Previous in Forum: Cats Alive! - A Quantum Puzzle   Next in Forum: Koken Barber Chair
Good Answers: 59
Useful Repurposed Items
01/22/2014 7:21 AM
This idea comes from Kris's comment over here. His question:
Now that would make for an interesting chat - things that have been 're-purposed' as tools. Inverted commas because the phrase is not familiar to most Brit ears. For instance, I carry some emery boards (those things used for filinfg nails) in my toolbox. They're great for getting in awkward places. A toothbrush can be surprisingly helpful. I'll not go on here because it's potential fun - 'what strange stuff do you have in your everyday toolkit and why ?.
Re: Useful Repurposed Items
01/22/2014 8:05 AM
Thank you, Savvy.
I'm at a loss to start, so I'll kick of with an 'easy one'. Bit of broken soap. If you have a set of draws that's a bit sticky then rubbing soap up and down the sliders can usually solve it. It works especially good with flat-pack furniure.
This one is not exactly 're-purposed', but if you have to bash a nail into something then blunt the end first. It prevents the wood from splitting.
Mt toolkit includes a 'bicycle spanner'. Doesn't look very proffesional, but it's very useful when you have you head stuck in a tight corner.
OK, that's all fairly basic, so do you have any tips to pass on ?
I was once playing in the garden and needed to level it. A length of clear plastic tube works very accurate as a level.
Here is one for people to ponder : you need to swap out a domestic radiatior, You don't want to drain the system, and you don't want to freeze the pipes. The answer is....
There are more questions, but the essential question is about good improvization techniques you have found.
01/23/2014 8:02 PM
do the work when the boiler is hot !
01/22/2014 8:15 AM
Oh Savvy, you shouldn't encourage him.
Next thing you know he'll be up in your loft, chewing the wiring and making a drey in the insulation.
Indeed 'Repurposed' does grate on the ears of those who hate nouns being turned in verbs.
Next thing we know you'll be 'gifting' us something.
'Give' is the verf, 'gift' is a noun... oooh and don't start me on illiterate athletes hoping to 'medal' or 'podium'.
Now look what you've done, I need a lie down or my string and feather
To be vaguely on topic, Bulldog clips and clothes pegs are V handy as mini clamps to hold stuff that is gluing, or to put on squirrels tails
Good Answers: 114
01/22/2014 9:51 AM
I agree, I think you should be tasked with the job of routing out this repurposing of nouns.
01/23/2014 9:50 AM
Almost any noun can be verbed!
01/22/2014 10:33 AM
It just has to be clothes pegs. Where is the fun if nobody will tell you off for it ?
Facebook has several very funny engineering type sites, but there's no point my linking them unless people have an account. They're just <whoevers> account where people illustrate slightly mad uses for everyday things that solve problems. I'll not post any links now because I think it's against CR4 policy, and Facebook has more viruses than I could point a stick at.
You go and stringthertize yourself and I wil think on it .
01/22/2014 8:46 AM
One of those cheap, soft metal screwdrivers (the sort you can get sets of in the "£1" shops) with the last ½" of the blade bent over at 90º makes a very handy tool for levering DIP pack ICs out of their sockets, oiking wires out of looms etc. I've had one in my tool-roll for about 20 years (next pocket to the dentists' mirror, the toothbrush and the emery-boards).
Bit of ~0.5mm dia piano wire with the end bent into a hook is in there as well (good for more deeply buried wires).
01/22/2014 10:24 AM
I like this . A cheap and nasty driver is great for when somebody has mashed the head on a screw. You can bash the thing in and then get some purchase on it.
Dental floss can make for a good grip in certain situations, and it's not bad for emergency plumbing. Toothpaste can be quite handy (amazing how hard it can set), but given that it's available in most bathrooms there isn't much need to carry any.
Dentist mirror is a good idea, and I also like the idea of a small but powerful magnet. Very good if keys are dropped down a drain, especially when a vehicle is blocking the works entrance .
Plain old piece of wire (coat hanger size) is handy. That half used tube of mastic ? great for unplugging the thing.
'Repurposed' is now my favourite word of the week, very much worthy of adoption by Brits. If anyone can express it better then I'm all ears.
01/22/2014 10:49 AM
A tosser working on the factory roof a few months ago managed to drop his car keys down a drain-pipe, leaving his car blocking everyone else in the car-park. It's a plastic pipe, so they tried the magnet trick. Trouble is it's fixed with a stell bracket about 6ft down, which the magnet wouldn't pass. Eventually got the guys from Dynorod in the unit next door to run a camara + grab down. The keys had shot round the bend at the bottom and gone about 10ft under the car-park, so the magnet wouldn't have worked anyway (unless it was on a very flexible rod).
01/22/2014 9:46 PM
Did you really think I would forget that one ? Too funny, though I haven't figured the 'perfect answer'. I think we've all 'been there, done that' type thing.
Right now my front door keys are not working. No WD-40 in sight. Drop of Olive Oil ? Any improvised suggestiions will be greatly welcomed. What normal household good can lubricate a normal doorkey ?
01/23/2014 7:16 AM
Everyone should go to a DIY store and buy the correct key cylinder spray and give all cylinders, including the ones on your car(s), a small shot, working it in with the correct key.
It has a thin liquid that carries tiny particles of graphite into every tiny corner.The liquid then evaporates. Dry lubrication.
WD-40 is only to be used in an emergency as it, as do any wet lubricants, attracts and holds dust. Not good in the long term. Many cylinders have a small hole from inside to outside, that allows air with dust to pass through...its part of the design requirements....
If any lock even starts to get faintly heavier to turn, lubricate it immediately. If this does not fix the problem, replace cylinder before you get locked out...or break a key - and get locked out!!
All possible door cylinders need to be of the type that allow a key to be inserted from both sides at the same time AND turned, otherwise a jammed lock from the outside is possible with the cheaper ones that only allow one key to be fully inserted at a time and turned, then it is also jammed on the inside......
Some Yale types do not have a key slot o the inside, cars also not of course!!
Never use a drill to try and remove a cylinder, unless you also have the special locksmith's tools to finish the job as many cylinders have specially hardened parts that break or damage any but the worlds hardest drill bits.
