Previous in Forum: Pump   Next in Forum: BXS Type Heat Exchanger
9 comments
Moisture Calculation
12/17/2013 1:10 AM
Hello,
I would like to calculate the water content in air when temperature and Relative humidity are given.
other than chart ,can I use some excel formulas or suggest some website who can run similar program.
Good Answers: 141
Re: moisture calculation
12/17/2013 1:22 AM
You need to make a sheet, based on the psychometric tables. These tables are pretty much loaded and working it in Excell needs some imagination. Pressure can be a next parameter.
Plenty of room here
12/17/2013 2:16 AM
Agree with #1↑. Create a table in a second Excel sheet on the basis of the data in a psychrometric chart, then use the =Lookup function in the first.
12/17/2013 3:24 AM
Try Googling "psychrometric software".
Re: Moisture Calculation
12/18/2013 2:16 AM
Psychrometry analysis software is available. Use search engne to check it and use it.
12/18/2013 3:10 AM
SMathur,
There's no end of free and low-cost psychrometric analysis programs that you can download to your PC. Take your pick!
As for Excel, here's an app available from the DOE:
Good luck,
Zvi
12/18/2013 3:36 AM
Problem with the ASHRAE link. Try this: ASHRAE psychrometric plug-in
Good Answers: 58
12/18/2013 9:03 AM
I use a chart distributed by Shaw. If you want to do the math yourself you can use the equations used by instrument makers such a Davis. If you want truly technical data, try NOAH or NIST.
12/18/2013 10:13 AM
That would be NOAA rather than NOAH.
12/18/2013 10:25 AM
Download a free moisture calculator. I use it all the time for compressed air. Lovely little programme, numerous options, but you have to know what you are doing.
http://cosaxentaur.com/downloads?files_category_id=107
Register to Reply 9 comments
dvmdsc (1); horace40 (1); mrswamy (1); PWSlack (1); Tornado (2); welderman (1); Zvi (2)
