Previous in Forum: Indian ISI Mark For Industrial Motor Controllers - Starters   Next in Forum: Humans Are Taking Automotive Jobs From Robots In Japan
10 comments
Number of Passes in Welding and Consumable Cost
04/15/2014 12:43 AM
I would like to know the general practice or rule for determining number of passes in welding i.e if we have to joint two 8 mm SS 304 Plates then how many passes would be required .
how can we determine the cost of consumable in butt welding & fillet welding ?
Re: number of passes in welding and consumable cost
04/15/2014 12:56 AM
Consult the American Welding Society website.
Or your welders.
Or an engineer.
Or, do some research.
Canada - Member - New Member
04/15/2014 9:14 AM
Yes, AWS is the standard, or CWB in Canada, both will give you all the info you need on weld joints.
Never stop learning
Re: Number of Passes in Welding and Consumable Cost
04/15/2014 12:46 PM
A1) -
A2) It is simply the amount of consumable used multiplied by the cost per unit consumable divided by some measure of the joint; the figure is determined from consumption data and invoices to hand. No CR4 reader can see those from here. Nor can they see which currency is used in the calculation. These things are also commercially sensitive, so don't ask.
04/15/2014 10:30 PM
To start, one could estimate that a welding electrode's own cross-sectional area is the same as the area it furnishes to the weld's cross-section.
Good Answers: 102
04/15/2014 10:55 PM
That's how I figure too.
1" of electrode for every inch of weld. The number of passes will depend on the weld spec.
04/15/2014 11:02 PM
Which in turn depends on cross-sectional comparisons.
04/16/2014 2:51 AM
  • It depends on type of welding process and weld metal deposition thickness.If you prefer EGW (Electro Gas Welding), then you can fill the groove with the help of 1/2 pass!
  • For general purpose work, Austenitic Stainless Steel 304 welding is carried out by SMAW (Shielded Metal Arc Welding) or GTAW (Gas Tungsten Arc Welding) .In this case GTAW need more weld pass compared to SMAW due to deposition thickness difference with the same diameter electrode/filler wire.
  • Calculation of weld metal is simple mathematics based on groove volume and density of weld metal.
http://www.twi-global.com/technical-knowledge/job-knowledge/calculating-weld-volume-and-weight-095/
  • But nobody in industry interested to play with complicated mathemaktiksPlenty of excel spread sheets are available in internet to calculate weld metal requirement and a simple search with right keywords would open up those files.If the procured consumable doesnot meet the actual requirement,again calculate and give the requirement to procurement department to procure the same brand of welding consumable (If your client is serious about the consumable brand name).This is the common practice followed in all fabrication shops and construction sites. If you need spread sheet, let me know your e-mail.
Pls, Let me know if you need further information on this subject.
Good Answers: 32
04/20/2014 1:43 AM
Hi dolby:
Excellent information. I wonder if there is online test method to know if everything going on is as per plan and result will not be having any serious problem. Obviously final testing may be still needed but failure rate can be brought down to minimum.
04/20/2014 5:44 AM
Hi Shyam,
So far I do not have information about an online program as per your requirement. However, if you want to reduce failure rate,then you can try ISO 9000 Quality Management System.Plenty of companies around the globe already adopted ISO 9000 QMS system.
ISO 9001:2008 specifies requirements for a quality management system where an organization
  • needs to demonstrate its ability to consistently provide product that meets customer and applicable statutory and regulatory requirements, and
  • aims to enhance customer satisfaction through the effective application of the system, including processes for continual improvement of the system and the assurance of conformity to customer and applicable statutory and regulatory requirements.
http://www.iso.org/iso/catalogue_detail?csnumber=46486
" A published survey showed that companies that implemented a quality system for ISO 9001 reduced failure rates by 40 percent and customer returns by 54 percent.
http://tpg-tc.com/consultancy-2/environmental-quality-management/iso-9001-quality-management-support/
04/16/2014 10:40 AM
Chapter 6.4 in the book Design of Weldments by Omar Blodget gives a good over view. This book is a hardcover and is available from the James F. Lincoln Welding Foundation for 15 dollars US. www.jflfoundation.com. There is also the Weight of Weld Metal Tables for 2 dollars US that expands on the tables in the book.
I hope this helps.
Register to Reply 10 comments
davlamb (1); dolby (2); Kevin LaPaire (1); lyn (1); PWSlack (1); Shyam (1); Tornado (2); Wal (1)