I used special 3.2 mm drills and then a specially hardened self cutting screw into that hole. Once the screw was in place, a special puller is used to break out one half of the cylinder and allow access for the special cylinder key to open the door.
I can make and post Fotos of the tools if anyone wishes.....
Even opening a door without the special Locksmiths Key, after you have removed the cylinder is almost impossible as well......and not knowing exactly how everything works will cause severe problems....seen it several times.
For some cylinders a high speed Dremel with a specially hardened bit (around US$50:00 each) can be used, but the special key is still needed of course....one that simulates the now missing cylinder....
Remember the prices Locksmith's charge to come out "in" hours, let alone "after" hours......? You can buy enough spray for the whole street and have money left over.......for the price of one visit!!!
01/23/2014 11:43 AM
I have found that a short piece of coping saw blade (3"), wrap the end with tape with the teeth pointing towards the tape and when inserted the teeth hook the broken piece and you can usually pull it out.
01/23/2014 11:32 AM
Frozen with ice? That happened to me years ago with the torch inside. My wife's idea worked like a charm. Small teapot filled with hot cooking oil; soak/heat key in it and insert in lock. Both thaws and lubricates.
Lehman57
01/23/2014 12:20 PM
It's a fairly new door ( about 2 years), so I'm a bit puzzled why it's gone cranky. We've had some lousy weather over the past few months but I don't think driving rain is the problem. Having read Andy's comment about WD-40 and dust I'm now even more stuck ! The thing still works but is getting increasingly hard.
I can swap the offending lock out, but it's still a bit of a mystery. The key will not fully insert (without some harsh shoving), and looking at the dust that gets swept against the door I'm inclined to think that's where the problem is. My first thought here is to lube the key, then repeatedly insert and wipe. If that gets it working then I clearly need to put some sort of swivel cover over the keyhole.
The irony is that having spent several hundred quid on a door, the lock mechanism is ****. I'll not describe here, for obvious reasons, but it's pretty easy to break the type of lock fitted to most uPVC doors.
Mucho thanks to you and Andy for inspiring me with a few ideas on the door. Everyone else as well - some great nuggets of information .
Good Answers: 444
01/23/2014 12:37 PM
Oil should never go into a lock, as you now know it's sticky and holds the dirt and grit from your pocket that gets on your keys. Now you have to get some electrical contact cleaner and spray the mechanism to flush out the grime, then use graphite only on your keys.
Be careful with your door, some solvent based cleaners may distort the plastic, best if you can remove the lock first, then clean it, much easier as well.
01/24/2014 5:33 AM
Cast-iron bathtub as a gong?
01/23/2014 11:34 AM
graphite from a common pencil, #2 or softer, much better than oils which gum and cause things to stick. (what's the deal with this editor and emoticons...my w7 system will produce none, this vista system was bringing up the lot to select and today only allows only the smiling fool)
01/23/2014 3:30 PM
Scrape a graphite pencul and blow the dust into the lock.
Robert A. Heinlein (1907-1988) "There is no worse tyranny than to force a man to pay for what he does not want merely because you think it would be good for him."
01/24/2014 5:13 AM
Use a soft (#1 or less) pencil as the harder ones' leads are a mix of graphite and clay/silicates.
01/22/2014 11:24 AM
I once built a custom exhaust system using an oxy/acetylene torch and coat hangers as the filler metal.
01/24/2014 8:22 AM
grandpa showed me how to do body work with metal coat hangers.
01/22/2014 12:00 PM
appropriated for a greater good....multi-use materials....gangam stylin junk...creative recycling....Jiggin
01/23/2014 12:00 AM
"gangam stylin junk"? "Jiggin"?
Please educate me!
01/24/2014 3:10 PM
I think that is the street term for 'Factory-Authorized Repair' in Nuevo Laredo, Tijuana, etc. - the Re-Purposing Capitals of the Western World. These guys are so good they can repurpose your car's ROM using only baling wire and a switchblade.
01/22/2014 9:06 AM
I have many pieces and fittings and sizes of pipe for various uses, such as leveraging wrenches, removing or installing pressed in fittings or shafts, a garbage can full of various wood scraps of all sizes and shapes including dowels, shingles/shims, 4x4's etc....
01/22/2014 9:30 AM
I keep a neodymium magnet in a 35mm film canister. That keeps it from getting crudded up with metal bits. I don't like magnetized screw drivers for the same reason, but I can use the magnet if I need to hold a screw on the tip one in a tight place.
I'm with Del on the casual redefinition of words.
Good Answers: 29
01/22/2014 7:28 PM
You might want to explain to the younger folk here, they may not know what a 35mm film canister is.
Those canisters came in handy for holding small parts, screws and the like, but the best use ever was to fill them up with freeze spray and quickly close the lid. Toss it under a co-worker's chair and wait for the lid to pop. It's even more effective when they've just learned that reverse polarity on an aluminum can electrolytic makes a similar sound. Their nerves are a little jittery for a while after that lesson.
01/22/2014 9:49 PM
So, here's what we have.The large black and silver object is a 35 mm single lens reflex camera. (Non-digital) The green and white cylinder on the left is the memory. (actual film cannister) It holds 36 "negatives" which are equivalent to about, maybe 100MB of memory in a "real' digital camera.The film cannister container (object used to hold the magnet) is the round black plastic container with the gray lid in the foreground.
For the purists, this is a Minolta XGM, purchased in 1982.
01/23/2014 1:29 PM
Going back a bit farther: remember the aluminum cans with the screw-on lid? I wonder what kind of racket they would make to scare a co-worker!
The plastic ones have another use for me. On the old glass oil bottles (wish I could find some more modern plastic ones) with the screw-on conical tops,the cap often gets lost. The film containers work (pill bottles too) in place of the lost cap, but not as neatly.
Lehman57
01/23/2014 8:25 PM
according to Youtube you can use that samera lens on some cannon digital cameras
01/23/2014 8:29 PM
I have 5 or 6 of them. Wanna buy some?
