Previous in Forum: Compressor Efficiencies   Next in Forum: Ventilation Fan
9 comments
Pump Curve
01/02/2014 11:36 PM
Dear Friends,
I'm new mechanical engineer. Could you guide me how to design pump curve. I was given an assignment to construct a pump curve.
The information given is Q=4.2Mld and H=30m
please let me know the steps should I do before designing.
Thank you :-)
Re: Pump Curve
01/02/2014 11:46 PM
You need to design a pump. From testing the pump, you will get a curve.
Now, do you want to design a pump?
If so, go to the net and search for "pump design guidelines".
You will find the steps required there.
We don't normally tutor here.
HOW TO design a pump system
Re: Pump Curve
01/05/2014 9:41 AM
Dear Mr.lyn
I have opened the link given by you.
Thank you for giving a link which gives good amount of details.
I have noted there that One Gallon = 8 Pounds. But in our college days we have been taught that One Gallon = 10 Pounds. Also we have been taught Imperial Gallon (but I do not remember how many Pounds) and pl. clarify this. Perhaps it will be like Long Ton and Short Ton.
DHAYANANDHAN.S
Re: Pump Curve
01/05/2014 12:33 PM
One U.S. gallon = 3.785 liters. If water (at standard temperature) it weighs 8.33 pounds.
One imperial gallon = 4.54609 liters ≈ 10 pounds of water.
Re: Pump Curve
01/03/2014 12:31 AM
This does not sound like a well formed question from your instructor. For instance, is (4.2, 30) a given point on the curve, or are (0, 30) and (4.2, 0) the endpoints of the curve?
In either case, the curve could be approximately a quarter ellipse containing the point(s).
Another recent question revolves around 4.2 ML/d; by chance are both questioners from the same design team?
India - Member - Mechanical Engineer Engineering Fields - Petroleum Engineering - Mechanical Engineer
Re: Pump Curve
01/03/2014 12:41 AM
Are you trying to create a Pump System Resistance Curve or Pump Performance Curve.
If system resistance curve is required use the Hazen - William formula to do that, while if you need performance curve then you will have to contact the pump supplier since, performance curves are done by them based on pump testing.
Good luck...
Varun Passi
Re: Pump Curve
01/03/2014 1:59 AM
I'm trying to create Pump Performance curve. Oh, so we cannot create the curve ourselves?
Re: Pump Curve
01/03/2014 2:12 AM
Re: Pump Curve
01/03/2014 2:38 AM
The curve is a result of testing of the pump. If you test the pump you can obtain the curve.
You can not design the curve. But you can design the pump to a certain degree to have a desired behaviour on the curve.
Re: Pump Curve
01/03/2014 2:53 AM
Noted...really understood. Sorry for any incovenience
Register to Reply 9 comments
abu_syifaa (3); dhayanandhan (1); IdeaSmith (1); lyn (1); Tornado (2); varunpassi (1)
