Friends
We all want clean drinking water. Most of us have seen Chlorination, Ionization, UV etc. Now is the time to move to this new technology.
I will like to experiment with this Novel device called Blumlein HV pulser to generate 100kV pulsed HV output to butcher all pathogens in water giving then a shock of life.
Some of you may still worry about the debris in water so can workout ways to remove it or simply digest it as part of flavor embedded in zero living bacteria in your water.
Those of you have already done great work with Spark HV multipliers and short pulse generators can give their good advices. I am sure some of you have also worked with those high voltage bulbs to create great HV pulse. Let us examine all that is possible to get to this limit.
Idea is to make a 100kV pulser of 100ns to 1000ns pulse width and 100Hz repeat rate with pulse current of 100A in 100ns pulse and about 200mA in 1000ns pulse.
I have experimental budget of about $10000 for this project so please suggest only those items that will fit into this to reach the final goal.