01/23/2014 5:46 PM
I'm from the old days when there were pay phones and vending machines that needed exact change, so I keep 2 or 3 Kodak film canisters of quarters in the truck. A Kodak canister holds exactly $7.00 worth of quarters. -- JHF
Good Answers: 140
01/22/2014 9:50 AM
Wax crayons... are real good at getting a slipping drive belt to grab for a bit longer when you cannot afford to shut a drive, and therfore the production line, down.
You just hold them agaisnt the v-belt and let the belt pickup the wax.
01/22/2014 10:11 AM
Wax crayon (or a candle, or a bit of soap) also makes life a lot easier for driving wood-screws in*, as well as lubricating drawer runners.
(* You put it on the threads. Don't use it as a screwdriver, it doesn't work ).
Good Answers: 29
01/22/2014 7:31 PM
Good for sled runners too. I also coat the face of my snow dozer blade before plowing out the driveway. Came in handy this morning. It's the best use that I've come up with for those nasty smelling candles the wife keeps buying.
01/23/2014 1:11 AM
Putting Soap on Screw threads has the unfortunate additional effect of causing the wood fibers you are screwing into to deteriorate over time. Then the screw will loosen or fall out and the wood is ruined. Bee's wax or candle wax does provide the desired lubrication with out the negative after effects.
01/23/2014 4:11 AM
Didn't know that about soap & wood - thanks. Thinking back, I've only used it for easing e.g. shelf fixing screws throught wood (with pilot holes) into plastic wall plugs, which doesn't seem to have any deleterious effects over time.
Good Answers: 114
01/22/2014 10:01 AM
I used to have a couple of plastic knitting needles, sharpened as screwdrivers for adjusting trimmers in radios. A small artists brush for putting enough, but not too much, penetrating oil into awkward spots. A knife, ground from an old hacksaw blade.
Good Answers: 140
01/22/2014 11:46 AM
Ground hack saw blades make the best tools for cleaning out the slots on commutators on DC armatures. Spent many an hour as an apprentice cleaning them this way. The plant I did my apprenticeship at had lots of 200+ HP DC motors.
01/22/2014 11:56 AM
Old needle files are great for grinding down as tiny chisels for inlay work, or little awls, picks, scribers etc.
Masonry nails with the point ground off make good leather punches too
Good Answers: 114
01/22/2014 12:42 PM
I guess the classic is duct tape, it seems to be used for everything but ducts
Good Answers: 444
01/22/2014 4:29 PM
To expand on that theme I saw this somewhere,
"Duct tape for everything that moves but shouldn't, and WD-40 for everything that won't move but should."
01/23/2014 8:17 PM
and a spot of toothpaste to keep things out of small holes
Good Answers: 88
01/22/2014 5:55 PM
"Cavallier won't start", solved? S.M.
5
01/22/2014 9:36 PM
Chicken coupé.....?
01/22/2014 11:29 PM
I keep a couple of syringes in my tool box. Good for sucking up all sorts of things and placing a spot of oil in just the right place.
01/23/2014 8:06 AM
My Brain: Every Day
My toolbox is going to drive someone nuts with all the Re-Purposed CR4P that I've used not for it's intended purpose.....
Even Fabricated special tools.
Currently figured out that an old log-splitter makes a pretty good 10 ton brake/bender for small parts, now I just need to come up with some dies....
01/23/2014 9:52 AM
Whenever I see a Street-sweeper blade, (spring steel about 0.1x0.03" anywhere from a few inches to around 8 inches long) I always pick it up. They make great tiny scrapers, hooks, pry bars, etc. I'd much rather bend one of those instead of breaking my knife tip if I pry too hard. They usually have a temper such that they can be bent once into a desired shape with not too sharp a corner.
01/23/2014 10:18 AM
Sounds like useful stuff. Don't have them over here - least I've never seen one.
01/23/2014 12:57 PM
The common street-sweeping trucks here have this "wire" brush with a nearly vertical axis that moves stuff from near the curb out to where the main brush (horizontal axis) and vacuum can pick it up. The "bristles" commonly break off, and I find them in the street. Not long ago I found where the driver apparently got too close to the curb, and broke off a whole bunch; I picked up about 30 of them. Too bad there's no easy way to send you some...
01/23/2014 6:32 PM
We have similar machines - but I think they have plastic brushes.
Good Answers: 203
01/23/2014 10:52 AM
I like making "unique" tools so sometimes I have to look for a job to use a tool on, not the tool for the job. Amongst some of the many are:
Hair pins make good small spring clips for holding small things or as small "c" clamps;
"White Out" correction fluid to accentuate marks, such as timing marks- put it on and remove excess, or to find out where there is a high or low spot on contacting surfaces.
Nail clippers make good cutters for small wires or other small things. Also have lots of mechanical advantage.
A 1" x 14" power hacksaw blade. Wrap 3" of one end with friction tape, or similar tape, and grind the back of the blade to a sharp knife edge or at least as sharp as you can get it. Makes a great saw and knife for Calcium Silicate insulation, cutting Styrofoam, foam rubber, fiberglass insulation, cardboard boxes and slicing a sandwich in two.
A fireman's door block. It is placed on top of the hinge and keeps the door from closing. Much better that a wooden wedge since it doesn't put a strain on the hinges and can't fall out when the door is opened a small amount. Also it can't get kicked out from under the door.
An old collapsible car antenna with a spade lug crimped on the end. Alligator clips, and other things can be screwed onto the spade lug for holding or picking up things or as an arm extension. Great for holding matches for lighting pilot lights on water heaters, grilles, torches and the likes. Use the clip to hold a rag to reach up and clean away those high cob webs in the house.
A couple of 1" x 4 foot rubber bands have many uses including holding a large bunch of lighter weight things vertical, as strapping, as a "third hand", holding plastic bags within drums or boxes. To make them tighter, increase the number of layers for the rubber band.
A "tire shaped" magnet with the hole in the center. When drilling a hole in steel place the magnet so that its inner circle is around the spot where the hole will be drilled. The chips are held by the magnet as they are generated and don't fly around. At the least it keeps the chips on itself and not under your skin.
A plastic turkey baster. Use it to get the last few ounces out of the toilet tank when replacing the fill valve. It is even more useful for emptying water out of the toilet trap when working on it for replacement. Keeps the "water" off the rugs.
