Previous in Forum: When To Use NAMUR Standard In A Switch?   Next in Forum: PMI Requirement
Coal Mill Level Monitoring Sytem for a Roller Mill
03/03/2014 9:31 AM
Does anyone know which technology i can use on a 'Raymond Bowl' roller mill to measure the level of coal in it remotely in a thermal power plant. I know the Milltronics acoustic system can only be used on 'Ball Mills', which similar technology can i use on the roller mill?
Pathfinder Tags: coal mill pulverized fuel
Re: Coal Mill Level Monitoring Sytem for a Roller Mill
03/03/2014 5:29 PM
Please list the suppliers contacted so far so that these may be eliminated from further suggestions. Start the list with the mill's original manufacturer, please.
03/03/2014 7:22 PM
Consider mounting the whole shebang on load cells, and go by weight.
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
03/14/2014 10:46 AM
I worked on a Milltronics ball mill control system years ago and for what I recall sound pressure was only one process variable used to measure mill load. The other variable was motor power. Perhaps a measurement of motor power in your roller mill would yield acceptable results?
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
03/14/2014 1:41 PM
Thanx, the power option sounds the easiest and most convenient to implement
Register to Reply 4 comments
PWSlack (1); rayanvd (1); tonykuphaldt (1); Tornado (1)
