Previous in Forum: Best Varnish for Hub Motor Stator Coils   Next in Forum: Trigeneration Sizing?
11 comments
Mechanical Design
01/13/2014 4:34 AM
hey guys help me with on this assignment
through calculations, select a motor and a battery that can be used to drive a load of 300kg at a maximum speed of 80km/h on a frictionless flat road. select a battery that can last 2hrs wen the load is running at maximum speed.(you may make reference to any metric design tables and formulae) show all the necessary working
Re: mechanical design
01/13/2014 4:58 AM
Do we get to ignore air drag also?
01/13/2014 5:06 AM
i suppose so,
01/13/2014 5:18 AM
Then you don't need a motor or battery at all.
Refer to Newton's first law.
01/13/2014 11:14 AM
just pretend its a Mag-Lev track and the wind is at your back
01/13/2014 5:31 AM
initialy the load is at rest,
01/13/2014 6:51 AM
Then you only need to get a battery which can supply enough energy (½mv²) to get it up to speed. Decide on the motor and gearbox dependent on the spec of the battery; unless you have any other constraints involving how quickly you need it to get up to speed.
01/13/2014 6:05 AM
If you show us how you are are doing it the maybe you will get some help and pointers.
I daresay no one is just going to do it for you.
The help you get out out is proportional to the work you put in.
That's Dels first law of CR4 posting.
01/13/2014 7:45 AM
Dels first law of CR4 Posting.......
I think he was sick that day when it was covered in class.
01/13/2014 8:27 AM
Del is right.
  • Do your own homework. CR4 is not a homework cheat site. While some here might relish the opportunity to sharpen up old rusty skills by working the homework problem, consider the following and consider it well. If you cheat on your homework by using someone else's answers, you are only cheating yourself, because the purpose of any homework or other academic assignments is to help you learn - by practice, repetition, and self-discovery.
@Fredski,I think he's serious.
01/13/2014 8:33 AM
you're joking, right?
Re: Mechanical Design
01/13/2014 10:45 AM
This cannot be done from the information provided. Electric motors require friction to move something on a road. Traction is friction.
Register to Reply 11 comments
Fredski (2); lyn (1); phoenix911 (1); Randall (2); redfred (1); thabo_ken (2); Tornado (1); user-deleted-1105 (1)