An aerosol can of hair spray will make an easy to release low tack contact cement.
Good Luck, Old Salt
01/23/2014 1:47 PM
I have also used the black (or almost any dark color) "magic" markers to coat screw threads or whatever fits too tightly to work. Put it together and tighten several times, that take apart and look for the high spots to "massage."
White Out works well on smooth surfaces to accentuate marks, but not so well on old rusty junque to bring out a stamped part number that you need to read.
Lehman57
Good Answers: 203
01/23/2014 2:26 PM
Lehman57-
Yes, understand about the black magic markers. Good Idea. Now I have another reason to use the one I carry which always turns out to be dry.
Another thing I carry, but forgot to mention, is bar of Ivory soap. I carry it in a plastic soap dish so it doesn't get all over everything else. Hold a long wood screw or any modification of it, to the soap, rotate it a few times, and then screw it into the wood. Makes a great lubricant for the screw. Bee's wax can also be used but the Ivory is more effective, much cheaper, and easier to apply. Use the solid bar only since the liquids don't work at all. Other brands don't work as well as Ivory. When replacing the nails of my deck with screws, 3" and 3-1/2" inch screws went in like 2" without the soap.
If you have children who want to "help" you with your project it is a great "attention keeper" for them. Let's them help but not too much.
Good Luck, Old Salt
01/26/2014 5:26 AM
Check out comment #27.
Good Answers: 203
#86
In reply to #85
01/26/2014 9:33 AM
Truth is not a compromise-
Yes, most of #27 makes sense. What doesn't make sense is the conflict about the soap and experience. I am NOT stating the answerer is wrong, perhaps not as widespread as one might think. I have personally used that method since I was a teen-ager, a long, long time ago. The person who told me about it used it since Ivory soap was available to him. This method was shown on an internationally recognized construction/home improvement TV show. I have also been told about it by several others. None has indicated any adverse effects or problems with the method vs. time. Perhaps the differences are in the location and loads on the screws? Perhaps he is speaking of a greater quantity of soap being applied/screw.
Who knows why one methods works for some but not others? I don't care about why the differences in experiences have occurred. I am satisfied with both methods because history has proven both to work as needed. I use methods, the bee's wax and the Ivory, but primarily the Ivory.
Good Luck, Old Salt
#87
In reply to #86
01/26/2014 2:31 PM
It would be most interesting if you looked back closely at places where you have used Soap on wood screws after a number of Years post the installation!
The Alkaline nature of the soap is what deteriorates the wood fibers over time.
Looking at old furniture repairs is a good place to see this effect, where the repairs have "loosened" up. Removing the old screws reveals the wood rotted where the soap was used and not where it wasn't.
I have some 50 years of experience in restoration and have learned not to use soap, the hard way. Observing my own earlier repairs or new construction now needing more major surgery.
Fortunately, other older and wiser professionals pointed this unexpected result out to me many years ago and I changed my operating basis after I observed that it was true.
As a result, I no longer see this deterioration in any of the construction I have built or repaired over the last 15 years since I started using paraffin or Bee's wax instead.
Viability is important in all the products and repairs I do. This is why I wanted to share this data with you.
Dan
In reply to #87
01/26/2014 3:13 PM
Off the topic question. I have heard that stainless steel hardware should not be used in oak when it may get wet as in a pick-up bed. The reason was that oak and SS do not get along together, but I forget the reason--maybe the alkalinity of the oak? Apparently galvanized worked OK.
Lehman57
Good Answers: 203
#90
In reply to #88
01/26/2014 5:23 PM
Lehman57-
Hi. That is a new one on me. I have heard of the incompatibilities of other things with oak but if I remember correctly, age diminishes the mind, that it was because of the Tannic Acid in the oak. I have some St Stl screws and bolts in the white oak stem and keel of my sailboat and have never found any evidence of a problem. Could the different grades of Stainless be a factor in it? I use 316 exclusively when available.
Stainless Steel is used regularly to handle the transportation and storage of acids. Tannic is not a particularly strong or exotic acid. It is used in many products including the treatment of cold sores, hemorrhoids, dyes and foods.
Galvanized things would lose their zinc galvanizing if in contact with Tannic Acid or most any other acid. This is the same way that steel and other metals are cleaned with acids. The common name for this process is "pickling."
Hope this helps you.
Good Luck, Old Salt
In reply to #90
01/26/2014 9:28 PM
I found the original source; Dec, 2011, issue of Auto Restorer magazine. (Luckily I had sent an email about this or I'd still be looking!)
The guy was talking about the restoration of his 1949 Ford F4 stake truck. Most fasteners in the truck were stainless steel, except for those in the stake bed where he used galvanized. In his words: " . . . stainless and oak are not compatible. A lot of people think that if you use stainless it's 100-percent great, but stainless just rusts to hell in oak. It's the acid in the oak, once it gets moisture to it. If you're in a perfectly dry environment, you can put stainless steel in with no problem. It's not that oak doesn't like stainless; it's that oak/water and stainless don't agree."
So, I was wrong to suggest alkalinity.
Lehman57
In reply to #91
01/26/2014 9:35 PM
Tannic acid, I think. Check me on this.
There are specialty S. steels which resist acids to a great degree, but they're very expensive and you'd probably not see fasteners made with it. Nitron 50, for instance.
In reply to #91
01/31/2014 2:53 AM
It's been my experience that carbon steel fasteners, even galvanized will stain (badly, and rot) oak. The galvanized are OK until the galvanized coating is gone, then you're faced with the same staining effect as bare carbon steel. Of course, the greater the moisture, the sooner and greater is the staining. Even kiln dried, in a relatively dry atmosphere will stain. Solution? Probably bronze if you want a long term solution.
Good Answers: 203
#89
In reply to #87
01/26/2014 4:58 PM
Dan A-
I can't argue (besides I hate to argue) with your experience and reasoning. My experience has not been with the uniqueness of restorations but rather of the dimensional type lumber. Also I only use a minimal amount on those that I do. I don't like to use lubricants for systems that were not intended to have them, whether it is ivory soap or bee's wax or paraffin or anything else. I don't get much chance to do restorations since it is not one of my hobbies unless it is a necessity. Likewise my wife prefers to buy new when things such as furniture breaks, much to my displeasure.
