); North of 60 (1); pnaban (1); PWSlack (1); RAMConsult (1); SolarEagle (1); Tornado (1); triniboy (1); wareagle (1)
