Previous in Forum: Motor Burning   Next in Forum: kVA Rating Question
Capacity of C.B.
11/02/2013 12:56 AM
Dear sir
How can we calculate the capacity of circuit breaker in MW.Please clarify this with an
example
Thanks
Pathfinder Tags: capacity of C.B.
Re: capacity of C.B.
11/02/2013 1:07 AM
V A √3 cosφ / 1,000,000
Good Answers: 141
11/02/2013 6:44 AM
I guess it depends how you look at it.
The value mentioned by Tornado is that of the 3 breakers together. If they have a mark on each of them it should be probably divided by 3.
It might be a language thing but "CAPACITY' of a breaker? Breakers normally have the load in AMPS (or in your case a fraction of MA( mega- amps) or a multiple of kA (kilo-amps) Breakers that size will most commonly be executed as (3)coupled singles.
Plenty of room here
Re: Capacity of C.B.
11/03/2013 2:14 PM
Easy. Phone the manufacturer's technical helpline with the model and serial number, and ask.
11/04/2013 1:33 PM
I'm having a hard time getting over the OP's handle...
common knowledge...less common than common sense
10/23/2016 11:09 PM
Me too. Long ago, we used to joke about using a 50-cent transistor to protect a $500 fuse, in an orbital vehicle, where field service can become problematic.
The glass is not half empty, or half full - it is half-filled with water and half-filled with air - hence, fully filled on the whole!
dvmdsc (1); PWSlack (1); richpress (1); The.Tinkerer (1); Tornado (1)