Since the advent of many different fastening systems and fasteners in the last 25 years it appears to me that there have been many changes. These have eliminated the need for lubricants on the more recent fasteners. For example decks seldom need lubricants since the advent of plastic planks and double threaded screws. Also the shank on many screws is reduced in diameter as compared to the equivalent old style wood screw. Also with the use of St Stl and exotic plating's I have found that these do not require any lubricant in most woods. Likewise methods and materials have changes. 25 years ago decks were constructed almost exclusively of PT SYP and a few from Red Wood. Now the use of PT SYP has reduced and the use of plastics, hardwoods and other woods increased. 25 years ago decks of red meranti and Ipe were seldom used in decks. Now its use has proliferated. Good Practices say that the fasteners should be used with predrilled pilot holes.
Thank you for bringing out the positives of some material and the negatives about Ivory soap. I think your view point and mine have been different because of the different items and materials we have worked with. Also a difference in viewpoints enables the cross learning of other's ideas and experiences. I will stick with my red meranti, oak and cedar for repairing and restoring wooden hulled boats. You are apparently the higher skilled one of us for restoring other items, something that I could never make a subsistence income at.
If you have the time and inclination, please provide me with more information on your restorations and practices for it. Please do this via the CR4 mail provision. Thanks.
Good Luck, Old Salt
#93
In reply to #89
01/27/2014 1:53 AM
Hi "Old Salt",
Thank you for your thoughtful reply.
One other thought came to mind from your comments;
Wood hardener is quite useful in fixing up an area where the wood rot has occurred around the wood screws. It does a good job of reinforcing a weakened but not ripped out area.
For more major construction, I agree with using the new Deck screws which generally do not need lubrication.
But one of the greatest improvements in screw technology was the invention of the SQUARE drive screws.
I have learned to detest Phillips head screws over the years, too many stripped heads
On the other hand, the square drive screws rarely slip, even 3 in long screws in harder woods. What a blessing.
Makes one wonder why anyone makes or uses Phillips head hardware any more!
Thank you for your thoughts and experience.
Dan
In reply to #93
Re: Useful Repurposed Items taht can cause problems!!
01/27/2014 5:34 AM
Important Infos for all when Repurposing can cause problems......
One of the problems when using either of the two styles of "cross-head" screws is that many people do not know the differences between them and that they are almost totally incompatible with each other.
Using the wrong screwdriver will almost always damage the screw, really ALWAYS. The amount of damage done related to the amount of torque used......
One type is called "Phillips" or "PH" and the other type is called a "POZIDRIVE", or "PZ".
The PH screwdriver has "flanks" set at an angle, which means when using a lot of torque, the driver starts to rise out of the screw, usually causing damage to the screw itself. It is an old design and has old problems still....
To combat this problem, the PZ driver "flanks" are made parallel and sometimes roughened, so that a) They do not "ride" up with torque as much and b) tend to grip or lock themselves in the screw.
To easily identify one screw from the other, the PZ screws have small extra marks between the "slots", PH screws do not have these.
Naturally the PH screws are also formed with holes to exactly fit the flanks of the correct screwdriver (see Note below for a possible change to this), as are of course the PZ screws.
Each screwdriver is made in several sizes, the usual ones being 1, 2 and 3, though there are both smaller and larger ones available for special order/applications. Some may dispute this, but these are usually only available from specialist stores, which sells such screws and drivers, though online, both are available.
Phillips Pictures of screws and drivers:-
Pozidrive Pictures of screws and drivers:-
Here are some difference pictures:-
I think that should clear that up fully.
Note.
There are some screws, usually formed for PH screwdrivers, often used for thin metal. The heads are NOT fully formed depth wise. For driving these screws correctly, PH screwdrivers (and PZ!!) are simply NOT good enough.
There is a small trick that will allow them to be driven cleanly, all you need to do is to take a PH screwdriver that "almost" fits the screw and grind a really tiny amount off the "nose" of the screwdriver, till it fits perfectly with no wobble.
Its only a tiny amount to take off AND the driver will still work with full depth PH
screws of that size still with no problems whatsoever...
I hope this short dissertation helps some of you with possible screw damage problems that you may have experienced, though I do not know just how widespread the screw types are, but Europe has both available as are both types of drivers too.
Other countries, no idea, sorry!!
In a good workshop, both should be available and a good worker takes time to identify which is correct before using the wrong tool.....which he will anyway!!!
Repurposing a PH or a PZ driver for the wrong screw type, is simply a bad idea.
(but we all know what we do when it comes to a problem!!)
In reply to #94
Re: Useful Repurposed Items that can cause problems!!
01/27/2014 8:57 AM
I've done this, good hint.
Lehman57
Good Answers: 29
#97
In reply to #94
01/27/2014 10:18 AM
I recall reading somewhere that phillips screws & drivers are tapered or, as you say, have flanks set at an angle, to minimize damage to the parts being fastened. The idea being that the screwdriver will cam out of the screw before it damages the parts being fastened.
While the intent is honorable, I always thought it a bit of a strange way to avoid damage, screwing up the screw so that you avoid screwing up elsewhere.
In reply to #94
01/27/2014 4:54 PM
Good advice.
There is a problem with cross head screws though, even when using the correct driver. I much prefer flat head screws to cross heads. Flat head bits fail very rarely and flat head screws never fail by rounding the interface with the bit, which is much more than I can say for cross head screws and drivers.
Oh, BTW, I know that the correct driver was being used each of the many times I have experienced failure of the interface being stripped or driver tip breaking, because the driver bit each time was supplied with the screws. I' convinced the design is made to increase sales of screws and driver bits, because if they used flat heads, you wouldn't have so many ruin.
In reply to #103
01/27/2014 6:02 PM
For such reasons, I tend to buy only wood screws with Torx bit heads, never had one strip out yet!!!
Like these:-
See here:-
Torx Woodscrews and others
In reply to #104
01/27/2014 7:45 PM
Ill give it a try.
In reply to #103
01/27/2014 6:14 PM
By "flat head" screws, I assume that you mean the type with a single slot.
