Previous in Forum: Water Paint Over Oil Paint   Next in Forum: Oil versus Water
12 comments
Designing a Plate Heat Exchanger
02/14/2014 1:58 PM
I need to design a plate heat exchanger for my design project and I wanted to know where should I start. It is a steam-air heat exchanger.
Values I have:
Need your help!
Temperature Inlet Steam160
Temperature Outlet Steam80
Temperautre Inlet Air25
Temperature Outlet Air40
Mass flow rate air kg/hr2954.4
Efficiency %93
Pressure0.6 Mpa
Re: Designing a Plate Heat Exchanger
02/14/2014 2:06 PM
It's quite evident that this project is beyond your skills-set. Your have given the sizing spec's required, on top of actually design the plate heat exchanger it's self.
02/14/2014 2:26 PM
If you need a start, I would say establish your required surface area first. That is a good start. Happy calculating!
You need farther direction, let us know.
And welcome to CR4....
02/14/2014 3:10 PM
Search for "plate heat exchanger design", using one of the many search engines available. How to Search the Internet - Hannon Library
If that fails, go the the library and read a book on the subject.
02/14/2014 3:55 PM
did you read the part about "wee don't do your homework"?
listing your % effecientcy parameter is a dead give away this is an assignment
02/14/2014 5:10 PM
93% is pretty good.
02/14/2014 8:27 PM
Okay you got me on this one?
Where is the other 7% of the energy transfer going?
02/14/2014 8:34 PM
Ambient loses for one.
02/14/2014 9:25 PM
But it's a steam to air exchange. Any degree of insulation around it will put the I (steam)/O(air) transfer ratio at 100%
02/15/2014 11:55 PM
Maybe better than 93%, but never fully 100%. (Unless Tambient ≥ Tsteam.)
02/16/2014 2:41 PM
Insulation around a plate heat exchanger?..... Ahhhhh, that tells me you never had to do maintenance on one. Am I correct to say that?
02/17/2014 3:11 AM
A few telephone calls to plate heat exchanger suppliers with this information will yield some useful quotations. At that point, detailed design from first principles becomes futile.
Good Answers: 38
02/17/2014 8:59 AM
Guest 2307....
Repeat after me "latent heat of saturated steam"...."latent heat of saturated steam"
Some points to ponder:
- Your HX has steam going in and steam going out ???!!???
- You have selected a plate-frame type HX to heat air ???!!???/! ???
- Do you understand the difference between steam and condensate ???
- Why do so many HXs that are supplied with a saturated steam heating source, reject condensate at virtually the same temperature as the inlet steam ??
Register to Reply 12 comments
Fredski (1); lyn (1); MJCronin (1); phoenix911 (5); PWSlack (1); tcmtech (2); Tornado (1)
