Recently I have encountered with a problem on selection of Relative humidity at constant Temp & Pressure for design of Shell & tube heat exchanger.
The parameter are given as under Design DBT= 41 C and humidity levels are mentioned as 93% & 27%.the exchanger has fluid of air on shell side ( 135/50 c)and cooling water on tubes side (32/40 c).
I have selected higher humidity which has given more heat duty but when I Checke the calculation with lower RH the duty has reduced but area has increased and net Overdesign margin will go on negative sides.
My question is there what is the safe rule for selection of RH at constant Pressure & Temp ,because higher RH selection gives Higher duty and low area, while lower RH selection provide Low Duty and higher area.