Perhaps, if you used the correct terminology for the two types you would be better understood.
I have taken the liberty to explain the correct terminology below.
This ↑ is a "minus" head screw.
This ↑ is a "plus" head screw.
I hope this helps.
In reply to #105
01/27/2014 7:45 PM
Point taken. Thank you. Old habits die hard, but they die none the less.
In reply to #106
01/27/2014 7:52 PM
We all knew what "flat" blade means.
I worked in a prototyping/research lab with a bunch of talented, crazy guys 40 years ago.
We gave names to lots of things. Most unprintable here.
In reply to #108
01/27/2014 8:16 PM
"P.A.s" for self-adhesive, paper binder-hole reinforcements is one colourful acronym* that comes to mind. Sharing your reluctance to wax eloquent, I'm not going to spell it out of course. :))
Acronym: Alphabetic Colocation for Reducing Or Numbing Your Memory
In reply to #109
01/27/2014 8:43 PM
Preventative Abutment?
Prince Albert?
Pucker Again?
Penetration Angel?
In reply to #110
01/27/2014 9:21 PM
Lol.
'P' for Paper. As for the rest, my lips are sealed. :))
Good Answers: 203
#112
In reply to #105
01/27/2014 9:50 PM
lyn-
GA for that one!
One question though, if one is a "minus" head screw and one is a "plus" head screw what is an "all screwed up"? Is that a screw with all the types of heads on it? Also is a "cap" screw one that wears a hat? Is a "machine" screw one that makes other screws? Is a "carriage" bolt one that carries bolts? Are shoulder bolts and screws one with broad shoulders? Are socket head cap screws cap screws with electrical sockets? Do "eye bolts" wear glasses? Is there a "me bolt" to match up with a "u-bolt"? Do "set-screws" come in pairs? Do "wetwall" screws turn into "drywall" screws during a drought? Likewise do "drywall" screws turn into "wetwall" screws during a rain storm? Are there "index screws" to use with "thumb" screws? Is an "anchor bolt" used to hold a boat's anchor to the anchor rope? Is a "hanger" bolt the one that held the noose onto the gallows? Finally, what does a ball screw do?
Its been more than one, but you are such a inspiration to all of us, you are the only person who would have the all encompassing knowledge required for these questions. Thank you advance for your efforts on our behalf.
Good Luck, Old Salt
In reply to #112
01/27/2014 10:03 PM
WOW!
I bow down before your creativeness.
I can only offer SNAFU as an answer to the first question.
The rest, well, that'll take some time.
Good Answers: 203
#122
In reply to #113
01/28/2014 10:06 AM
lyn-
Thank you for your prompt and astute reply. Unfortunately, in the meantime several other questions have risen (some might say they have "lefty looseyed") and we would like your clarifications of these questions:
Is there an "advanced screw" that is used with a "lag screw" in order to prevent a discrepancy in time?
If a "TEK" is self drilling screw would a "KET" screw be a self filling screw?
Is a sheet metal screw made out of sheet metal?
Is a wood screw made out of wood"
If your door has self-tapping screws in it do you still need a door bell?
Manufacturers make "I"-bolts and "J"-bolts, will they next make "K"-bolts?
Can "hot-dipped galvanized" screws be used on other than hot water pipe hangers and hot water heaters?
Are "concrete screws" available in "Portland", "air entraining", "mortar" and "grout" grades?
Are "tapcons" have clockwise threads do "tappros" have counter-clockwise threads?
Are deck screws used for house decks or boat decks. Also do boxers use these when they knock someone down to the canvas?
Are "double-ended" screw only for use on ferries?
Do "dowel screws" grow up to be "broom handle" screws?
Do "mirror" screws reflect your face when you look at them?
Do "security head" screw have "security screws" that they boss?
Are 'breakaway" bolts forbidden to be used in prison construction?
Do "elevator" bolts only go up and down?
Are "plow" bolts used to till a garden?
Do they make "fireplace" bolts that can be used instead of "stove"bolts. Also, do they make "microwave" bolts to speed up the installation of "stove" bolts?
Are "tension control" bolts the same as "Valium" bolts?
How far can a "thread rolling" screw roll a thread?
Are there "fasteners with built in dryers" for use after "fasteners with built in washers"?
Are "pan head" screws the same as "pot head" screws?
Are "button head" screws only for use on shirts?
Are "mushroom head" screws hallucinogenic?
Are "flanged head" screws available in weld neck, socket, slip on, threaded and lap joint heads also?
Are "snake eyes" bolts used on anything else besides crap tables?
Are "cup point" set screws used with "saucer point" set crews?
Are "half dog point" set screws only used for the cages of dog/wolf hybrids?
Can "cone point" set screws be used with other than vanilla ice cream?
Thank you in advance for your enlightenment on these questions.
Good Luck, Old Satl
In reply to #122
01/28/2014 10:34 AM
This last part, most of the thread I think, on the various screws has certainly been off-topic from the original question; but nevertheless useful, then morphed to entertaining.
Lehman57
Good Answers: 203
#125
In reply to #124
01/28/2014 10:53 AM
Lehman57-
Yes, I agree but many times there are things in our professions and hobbies that we really have to stand back and not take everything serious. A little humor mixed with the ultra serious keeps us, or at least many of us, stable and able to tolerate some of the more stressful aspects of what we are involved with. For example, why is the suicide rate for engineers and scientists higher than the general population? Why do some suffer from depression? Answer- we are so ingrained in perfection and getting everything perfect that some become depressed because they can't always reach their personal goal, perfection!
These simple questions/comments are to avoid the mundane and perfection aspects of our endeavors.
There are numerous parts of engineering that are not easily explained or known. For example, I still have my set of "banana wedges" in one of my tool boxes. Yes, they are banana wedges! How many participants in this thread know what banana wedges are and for? Yes, they do have a useful purpose besides wedging bananas.
Good Luck, Old Salt
In reply to #112
01/28/2014 1:20 AM
....speaking of which. You should check the type set screws in the font you are using. It appears some are loose and need to be tightened.
It came to my attention while I was puzzling over what you could possibly mean by 'anchor rope'. Bizarre right? ...and then it hit me:
the type set screws on your font are loose allowing the 'd' in what you typed ('anchor rode') to swivel down to disguise itself as a 'p', creating the nonsensical phrase that appeared...
