Previous in Forum: Memory Backups   Next in Forum: Orifice Plate and Flow Transmitter
Simatic S7 300 Vs 1200 CPU
11/23/2013 3:11 AM
Dear All,
What is different in price and performance of Simatic S7-300 compare to S7-1200.
Because i am confuse and lost.
Please advise me
Thank you
Re: Simatic S7 300 Vs 1200 CPU
11/23/2013 9:55 AM
I advise you that you contact the manufacturer about the differences between these two products. CR4 does not sell any product. Once the manufacturer gives you an answer, if their answer still baffles you then bring that answer to us for a translation and analysis.
11/23/2013 10:16 AM
Go here: GlobalSpec Electronics at the time of this page.
They will help you.
Good Answers: 32
11/23/2013 10:44 PM
Don't you know your requirements?
Generally you know the speed of operation or cycle time you may need. You may also know the number and types of Inputs and Outputs from and to the process. Once you have these parameters then you select the PLC that fits into requirement and often any manufacturer can suggest a suitable PLC for the purpose.
Now that you are starting from PLC part numbers without stating your actual need, no one can judge what is suitable for you. You are not going to use everything that PLC offers and most of these models may be flexible in configurations and that may be the criteria for the manufacturer to have different model or versions. Generally higher part number is for the latest version and smaller numbers may get phased out from production line or may become obsolete.
Rightly stated, that people here are engineers willing to extend small help and they do not advocate for any product type or product make so asking such question with the support team of the product manufacturer is the only right way to act upon.
11/25/2013 3:40 AM
The best thing to do is to pick up the phone, and talk to the local Siemens Sales Office. The number can be found using an internet search engine.
11/26/2013 4:07 PM
I hear you.
The only time we use Siemens where I work for the control on our process skids is when the customer is European based and they pick the CPU and I/O cards for us. I find the Siemens site to be difficult at best.
As the others said - go to Siemens and let them help you. I have built about a dozen systems with various Siemens models, various sub-models of the the S7-300 included and I sure wouldn't try to answer your question.
12/15/2013 6:55 AM
Dear All,
Here with some infomation,where i have found in Siemens website,
SIMATIC S7-1200 Integrated technological functions
Counting, positioning and closed-loop control with S7 CPUs Overview
Description
The S7 CPUs offer different integrated functions for implementing simple counting, positioning and closed-loop control tasks.
S7-1200
Depending on the CPU, up to six high-speed counters are integrated, three at 100 kHz and three at 30 kHz. Optionally, using Signal Boards, 200 kHz (24 V or 5 V version) is available. They are used for the precise monitoring of incremental encoders, frequency counting or high-speed counting of process events. Two high-speed outputs are integrated into the SIMATIC S7-1200 controller for use as pulse outputs. They can be used for the open-loop speed and position control of stepper motors and servo drives. They are easily configured using an axis technology object along with the internationally accepted PLC open motion function blocks included within the SIMATIC STEP 7 Basic engineering system.
Intuitive and efficient engineering in the TIA Portal
The engineering of the S7-1200 offers a project view for all tasks, up-to-date user guidance for intuitive and graphical configuring with intelligent drag-and-drop technology, uniform data storage and integration of SIMATIC WinCC Basic.
TIA Portal - Engineering for the S7-1200
In the project view, the project tree (1) shows all the hardware components that are used and the associated program structure and data elements. This provides direct access to the appropriate devices, folders and special views that support the user with the automation tasks. Technology functions, such as closed-loop control or motion, are embedded in the engineering. This includes parameter assignment as well as commissioning functions.
The control panel included with the SIMATIC STEP 7 Basic engineering system simplifies the commissioning of stepper drives and servo drives with a pulse/direction interface. It provides both automatic and manual control of individual single motion axes as well as online diagnostics information.
Below the axis parameterization (2), the user program (3) is displayed. This program editor supports efficient programming in LAD, FBD and SCL using statements and libraries (4).
Symbolic program elements can be directly assigned between the PLC and HMI editors using intelligent drag-and-drop functions. HMI editors as well as PLC editors can be efficiently used together in the engineering environment.
Devices and networks are easily configured using graphical editors, thanks to the structured interface.
To the top of the page
Decrease text sizeIncrease text size Text Size
PID Control
PID Temperature Control
S7-1200 integrated functions
S7-300 integrated functions
More information
Brochure: "SIMATIC Technology for technological tasks"
Folleto: "SIMATIC Technology para tareas tecnológicas"
Brochure: " SIMATIC Technology pour tâches technologiques"
Brochure: "SIMATIC Technology per compiti tecnologici"
SIMATIC S7-1500
SIMATIC S7-1200 CPUs
SIMATIC S7-300 Compact CPUs
SIMATIC STEP 7 Engineering Software
Case studies for SIMATIC S7-1200
Regards
Good Answers: 804
12/27/2013 4:34 PM
They are not really comparable other than as in Apples and Oranges both being tree fruits.
The S7-1200 is a micro controller, intended to be cheap and small with limited functionality, limited expandability and intended for use in highly controlled environments, ie cool enclosures, no vibration, clean power etc.
The S7-300 is a much more robust controller that can be expanded to much higher levels of I/O count and memory capacity. It is intended for more complex machinery or processes and is better suited to handle less than perfect environmental conditions. There are a myriad of functions available in the S7-300 that you cannot do in the S7-1200.
But if the S7-1200 does what YOU need to do, and you are confident that you can keep it free from harm, then there is no reason not to use it.
Register to Reply 7 comments
aikhh (1); JRaef (1); lyn (1); Phys (1); PWSlack (1); redfred (1); Shyam (1)
