Previous in Forum: Gussets In Stayed Surface As Per ASMESec I   Next in Forum: Tig Welding
25 comments
Tig Welding Flow Rate for Manufacturing SS Welded Pipes
04/23/2014 11:57 AM
Please tell me the flow rate for manufacturing ss welded pipes in a ss tube mill. What should be the pressure in kg/cm2/min for this process
Re: Tig welding flow rate for manufacturing ss welded pipes
04/23/2014 12:08 PM
04/24/2014 9:18 AM
no...5!
04/23/2014 12:15 PM
Can you please elaborate.
04/23/2014 2:31 PM
Ask not for elaboration, lest ye be asked to elaborate yourself!
04/23/2014 12:25 PM
Lincoln Electric web site has quite a bit of information, did you try that
Process and Theory
You can look at Miller also. (great machines)
Re: Tig Welding Flow Rate for Manufacturing SS Welded Pipes
04/23/2014 1:36 PM
There are a number of factors that affect the required flow rate, not the least of which is the type of gas cup or gas lens being utilized. Flow rates may be procedurally dictated, in which case the type and size of gas cup or lens should also be dictated.
A qualified TIG welder should be able to set appropriate flow rates. Novices often make the mistake of continuing to turn up the flow to correct any perceived problems with shielding, but the high flow rates draws outside air in. Flow should be as low as possible but still cover reliably all areas that are at temperatures high enough that exposure to atmosphere is problematic, taking into consideration any external influences likely like gusts, or people walking up.
This differs for various alloys. But without further specification, as a rough rule, if stainless beads are consistently no more than light yellow/straw colored, then for many alloys that indicated shielding was maintained until temperatures were low enough.
Purging is also something that requires consiideration.
04/23/2014 1:58 PM
also, is he talking about back purging?........
04/23/2014 2:00 PM
Who knows.
04/23/2014 2:25 PM
Maybe?
Questions like this really make me wonder about the number of decisions that are made without a decent understanding of what is standard/correct/important while attempting to not give any hint that some important knowledge is missing.
What were the hiring interview like? or, are the people doing the hiring also so worried about not looking like there is something that they don't know, that a little emulation of confidence opens all the doors?
....or do I just read to much into a question with insufficient details that fails to fill in those gaps?
04/23/2014 2:30 PM
like tornado mention, the units just isn't right.... SCFH would make more sense.....
well, because of what it lacks, it seems one has to read something into the question..........
04/23/2014 10:58 PM
Just to be clear (because rereading, I think I was on autopilot typing that previous comment, and autopilot didn't really make it unambiguously clear)...
...when I wrote 'Questions like this really make me wonder.....' , the type of question in reference was that of the OP and not your question, pheonix911. I'm guessing your got that, but if taken the other way, it seems belligerent and certainly uncalled for.... so I didn't want it to remain hanging out there unexplained.
04/24/2014 7:44 AM
I had gotten that,....... and even if I didn't I not that sensitive that I can be critized...
But thanks for the concerned though.
04/23/2014 2:18 PM
kg/cm2/min is not a meaningful unit, anyway.
04/23/2014 3:16 PM
What we have here, is failure to communicate.
04/23/2014 3:17 PM
I don't understand.......
04/23/2014 4:39 PM
again?
You have to actively participate in the manifestations of your own joys and good fortunes - they are not ready made for the taking, they are available for the making.
04/23/2014 11:04 PM
Again!
04/23/2014 5:38 PM
Titanium has unique set of properties that makes it suitable for variety of applications in Power plant , Desalination plant and Process Industries etc . It has a high environmental resistance , relying primarily on a very thin , tenacious and highly protective surface oxide film . Titanium is highly resistant to wet chlorine chemicals , practically all salt solutions , sea water , a range of acids , organic and inorganic chemicals and gases. The same oxide film provides a high resistance to erosion in high velocity process streams. The corrosion and erosion resistance makes titanium a preferred heat transfer material for shell/tube heat exchanger , as it permits the use of thin heat transfer walls and high fluid flow rates . In addition titanium has only half the density of steel. It is non magnetic and is characterized by a high melting point , high strength to weight ratio and low modulus of elasticity.
04/23/2014 5:45 PM
Ti?
What the devil are you talking about?
The question may have been disjointed and vague, but how did you ever come up with Titanium from it???????
Never mind, don't answer that.
04/23/2014 11:41 PM
Even if they provide a response, it's safe to assume that isn't the question they will answer.
'...Rhodium has unique set of factual properties and fanciful properties which makes it ideal for me to spout extemporaniously information that may vary in its veracity but is all unrelated to the question asked. All Rhodium in the universe originated in the relativistic jet sprayed out in the early universe by the galaxy swallowing supermassive black hole called Rhodonodor. Being from such royal lineage, Rhodium is the most pretentious of all the elements. It is better than any halogens, actinides, and rare earth or transition elements, and way better than the remainder. The price of Rhodium has always been to low, which is largely due to jelly haters like that good for nothing Palladium. But Rhodium is resistant to all that pettiness. Everyone desires Rhodium because it has better qualities than any other element. Rhodium is hard and lustrous and inert. Rhodium is tolerating residing in the house of Platinum, until something more suitable is found....'
04/23/2014 5:53 PM
Rohit,
35 surface cubic feet per hour is a good starting point.
You can do the conversion yourself and depending on the specific weld rate and some other conditions adjust up or down.
Don't forget to shield the inside of the tube also.
04/23/2014 11:03 PM
SCFH = standard cubic feet per hour.
04/23/2014 11:25 PM
Thanks. Of course. Standard.
Anonymous Poster #2
04/24/2014 7:28 AM
TIG welding flow rate?? What flow rate do you really need?? Could you elaborate more??
Good Answers: 34
04/25/2014 3:32 AM
Do you have WPS/PQR?
Register to Reply 25 comments
Anonymous Poster (2); Deefburger (1); IdeaSmith (1); lyn (4); Mike W (1); phoenix911 (5); rohit-69 (1); Tornado (2); truth is not a compromise (6); user-deleted-1107 (1); Whitephone (1)