I know that isn't the only possibility. You could have written 'anchor line'. It just seems unlikely that 'lin' morphed to 'rop'. Whatever term you used originally, it must have caught you a little off guard to see 'anchor rope' in your own comment!
Good Answers: 203
#119
In reply to #114
01/28/2014 9:06 AM
truth is not a compromise-
My original intention was to describe it as an "anchor line" but thought that some land lubbers might have a difficult time understanding how a screw/bolt could be installed into a geometric element. Also, if I described it as an "anchor rode" some might think that this was the wrong tense to use or I was speaking of a mode of transportation. Now we all know that an anchor is to stop movement. Some boaters/sailors might also wonder how a screw could be installed through a galvanized chain.
In order to not promote any more confusion than what I had already, I chose to call it by the term that most people would describe it as, "rope". If my intention was to impress the greatest number of people I probably would have called a "tri-cylindrical rotated assemblage with longitudinal positive elastic resistance and directional flexibility".
Next question is would Capt. Ahab shout "Avast ye mates, weigh anchor bolts/screw"?
Good Luck, Old Salt
In reply to #105
01/28/2014 4:57 AM
It may be a good use of terminology where you are (only PH and no PZ for example?), funny too, but as I already pointed out it does not differentiate correctly between PH and PZ screws for some parts (at least) of the world.......
Can you somehow "Modernize" that comment for us all?
My thoughts went something like this:-
= MINUS
= PLUS
= Multiply
Also, I occasionally find old slot headed screws in old woodwork when renovating. Anything less useful than such an outdated, easily damaged crew head than those, I have to see! Only to be used when repairing antiques to my mind AND the screw must remain visible, something I never, ever do!!
By the way my slot (flat) screwdrivers are all in good condition, ready for use, graded by width and thickness.....as I need them for dismantling old guns as well.....though they are mostly with a friend of mine at this time, I expect I will have to grind some back to shape after he is finished with them!!
I am also one of those people who will re-grind a flat bladed screwdriver to fit a screw correctly when needed. Par for the course!
I am sure that MANY others here do much the same, this is very important for the slotted screws on Guns and the like.
I looked around on the internet for some good info on grinding flat bladed screwdrivers, there is a lot of rubbish there, no help at all. No diagrams or pictures. One even said the sides of the screwdriver should be dressed with a NAIL file.....forgetting that even normal files have problems on quality steel in quality tools.......A NAIL FILE????????
In reply to #115
01/28/2014 9:33 AM
The 'minus' 'flat' 'slot' -head screws of the same size and material have always been able to handle much more torque without damage to the head than the 'plus' and 'multiply' heads, in my experience.
When a 'minus' head screw fails, it breaks below the head, and that is much less common than the additive or multiplicative common failure of rounding out the 'teeth' in the head. I can't remember rounding off a slot.....there is just so much more material there, someone would have to be using the wrong size driver.
In reply to #120
01/28/2014 2:08 PM
If you round out a cross head screw, there are some very cheap tools easily available to remove them.
See their usage here (there are many other videos on this subject):-
http://www.youtube.com/watch?v=ZXL28fepFl4
Basically though, damage to any screw is the fault of the person turning the it in/out:-
Wrong screw for the job
Incorrect pilot hole size (wood)
Badly Tapped (metal)
Wrong torque
Wrong screwdriver/bit
Wrong size screwdriver/bit
Worn screwdriver/bit
Not used at a right angle to the screw head
..........and I bet there are even more problems that I haven't even thought of.....
In reply to #127
01/28/2014 4:13 PM
Interesting video. I have the second extractor, but haven't used it enough to comment. I also have the first type, and have had no luck at all with it. Perhaps an observation that I saw in Skinned Knuckles magazine will explain. This is about bolts, not screws. If the bolt fails by torque, an E-Z Out will not work. This has usually been my case--the bolt rusting in place for decades.
I also have an air hammer that has worked the couple of time I used it on a screw. It provides axial impacts, not torsional impacts. When using a socket on a bolt, the socket bears on the work, not on the fastener, thus the impacts go the wrong place. On a screw the axial impacts go directly to the fastener and a built in wrench will let you loosen it. I found it in an aircraft tools catalog from "The Yard;" www.yardstore.com at that time. It was listed as "screw extractor/screw knocker/old man.
Lehman57
In reply to #127
01/29/2014 12:51 AM
'....Basically though, damage to any screw is the fault of the person turning the it in/out....'
I'm not convinced that there aren't some other factors entering into the equation. I'll grant that for well manufactured flat/slot/minus head screw of a decent alloy, if it fails, it will certainly be the person screwing it in that is at fault.
But there is certainly a spectrum of quality out there when it comes to things like screws and driver bits. I suppose it is still the person turning the screws fault for buying crappy screws or crappy driver bits.
I'm also unconvinced that cross head screws a good design. The main argument that leads me to this conclusion is the simple fact that using cross head screws with the driver supplied, typically when driving into wood that is somewhat dense or hard, many many more failures occur than when I use flat/slot/minus screws. Moreover, almost all of the failures are in the head of the screw with cross heads, while the very few failures I do have with flat/slot/minus head screws never occur in the head.
I use the bits provided with the screws, so it isn't a matter of a wrong match. Someone might suggest that I am using the wrong angle. Perhaps I am but I have no problem with slot/minus flat head screws. If cross head screws require a level of control I am not able to consistently give in various positions, then it suggests that the design is too finicky.
In my experience, a slot/flat/minus head screw offers a more robust interface with the driver, while the interface provided cross head screws is clearly the weak point. This only comes into play when it isn't easy to drive the screw. While drilling a pilot hole would probably alleviate the problem, there are many situations where I would much rather use a better screw than drill a pilot hole for each.
In reply to #133
01/29/2014 4:09 AM
If the correct pilot holes are not drilled in hard wood, there is a serious possibility of breaking off or damaging the head of even a quality screw.....
Many are simply too lazy to drill a hole first!!
Its a good reason to have two fully charged electric drills, one with a drill bit, the other with a screw bit.......I have bought some special drills years ago that make both hole sizes needed, the bigger ones for the top piece of wood and the smaller one for the lower piece where the Spiral thread Bites...If wished, it will also countersink. See here:-
Canada - Member -
In reply to #136
01/29/2014 10:58 AM
Hey Andy,
I also have a set of those for working in hardwood. My set came with the corresponding plug cutter:
Rick.
Handle every stressful situation like a dog. If you can't eat it or play with it, just pee on it and walk away. - unknown.
In reply to #140
01/29/2014 12:28 PM
That I have not seen, beautiful.
Though I personally haven't used plugs for many years (stopped making furniture and the like!!), but if I ever do, I know now what I need!! Many thanks for sharing.
In reply to #136
01/30/2014 1:49 AM
'....Many are simply too lazy to drill a hole first!!....'
The situations in which I choose not to drill pilot holes are not exceedingly rare. If that is your chosen descriptor, so be it.
Modified to your descriptive standard, I still maintain: Pertaining to jobs for which my laziness motivated analysis (comparing the time and effort to drill pilot holes to the time and effort to correct a failed screw times the most probable number of failed screws), the use of a slot head (flat minus) screw as opposed to use of a cross head screw is an important variable. The more robust connection of a flat head screw (as compared to cross head) significantly decreases the probability (and consequently the most probable number) of failed screws.
Using flat head screws correctly biases my laziness motivated analysis toward skipping pilot holes in certain situations. If I use cross head screws, the wood needs to be much softer before I would feel safe without pilot holes.
I'm liking the suggestion in this comment.
They have no intention of ever fixing the problem submitting comments, do they?
In reply to #142
01/30/2014 2:34 AM
...laziness motivated analysis
Who on earth let you inside my head ?
Some evil so-and-so recently got my son a new chest of draws. Flat pack . The pilot holes were all woefully undersized. Out of pure stuboness I didn't drill them out larger. Having got halfway thru assembling the garbage I much regretted that decision. It got put together OK, but the effort in doing so nearly killed me off.
As with all flat-pack furniture, I should have binned the instructions and just looked at what I could do with the raw material supplied. In my experience, self assembily furniture is almost always junk unless it involves hex-headed screws or bolts,
In reply to #142
01/30/2014 5:19 AM
I read an article once in which someone did a series of controlled experiments to confirm the counterintuitive common or received knowledge that joints formed with screws in pilot holes were stronger than those without pilot holes.
I accepted the premise at the time and was convinced by the apparent thoroughness of the experiments. But, looking at some of the comments in this thread it seems as though this "common knowledge" is not as common as they implied.
Was I duped?
In reply to #145
01/30/2014 5:47 AM
Don't know that I've ever considered the joint strength much when drilling pilot holes - the joint foremost in mind has been my wrist (except when there was a clear possibility of the wood splitting without a pilot hole).
In reply to #145
01/30/2014 5:58 AM
I'm just pointing out. Sometimes one has to weigh available time against risk of failure and other such stuff. Slightly ironic for 'Truth is not a Compomise', but some situations demand a fast result, even if it's not a very good long term solution.
Has nobody here ever done a lash-up job to simply make something work until a more suitable solution can be decded upon and implemented ? Most normal people like a perfect solution to any given problem, but I would humbly suggest that the job of an Engineer is to make the <whatever> work. If a component is not to hand, an action plan not worked out, the Engineer has to, well, Engineer it. That involves weighing up what you'ld like to do against what you can do with available resource.
In reply to #145
01/30/2014 8:10 AM
I find it difficult to believe that screws with pilot holes are directly "stronger", but they are certainly easier to form, even if they need more work. They are easier to judge depth and torque with too....
And you can always undo and do them up many times in quality wood without problems......if using a power drill, setting the torque correctly works wonders.....
I like screws (either type!!) when building cabinets, if I make a mistake, I can redo it. Furthermore, when its right, I can glue frames together, using screws till the glue is cured, then remove them and fill the holes for a good final finish...and no metal left. Or sink them well in and also fill the head holes for a good finish....
In reply to #142
01/30/2014 5:58 AM
I tend to forget to drill a pilot hole when using OSB panels (the name may be different where you are!). They appear to be made of wood shavings, glued together under pressure. Great stuff, stable and easy to work, if you forget the sharp edges and splinters.....and put the screws where you cannot see them......
I have used them a lot!!!
There are a few pictures here for those the name does not ring a bell:-
OSB Panels
Great as flooring too, which was how I discovered them about 10 years ago...
OSB(Oriented strand board).
In reply to #136
01/30/2014 4:26 AM
It's maybe a bit frivolous, but having viewed some stuff on the internet I'd love to have a decent kit of those Dremel drills. Some of the artwork people make is astonishing.
In reply to #144
01/30/2014 7:55 AM
Buy a Dremel with a battery, they are totally freehand.....mine is 7 years old and the battery is still good and still holds its charge well, for a few months......its a Lithium Ion type of battery.....
But I have to admit to also having also several others, not just Dremel, that use 220 volts. They are all simply the best tools ever.
I could liken them to a laser, till you have one, you wonder why you need one!!!
I remember as a teenager, seeing a BBC TV program about Lasers, basically it said "Great thing Lasers, but what use are they!! It must have been in the early '60s at a guess......
They did use one to measure the distance to the moon I remember......and a Moon visit by NASA put a reflector on it to improve the reflection. (Is it still in use?)
One could say:- "there is Gould in them thar hills" - if one understood the history of lasers better,......
See here:-
Laser
BUY A DREMEL!!!!
Andy Germany (14); bluebelly (3); Bricktop (1); Circuit Breaker (2); corbinstein (1); dadw5boys (7); Dan A (6); dkwarner (6); geraldpaxton (3); JohnDG (9); Kris (17); Lehman57 (15); Lo_Volt (5); lyn (10); North of 60 (2); old salt (24); passingtongreen (3); RAMConsult (2); Randall (3); Rick@cae (2); Rixter (3); silvCrow (1); SimpleMind (2); SolarEagle (3); Theophilus Stark (15); Tom_Consulting (1); truth is not a compromise (12); user-deleted-1105 (2)
